03-31-2010 03:35 AM - edited 03-04-2019 07:59 AM
Hello Netpro
I need to publish a website on a DMZ Server with Active Directory authentication. Its not a public website.
I need to understand the advantages/disadvantages of publishing with SSL and without SSL
thanks
Nasr
Solved! Go to Solution.
03-31-2010 04:06 AM
Well - what's important is how the AD credentials are sent from client to server.
SSL will ensure that the credentials are encrypted even if the credentials are set to 'plain text' in IIS...
It will also validate that the server users are connecting to is the server it says it is - really anywhere where you want users to put their AD credentials (which if compromised could get someone access to any number of things) should be verified in this way...
Aaron
Please rate helpful posts..
03-31-2010 04:06 AM
Aaron
