Static NAT not working over the GRE Tunnel
smohanasundaram
my config as follows
interface Tunnel5
description "" xxxxxx ""
bandwidth 1024
ip address a.a.a.a 255.255.255.252
ip mtu 1500
tunnel source b.b.b.b
tunnel destination k.k.k.k
interface FastEthernet0/0
ip address y.y.y.y 255.255.255.128
ip address b.b.b.b 255.255.255.240 secondary
ip nat inside
interface Serial1/0
description *** 2MBPS Link ***
bandwidth 2048
ip address z.z.z.z 255.255.255.252
ip accounting output-packets
ip nat outside
ip route 0.0.0.0 0.0.0.0 y.y.y.y-1
ip route w.w.w.w 255.255.255.224 Tunnel5
ip nat inside source static w.w.w.w y.y.y.y extendable
this static nat translations not working.Please help me to resolv this
15 Replies 15
paolo bevilacqua
You have no ip nat command under tunnell interface.
thanks for your reply
now i configured ip nat inside to tunnel interface,but not working
i am able to ping the ip address.i cannot able to work with other services like DNS and Http
thanks in advance
Check that the translation is formed as expected.
yes.nat translation is formed.But when i telnet Y.Y.Y.Y 80 this output will be connection refused error
Blame the host.
What happens when you do a
"sh ip nat tran"
Do you see it in there?
yes.router translates the ip and ports.but i cannot able to work with services
thanks in advance
I'd remove the secondary IP and see if that effects anything ...
secondary ip removed but no improvements
Can you do a debug on NAT and post the output here?
debug ip nat detailed
S mohana,
Please explain in detail on what you're going to accomplish with NAT. It should be a good idea to explain about the direction of traffic(dest/source) pass through this router.
As other poster said,let us see the output of "debug ip nat detail".
HTH,
Toshi
debug command output as follows
*Mar 6 18:29:56.303 IST: NAT: o: tcp (59.99.0.239, 6318) -> (203.112.139.174, 135) [7966]
*Mar 6 18:29:56.303 IST: NAT: o: tcp (59.95.189.53, 8308) -> (203.112.131.238, 135) [2492]
*Mar 6 18:29:56.303 IST: NAT: o: udp (202.54.15.30, 53) -> (203.112.128.20, 1024) [19190]
*Mar 6 18:29:56.303 IST: NAT: o: udp (203.112.151.57, 59651) -> (203.112.128.1, 161) [47]
*Mar 6 18:29:56.303 IST: NAT: o: udp (200.230.94.35, 48035) -> (203.112.128.25( This is my DNS Server IP Address, 53) [33402]
*Mar 6 18:29:57.123 IST: NAT: o: udp (203.112.151.51, 59492) -> (203.112.128.25, 53) [29470]
*Mar 6 18:29:57.127 IST: NAT: o: udp (200.142.58.20, 10795) -> (203.112.128.25, 53) [0]
*Mar 6 18:29:57.127 IST: NAT: o: tcp (203.112.205.197, 2411) -> (203.112.128.69, 135) [56942]
*Mar 6 18:29:57.127 IST: NAT: o: udp (195.90.231.241, 38844) -> (203.112.128.20, 53) [0]
*Mar 6 18:29:57.127 IST: NAT: o: icmp (200.142.58.20, 52452) -> (203.112.128.20, 53) [57184]
*Mar 6 18:29:57.127 IST: NAT: o: udp (203.112.151.51, 59492) -> (203.112.128.20, 53) [29472]
thanks
Hello
any updates.Please help me to solv this
I told you already, likely host problem, check the icmp message received.
