static Nat help
ibrasoul
Hello guys i just need some help in  configuring static natting to my cisco router. some configurations are already done to  the router , when i try to add my server by using this command "ip nat inside source static x.x.x.x x.x.x.x "  my server still cannot access internet . need some help guys. the Underlined ip is the one that i added but it fails to get internet
Here is my running config
license udi pid CISCO2921/K9 sn FCZ160970
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description LINK TO AIRTEL
 bandwidth 100000
 ip address 172.16.100.2 255.255.255.240
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LINK TO CYBEROAM-A
 ip address 172.16.0.1 255.255.255.252
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description LINK TO CYBEROAM-B
 ip address 172.16.0.5 255.255.255.252
 ip nat inside
 duplex auto
 speed auto
interface ATM0/0/0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface FastEthernet0/1/0
 ip address 41.75.211.214 255.255.255.248
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet0/1/1
 no ip address
 shutdown
 duplex auto
 speed auto
router ospf 1
 redistribute rip subnets
 network 172.16.0.84 0.0.0.3 area 1
 network 172.16.100.0 0.0.0.15 area 1
router rip
 version 2
 redistribute ospf 1 metric 4
 passive-interface GigabitEthernet0/0
 network 172.16.0.0
 no auto-summary
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list AVS_INTERNET interface FastEthernet0/1/0 overload
ip nat inside source static 172.16.2.19 41.75.211.210
ip nat inside source static 172.16.2.22 41.75.211.211
ip nat inside source static 172.16.2.15 41.75.211.212
ip nat inside source static 172.16.3.28 41.75.211.214
ip route 0.0.0.0 0.0.0.0 41.75.211.209
ip access-list extended AVS_INTERNET
 deny   ip host 172.16.2.10 172.16.0.0 0.0.255.255
 permit ip host 172.16.2.10 any
logging 172.16.4.20
no cdp run
2 Accepted Solutions
Interesting... let's do some diagnostics on your router, show the following commands output from your router:
ping 8.8.8.8 source 41.75.211.211
traceroute 8.8.8.8 source 41.75.211.211
(maybe you will need to add secondary address 41.75.211.211 to FastEthernet0/1/0)
sh ip nat translations (while ping -t 8.8.8.8 from your problem host)
Then remove secondary address from router and try there:
ping 41.75.211.211
sh ip arp
So the problem was on intermidiate device that acts as firewall and router  - between the host an ISR router. After reconfiguring that device everything workes fine.
Good luck, and have a good day!
9 Replies 9
dukenuk96
Level 3
Level 3
A bit offtopic maybe.. but you have this command on interfaces:
are you sure you need it?
then you have:
strange construction.. what do you expect from this?
And you said "my server still cannot access internet" - if the task is just to let the server access the internet and the server does not publish any external services (web, mail, etc..) then overload is enough - it is not a good practice to allow all port ranges to be translated to your internal servers.
Also please show IP configuration of the server plus traceroute. And tell - other hosts in your network are capable to access the Internet?
this host has an ip of 172.16.2.19 , it can access internet and it is in the same subnet as that of 172.16.2.22
Below is the trace route result from this host
tracert 8.8.8.8
Tracing route to google-public-dns-a.google.com [8.8.8.8]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  172.16.2.1
  2     1 ms    <1 ms    <1 ms  172.16.0.5
  3     7 ms     5 ms     5 ms  41.75.211.209
  4     7 ms     7 ms     7 ms  10.87.2.90
  5     6 ms     7 ms     7 ms  10.87.2.122
This is ipconfig result for 172.16.2.19
Windows IP Configuration
   Host Name . . . . . . . . . . . . : BI-SERVER
   Primary Dns Suffix  . . . . . . . : labnet.or.tz
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : labnet.or.tz
Ethernet adapter Local Area Connection 3:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Microsoft Virtual Machine Bus Network A
pter #2
   Physical Address. . . . . . . . . : 00-15-5D-0F-04-04
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection 2:
   Description . . . . . . . . . . . : Intel 21140-Based PCI Fast Ethernet Ada
er (Emulated)
   Physical Address. . . . . . . . . : 00-15-5D-0F-04-02
Ethernet adapter Local Area Connection:
pter
   Physical Address. . . . . . . . . : 00-15-5D-0F-04-00
   DHCP Enabled. . . . . . . . . . . : No
   IPv4 Address. . . . . . . . . . . : 172.16.2.19(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.224
   Default Gateway . . . . . . . . . : 172.16.2.1
   DNS Servers . . . . . . . . . . . : 172.16.4.15
                                       41.75.208.65
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{E8A224B3-8AAE-4A10-9D6E-E847DA39A963}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.{73D37043-1CFB-48D8-A91C-8B4F0E19F41A}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{FEF6AD18-2DB7-4F62-B6FE-F22792C58EB6}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Note: 172.16.2.19 and 172.16.2.22 are both virtual machine whose in 172.16.2.20
ibrasoul
tracert 8.8.8.8
pter #2
er (Emulated)
pter
                                       41.75.208.65
Good, show the same for 172.16.2.22
C:\Users\administrator.LABNET>tracert 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
  2     *        *        *     Request timed out.
  3     *        *
C:\Users\administrator.LABNET>ipconfig /all
   Host Name . . . . . . . . . . . . : FALCON
pter
   Physical Address. . . . . . . . . : 00-15-5D-0F-04-08
   IPv4 Address. . . . . . . . . . . : 172.16.2.22(Preferred)
                                       41.75.208.65
Tunnel adapter isatap.{A7CB4C95-5D07-44C0-9983-EC48CA6B67FA}:
ping 41.75.211.211
sh ip arp
please see the following results after doing what you suggested
DC-WAN-ISR2921#ping 8.8.8.8 source 41.75.211.211
% Invalid source address- IP address not on any of our up interfaces
DC-WAN-ISR2921#traceroute 8.8.8.8 source 41.75.211.211
sh ip nat translations (41.75.211.211 added as a secondary ip in fastethernet0/1/0)
udp 41.75.211.212:61799 172.16.2.15:61799 41.75.208.65:53    41.75.208.65:53
udp 41.75.211.212:63031 172.16.2.15:63031 41.75.208.65:53    41.75.208.65:53
--- 41.75.211.212      172.16.2.15        ---                ---
tcp 41.75.211.210:1234 172.16.2.19:1234   62.149.142.15:80   62.149.142.15:80
udp 41.75.211.210:5093 172.16.2.19:5093   167.114.210.233:46959 167.114.210.233:
46959
tcp 41.75.211.210:63966 172.16.2.19:63966 52.74.15.80:80     52.74.15.80:80
--- 41.75.211.210      172.16.2.19        ---                ---
udp 41.75.211.211:5093 172.16.2.22:5093   167.114.210.233:46959 167.114.210.233:
46959
udp 41.75.211.211:12476 172.16.2.22:12476 1.9.47.18:52617    1.9.47.18:52617
udp 41.75.211.211:12476 172.16.2.22:12476 86.163.137.102:52323 86.163.137.102:52
323
--- 41.75.211.211      172.16.2.22        ---                ---
tcp 41.75.211.214:1234 172.16.3.28:1234   62.149.142.15:80   62.149.142.15:80
icmp 41.75.211.214:3686 172.16.3.28:3686  123.126.126.107:3686 123.126.126.107:3
686
udp 41.75.211.214:5093 172.16.3.28:5093   167.114.210.233:46959 167.114.210.233:
46959
udp 41.75.211.214:50181 172.16.3.28:50181 27.106.62.222:11174 27.106.62.222:1117
--- 41.75.211.214      172.16.3.28        ---                ---
sh ip arp results
DC-WAN-ISR2921#sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  41.75.211.209           0   0019.e287.8021  ARPA   FastEthernet0/1/0
Internet  41.75.211.210           -   7cad.743e.257a  ARPA   FastEthernet0/1/0
Internet  41.75.211.211           -   7cad.743e.257a  ARPA   FastEthernet0/1/0
Internet  41.75.211.212           -   7cad.743e.257a  ARPA   FastEthernet0/1/0
Internet  41.75.211.214           -   7cad.743e.257a  ARPA   FastEthernet0/1/0
Internet  172.16.0.1              -   442b.0321.c2e1  ARPA   GigabitEthernet0/1
Internet  172.16.0.2              0   0002.b642.7db3  ARPA   GigabitEthernet0/1
Internet  172.16.0.5              -   442b.0321.c2e2  ARPA   GigabitEthernet0/2
Internet  172.16.0.6              0   0002.b642.7db2  ARPA   GigabitEthernet0/2
Internet  172.16.100.1            4   0019.e286.8000  ARPA   GigabitEthernet0/0
Internet  172.16.100.2            -   442b.0321.c2e0  ARPA   GigabitEthernet0/0
Internet  172.16.100.3           99   f0f7.55d4.bb41  ARPA   GigabitEthernet0/0
Internet  172.16.100.4            0   Incomplete      ARPA
Internet  172.16.100.5          168   f0f7.55d4.9e21  ARPA   GigabitEthernet0/0
Internet  172.16.100.6          110   f0f7.55d4.b681  ARPA   GigabitEthernet0/0
Internet  172.16.100.7          150   f0f7.55d4.b981  ARPA   GigabitEthernet0/0
Internet  172.16.100.8          165   f0f7.55b3.a881  ARPA   GigabitEthernet0/0
Internet  172.16.100.9          133   f0f7.55d4.b841  ARPA   GigabitEthernet0/0
Internet  172.16.100.10          35   f0f7.55d4.bb81  ARPA   GigabitEthernet0/0
You missed a few key things I asked to do.. well.. would you like to make live tshoot using some app? You can write to my skype:andrey66_87
