Static IP Nat Outside with Route-map
i have static IP NAT inside statement with route-ma( Route-map is working with extended ACL)
NATing is working without any problem
ip nat inside source static 192.168.1.10 x.x.x.x route-map TEST
for some reason.. i want to reverse the NATing statement from inside to outside.
However.. i tried to change the statement from Inside to outside and didnt work
need a help to do static NAT outside with route-map.??
12 Replies 12
balaji.bandi
explain more - inside to outside nat cover global NAT configuration right ? or you looking PBR with different Route ?
BB
Hello
What exaclty do you want to reverse, can you please elaborate
Kind Regards
Paul
explain the problem
interface GigabitEthernet0/1/2
 description --- LAN
 ip nat inside
interface GigabitEthernet0/0/1.406
 description --- WAN
 ip nat outside
ip route x.x.x.x 255.255.255.255 GigabitEthernet0/1/2 10.20.20.1
the route-map contains ACL to block IPs and only allows x.x.x.x.
Targeted:
 description --- LAN
 ip nat outside
 description --- WAN
 ip nat inside
ip nat outside source static 192.168.1.10 x.x.x.x route-map TEST <<<<<<<<<<<<<<<<
However: ip nat outside source static 192.168.1.10 x.x.x.x route-map TEST is not valid syntax
Conf t
ip nat outside source static 192.168.1.10 x.x.x.x ?
  add-route   Add a static route for outside local address
  extendable  Extend this translation when used
  no-alias    Do not create an alias for the local address
  no-payload  No translation of embedded address/port in the payload
  redundancy  NAT redundancy operation
Conf t
ip nat outside source static ?
  A.B.C.D  Outside global IP address
  network  Subnet translation
  tcp      Transmission Control Protocol
  udp      User Datagram Protocol
Hello
Your outside source ip address isn't applicable, it needs to be a public or outside ip address not a internal ip address,
examples:
access-list 1 permit host 1.1.1.1
route-map NAT
match ip address 1
ip nat pool INPOOL 192.1681.11 192.168.1.11 prefix-length
ip nat outside source route-map NAT pool INPOOL
or
ip nat outside source static 1.1.1.1 192.168.1.11
or
ip nat outside source list 1 pool INPOOL
Kind Regards
Paul
Thanks Paul..
During my search I found something but not sure if it will work or not.
Ip nat inside source static x.x.x.x 192.168.1.10 route-map Test reversible
Do you have different Route Route inside ? why you like to have Route-map
route-map TEST
this should work for you : if you looking static NAT.
BB
Actually I have different NAT statements with different routes.
That why I am using the route-maps.
I may have missed some information here, what is this device ? can you post show version ?
BB
The device is asr1001x with ios release 16.12.05
Thanks for the information
as per the output after IP you do not see route-map option that is the reason i have asked what code running here.
what is the outcome @paul driver suggested method ? is this not workable for you. Let me review IOS XE command reference anything changed to do suggest best.
mean time you can check this example :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/15-mt/nat-15-mt-book/iadnat-rmap-outin.html#GUID-B6C74F5E-86F1-45E1-90E4-C688AC31CE32
https://community.cisco.com/t5/networking-documents/how-to-configure-static-nat-with-route-maps/ta-p/3132855
BB
i am wandering the
reversible
option well help  and solve the issue.
Glas to know all working, so  we mark as resolvable now.
BB
