stack two catalyst 3750 series
moroccancowboy
Do I need just one cable or two?
thank you.
Richard Burts
Youssef
One cable will bring up the connection and will pass data. Two cables will allow the data to pass at full rate. So it is enough to have one cable but it is better to have two.
Rick
Rick
Rick,
Thank you for your help.
Pavel Bykov
Level 5
Level 5
In term of marketing bandwidth, you will get 16Gbps with one cable and 32 gbps with complete circuit, i.e. two cables in your case.
If you have E-series, it's 32Gbps with one and 64 with 2.
Hope this helps.
m_zabetian
It is work with one cable but two cables you have redundancy and double bandwidth
