02-29-2012 10:13 PM - edited 03-04-2019 03:29 PM
Dear boss
I have a IP 192.168.0.1 and i NAT it to 172.25.40.1
like ip nat inside source static 192.168.0.1 172.25.40.1 as outsider can get 172.25.40.1.
Now i want to NAT 192.168.0.1 to 172.30.40.1 as both 172.30.40.1 and 172.25.40.1 get 192.168.0.1.
How can i do it ?
Thanking You
shahid
Solved! Go to Solution.
02-29-2012 11:40 PM
Yes you can. But depends on what version of IOS you are running. NAT with route-maps was introduced in 12.4(T) i believe.
access-list 101 permit ip host 192.168.0.1 host x.x.x.x
access-list 102 permit ip host 192.168.0.1 host y.y.y.y
route-map NAT_25 permit 10
match ip address 101
route-map NAT_30 permit 10
match ip address 102
ip nat inside source static 192.168.0.1 172.25.40.1 route-map NAT_25
ip nat inside source static 192.168.0.1 172.30.40.1 route-map NAT_30
Test this out & let me know. Replace the x.x.x.x with the destination X & replace y.y.y.y with destination y
Hope you got it.
Vivek.
02-29-2012 11:40 PM
Hope you got it.
Vivek.
03-01-2012 01:51 AM
Thanks a lot Mr. Vivek
It is taking the command. I will wait for ur response when i face difficulties in real implementation.
Thanks.
