squeeze flash problem
kevintang
I have the problem to remove the deleted file from flash, Any idea?
R3#sh flash
System flash directory:
File Length Name/status
1 15528164 c3620-is3x-mz.123-15.bin
2 890 r3-confg [deleted]
3 1241 r3-confg
[15530492 bytes used, 1246720 available, 16777212 total]
16384K bytes of processor board System flash (Read/Write)
R3#squeeze flash
Squeeze operation may take a while. Continue? [confirm]
First create squeeze log by erasing the entire device
%Error squeezing flash (Missing or corrupted log)
R3#
R3#sh ver
IOS (tm) 3600 Software (C3620-IS3X-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 25-May-05 01:38 by ssearch
Image text-base: 0x60008B00, data-base: 0x618CC000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3620-IS3X-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
R3 uptime is 19 hours, 34 minutes
System image file is "flash:c3620-is3x-mz.123-15.bin"
cisco 3620 (R4700) processor (revision 0x81) with 61440K/4096K bytes of memory.
Processor board ID 15069834
R4700 CPU at 80MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
2 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s)
DRAM configuration is 32 bits wide with parity enabled.
29K bytes of non-volatile configuration memory.
R3#
according to CCO:
...the squeeze flash command will not work if an erase flash command has never been executed on the router. If this is the case you will receive an "Unable to perform `squeeze flash'" warning message, and you will need to run the erase flash: command to enable the use of the squeeze flash command...
HTH,
GP
