startup config
Bob Greer
Level 4
Level 4
Hi there,
Thanks for reading.
I have a new router waiting for a circuit delivery.  I configured it and walked away but the router later went offline.  Short version: I came to find that the running config on the router was blank but the startup-config had everything!  What the heck did I do?
It was an easy fix: copy start run and then all was well.
I just don't know how I got there?
Thanks again,
Bob
Joseph W. Doherty
Check your config reg and show ver (for up time).  Your config reg may be set to ignore startup and you may have had some device restart.
Joseph W. Doherty
That was it EXACTLY.
Thanks!
Bob
