Static NAT and same port traffic over IPSec tunnel
I need to be able to do RDP down an IPSEC tunnel between 2 877 routers (Site to Site VPN) as well as allow RDP in from the internet interface.
so I have a
ip nat source static tcp 192.168.1.5 3389 interface dialer0 3389
to permit the external traffic.  But when this is in place and users are using the external RDP, I cant RDP down the IPSEC Tunnel.  The traffic "disappears".  All other traffic that doesn't have coresponding NAT (PAT) works great.
Any suggestions?
8 Replies 8
   Please post the current configuration.excluding sensitive infornation.
HTH,
Toshi
First is the site we want to RDP from...
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
hostname xxxx877
boot-start-marker
boot-end-marker
logging buffered 52000
no logging console
no aaa new-model
clock timezone ESTime 10
clock save interval 8
crypto pki trustpoint TP-self-signed-3528xxx
!----  Snip  ----
crypto pki certificate chain TP-self-signed-3528xxx
certificate self-signed 01
!----  Snip  ----
dot11 syslog
dot11 ssid xxxx
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 1331121xxxx
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.50
ip dhcp excluded-address 10.10.10.200 10.10.10.254
ip dhcp pool xxxxrRd_LAN_Pool
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 192.168.1.2
   domain-name xxxx.local
   lease 2
   update arp
ip dhcp pool Traffic_PC_Static
   import all
   host 10.10.10.151 255.255.255.0
   client-identifier 0100.1c25.c703.ee
   dns-server 10.10.10.1
   lease 8
   update arp
ip cef
no ip bootp server
ip domain name xxxx.local
ip host noojee 10.10.10.253
ip name-server 203.50.2.71
ip name-server 139.130.4.4
login block-for 300 attempts 4 within 60
login delay 7
login quiet-mode access-class aclQuietMode
login on-failure log
username UserInfo privilege 15 secret 5 $1$wxxxx
crypto isakmp policy 20
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key ATrickyPSKxxx address 120.151.xx.xx no-xauth
crypto ipsec transform-set RRCSet esp-3des esp-md5-hmac
crypto map RRCMap 20 ipsec-isakmp
set peer 120.151.xx.xxx
set transform-set RRCSet
match address 120
archive
log config
  hidekeys
ip ssh version 2
bridge irb
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
load-interval 30
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid tsrr
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description RiverRd LAN Interface
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer0
description ADSL2+ WAN FNN Nxxx9582R
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxx.@@direct.telstra.net
ppp chap password 7 075xxxx
crypto map RRCMap
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip http access-class 22
ip http authentication local
ip http secure-server
ip dns server
ip nat source static tcp 10.10.10.250 9013 interface Dialer0 9013
ip nat source static tcp 10.10.10.253 22 interface Dialer0 10022
ip nat inside source route-map rmNatIn2Out interface Dialer0 overload
ip access-list standard aclQuietMode
permit 120.151.xx.xx
permit 202.173.xx.xx
permit 10.10.10.0 0.0.0.255
permit 192.168.1.0 0.0.0.255
ip access-list extended aclNat
deny   ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 10.10.10.0 0.0.0.255 any
access-list 22 permit 10.10.10.0 0.0.0.255
access-list 22 permit 192.168.1.0 0.0.0.255
access-list 119 deny   ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 119 permit ip 10.10.10.0 0.0.0.255 any
access-list 120 permit ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255 log
dialer-list 1 protocol ip permit
no cdp run
route-map rmNatIn2Out permit 10
match ip address aclNat
control-plane
bridge 1 route ip
alias exec tl0 terminal length 0
line con 0
no modem enable
transport output all
line aux 0
line vty 0 2
access-class 22 in
exec-timeout 20 0
login local
transport input telnet
line vty 3 4
exec-timeout 20 0
login local
transport input ssh
scheduler max-task-time 5000
sntp server 202.173.144.3
sntp server 128.250.36.2
sntp server 202.72.191.202
Then the site we want to RDP in to both down the tunnel and externally in
no service pad
hostname xxxx877
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
crypto pki trustpoint TP-self-signed-2567xxxx
crypto pki certificate chain TP-self-signed-2567xxxx
!----  Snip  ----
dot11 syslog
dot11 ssid xxxx
   authentication open
   guest-mode
   wpa-psk ascii 7 122D001xx
no ip source-route
ip cef
no ip bootp server
ip domain name tlsg.local
login delay 7
username Theuser privilege 15 secret 5 $1$Bxxxx
crypto isakmp policy 10
encr 3des
hash md5
group 2
crypto isakmp key ATrickypskxxxx address 165.228.xx.xxx no-xauth
crypto map RRCMap 10 ipsec-isakmp
set peer 165.228.xx.xx
match address 120
archive
log config
  hidekeys
ip ssh version 2
bridge irb
interface ATM0
no ip address
no ip route-cache
load-interval 30
pvc 8/35
no ip address
ssid xxxx
station-role root
no cdp enable
bridge-group 1
interface Vlan1
description Centro LAN Interface
no ip address
bridge-group 1
interface Dialer0
description ADSL2+ FNN:N7xxxx
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
no cdp enable
ppp chap hostname xxxx@@direct.telstra.net
ppp chap password 7 15xxxx
crypto map RRCMap
interface BVI1
ip address 192.168.1.254 255.255.255.0
ip nat inside
no ip http server
ip dns server
ip nat source static tcp 192.168.1.250 9013 interface Dialer0 9013
ip nat source static tcp 192.168.1.5 3389 interface Dialer0 3389
ip nat source static tcp 192.168.1.5 3050 interface Dialer0 3050
ip nat source static tcp 192.168.1.2 443 interface Dialer0 443
ip nat source static tcp 192.168.1.2 987 interface Dialer0 987
permit 165.228.xx.xx
deny   ip 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 any
logging trap debugging
access-list 119 deny   ip 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 119 permit ip 192.168.1.0 0.0.0.255 any
access-list 120 permit ip 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255
no cdp run
control-plane
bridge 1 route ip
alias exec tl0 term len 0
line con 0
no modem enable
line aux 0
line vty 0 2
exec-timeout 20 0
login local
line vty 3 4
exec-timeout 20 0
login local
transport input ssh
     The problem is when you apply "ip nat source static tcp 192.168.1.5 3389 interface Dialer0 3389" on the router. RDP packets(From Tunnel) returned to 10.10.10.0/24 will hit this NAT statement. And Source-192.168.1.5 is modified. That's why you cannot RDP from 10.10.10.0/24 to 192.168.15 through the Tunnel anymore.  As far as I know is that you can apply a route-map to NAT statement to solve the problem.
Let's say "ip nat source static tcp 192.168.1.5 3389 A.B.C.D 3389 route-map Deny-Return-RDP".
     Unfortunately you cannot do this with Interface parameter on NAT statement.  I'm not sure about the new IOS.You may try.
HTH,
Toshi
Hi Toshi,
I am afraid I don't understand your reply.  Are your saying the above route map should be created or that it doesn't work?  If it doesn't work what is the solution?  if it does work what goes in the route map and what goes in the A.B.C.D?
Assuming the A.B.C.D is inside global then using the command...
ip nat source static tcp 192.168.1.5 3389 120.151.xx.xx 3389 ...
the only options using command completion are Extendable, no-alias, and no-payload.
Thanks Toshi
    Sorry,I was a bit sleepy while I wrote it.    The problem is return RDP packets from 192.168.1.5 to 10.10.10.0/24 will hit this NAT, ip nat source static tcp 192.168.1.5 3389 interface Dialer0 3389.  Source-192.168.1.5 will be modified. That's why it fails.  If your wan ip address is static ip address,you can solve this problem by using commands below.
ip access-list extend Deny-Return-RDP
deny ip host 192.168.1.5 10.10.10.0 0.0.0.255
permit ip host 192.168.1.5 any
match ip address Deny-Return-RDP
   However,you have no route-map option when using interface command in NAT statement.
HTH,
Toshi
Hi Toshi,
Thanks for the response.
The only way I can get the route-map option available is ...
ip nat inside source static tcp 192.168.1.5 3389 120.151.xx.xx 3389 route-map DenyReturnRDP
what is the diference between ip nat inside source static and ip nat source static?  can they be used interchangeably in this situation?
  "ip nat sorce static" means you don't specify the direction in command it's actullay used when using NVI. Just try this link:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/gtnatvi.html
HTH,
Toshi
Hi Toshi,
I have read that article through a few times now but can't see an explanation in there on the difference between the 2 statements.
From another forum I have had some advice to change the IPSEC tunnel to a VTI as opposed to crypto map and that has fixed my issue.  The VTI is a much more elegant solution as being able to control the routing and hence the path of the return traffic, resolves the issue.
I will keep trying to find and answer as to whether I should be using
ip nat source static tcp xx.xx.xx.xx interface dialer0
or
ip nat inside source static tcp xx.xx.xx.xx interface dialer0
to publish a service as I am stil confused about the difference
