Static NAT Issue
BCS-Tech
FPM 1010 using FTD
Is there a way to do a static NAT from one office IP to another office IP through a Site-to-Site VPN tunnel.
We use a cloud provided software that prints to local printers using IP printing.
The cloud provider and our local office have s Site-To-Site VPN. so users can print to a 192.168.126.??? printer
Cloud provider 172.156.XXX.XXX/28
Local office 192.168.126.0/24
VPN Remote  192.168.0.0/24
Our office is Site-to-Site VPN with our Remote office.
Our cloud provider cannot use 192.168.0.XXX to be able to print to one of our printers since that is already being used by another of their customers.
I would like to setup a printer in the cloud location to print to 192.168.126.90 and have that NATTED to 192.168.0.20.
Is this possible?
So far I have not been successful
From the local office, I can ping 192.168.0.20, but cannot ping 192.168.126.90
Help
"Lost in Space"
36 Replies 36
Yes you can
Use NAT
Then use mapped IP in acl of IPSec in local peer and remote peer
MHM
BCS-Tech
Thanks, but can you be more specific?
NAT
Is the translated Interface Outside or (inside since it is a site-to-site)
Need help on the "mapped IP"
Thanks in advance.
BCS-Tech
I already have an allow ANY to ANY both inbound and outbound for ACL between both offices.
Ok
What is local LAN and is remote LAN waht is mapped LAN?
Let me guide you to config vpn step by step
MHM
BCS-Tech
The local an remote info is in the first post above.
The site-to-site VPN is setup and I can ping both ways.
My issue to connecting a local IP to a remote IP using NAT.
Local office 192.168.126.90 -> 192.168.0.20
Now let start
First' remove the any at any it bad idea use any in vpn acl
Use acl
First line
192.168.126.0/24 to 192.168.0.0/24
192.168.10.20/32 to192.168.0.0/24
Why 192.168.10.20 becuase you can not use 192.168.0.20 since remote use 192.168.0.0/24 this make conflict in IP
Config NAT
Real IP
Source 192.168.126.90
Destiantion 192.168.0.0
Translate IP
Source 192.168.10.20
Do above and check
MHM
BCS-Tech
This does not make since to me
Real IP
Translate IP
You want me to NAT to a .0 address that does not exist?
Real IP
Source 192.168.126.90 <<- this NATing
Destiantion 192.168.0.0 <- this destiantion use as condition
Translate IP
Destiantion 192.168.0.0 <<- no NAT
BCS-Tech
Should this be a network?  /24
or
host?
Friend it must be /24
MHM
BCS-Tech
This is what I currently have.  The "Mooresville-Inside" is 192.168.0.0/24
When I ping 192.168.10.20, I get no reply.  When I ping 192.168.0.20, I get a reply. I am pinging from 192.168.126.2
I know I am missing something. And I want to say I appreciate all the help.
How you ping from 192.168.126.2 ? You need to ping from remote office 192.168.0.x to 192.168.10.20 and local office will NATing it to 192.168.126.0.90.
Or I am wrong?
MHM
BCS-Tech
The local office is 192.168.126.0/24
Remote office 192.168.0.0/24
remote Printer I want to be able to ping to using the local ip of 192.168.126.90 is 192.168.0.20
I want to be able ping 192.168.126.90 from 192.168.126.2 and the system connects to the remote of 192.168.0.20 and sends the reply back as a complete ping.
Is this posible?
BCS-Tech
If this is possible, then I can give the cloud provider and internal IP address of 192.168.126.90 for a printer on their print server and that system will send the print job to 192.168.126.90 and the local FPM1010 will NAT that job to 192.168.0.20 and the system should print the file.
That's the plan anyway.
