Static Nat stops working
gcarson73
I have 13 public IP's, NAT/PAT to HTTP,HTTPS, RDP ect.....  I am using a Cisco 2951 with Version 15.0(1) M3.
My FTP server IP is 10.3.81.7 and the public IP for it is 99.3.81.72
About every 6 hours, I have to use the commands
no ip nat inside source static 10.3.81.7 99.3.81.72
Any idea on why I have to keep doing that?  I have other public IP's in use with no issues.
Building configuration...
Current configuration : 5681 bytes
! Last configuration change at 13:20:49 UTC Sun Apr 3 2016 by smith
version 15.0
hostname router
boot-start-marker
boot-end-marker
enable secret 5 $$%%$$%%$$%%
aaa new-model
aaa session-id common
no ipv6 cef
ip source-route
no ip icmp rate-limit unreachable
no ip icmp rate-limit unreachable DF
ip cef
no ip domain lookup
ip domain name tss.tssgis.com
ip name-server 208.67.222.222
ip name-server 208.67.220.220
voice-card 0
license udi pid CISCO2951/K9 sn FGL170811RR
username smith privilege 15 secret 5 $$$%%%$%$%$%
redundancy
interface GigabitEthernet0/0
description verizoninternet
ip address 99.3.81.66 255.255.255.0
ip access-group block1 in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
description TSSLAN
ip address 10.3.81.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool mynatpool 99.3.81.66 99.3.81.78 netmask 255.255.255.0
ip nat inside source list 1 pool mynatpool overload
ip nat inside source static tcp 10.3.81.57 80 99.3.81.67 80 extendable
ip nat inside source static tcp 10.3.81.5 443 99.3.81.68 443 extendable
ip nat inside source static udp 10.3.81.5 500 99.3.81.68 500 extendable
ip nat inside source static tcp 10.3.81.5 992 99.3.81.68 992 extendable
ip nat inside source static tcp 10.3.81.5 1194 99.3.81.68 1194 extendable
ip nat inside source static udp 10.3.81.5 1701 99.3.81.68 1701 extendable
ip nat inside source static udp 10.3.81.5 4500 99.3.81.68 4500 extendable
ip nat inside source static tcp 10.3.81.5 5555 99.3.81.68 5555 extendable
ip nat inside source static tcp 10.3.81.6 443 99.3.81.69 443 extendable
ip nat inside source static tcp 10.3.81.61 80 99.3.81.70 80 extendable
ip nat inside source static tcp 10.3.81.49 80 99.3.81.71 80 extendable
ip nat inside source static tcp 10.3.81.49 443 99.3.81.71 443 extendable
ip nat inside source static tcp 10.3.81.16 80 99.3.81.73 80 extendable
ip nat inside source static tcp 10.3.81.90 3389 99.3.81.73 3389 extendable
ip nat inside source static 10.3.81.12 99.3.81.74
ip nat inside source static tcp 10.3.81.89 80 99.3.81.75 80 extendable
ip nat inside source static tcp 10.3.81.89 443 99.3.81.75 443 extendable
ip nat inside source static tcp 10.3.81.95 3389 99.3.81.75 3389 extendable
ip nat inside source static tcp 10.3.81.55 8080 99.3.81.75 8080 extendable
ip nat inside source static tcp 10.3.81.15 80 99.3.81.76 80 extendable
ip nat inside source static tcp 10.3.81.14 3389 99.3.81.76 3389 extendable
ip nat inside source static tcp 10.3.81.15 6080 99.3.81.76 6080 extendable
ip nat inside source static tcp 10.3.81.92 80 99.3.81.77 80 extendable
ip nat inside source static tcp 10.3.81.60 80 99.3.81.78 80 extendable
ip route 0.0.0.0 0.0.0.0 99.3.81.1
ip access-list extended block1
deny tcp any 99.3.81.0 0.0.0.255 fragments
deny udp any 99.3.81.0 0.0.0.255 fragments
deny icmp any 99.3.81.0 0.0.0.255 fragments
deny icmp any 99.3.81.0 0.0.0.255 echo
deny ip host 0.0.0.0 any
deny ip 127.0.0.0 0.255.255.255 any
deny ip 192.0.2.0 0.0.0.255 any
deny ip 224.0.0.0 31.255.255.255 any
deny ip 10.0.0.0 0.255.255.255 any
deny ip 172.16.0.0 0.15.255.255 any
deny ip 192.168.0.0 0.0.255.255 any
deny ip 175.117.0.0 0.0.255.255 any
deny ip host 162.209.114.244 any
deny ip host 93.174.93.164 any
deny ip host 93.174.93.227 any
deny ip host 185.56.82.18 any
deny ip host 141.212.122.82 any
deny ip host 5.39.222.253 any
deny ip host 94.102.49.210 any
deny ip host 67.78.23.214 any
deny ip host 89.248.172.173 any
deny ip host 46.172.71.251 any
deny ip host 141.212.122.59 any
deny ip host 93.113.125.11 any
deny ip host 208.100.26.229 any
deny ip host 141.212.122.122 any
deny ip host 111.13.102.5 any
deny ip host 141.212.122.3 any
deny ip host 71.6.167.142 any
deny ip host 94.102.56.130 any
deny ip host 91.90.225.23 any
deny ip host 141.212.122.90 any
deny ip host 137.226.113.7 any
deny ip host 94.102.48.194 any
deny ip host 198.20.69.98 any
deny ip host 71.6.165.200 any
deny ip host 141.212.122.42 any
deny ip host 85.25.43.94 any
deny ip host 60.217.72.10 any
deny ip host 62.210.209.237 any
deny ip host 94.102.49.79 any
deny ip host 66.240.192.138 any
deny ip host 184.168.47.225 any
deny ip host 180.97.106.162 any
deny ip host 180.97.106.36 any
deny ip host 37.59.28.236 any
deny ip host 23.236.62.147 any
deny ip host 208.100.26.231 any
permit ip any any
ip access-list extended blockvty
permit ip 10.3.81.0 0.0.0.255 any
deny ip any any
access-list 1 permit 10.3.81.0 0.0.0.255
no cdp run
nls resp-timeout 1
cpd cr-id 1
control-plane
gatekeeper
shutdown
banner exec ^C
*** Ensure that you update the system configuration ***
*** documentation after making system changes. ***
^C
banner login ^C
*** Login Required. Unauthorized use is prohibited ***
^C
banner motd ^C
If you have not been provided with permission to
access this device - disconnect at once.
^C
line con 0
line aux 0
line vty 0 4
access-class blockvty in
transport input ssh
scheduler allocate 20000 1000
end
dukenuk96
Level 3
Level 3
Show the output of
show ip nat translations [ verbose ]
Are you sure the problem is in your Cisco box, not FTP server or client? What exactly happens that make you issue those two commands? Existing FTP session fails or new sessions fails to initiate? Collect packet dumps and logs from both client and server when something bad happens, this should clarify what's happening at these moments.
I am able to ping both interfaces on the Router with the FTP server.  I cannot ping 8.8.8.8.
I have had to issue the
to make it work three times yesterday...I have an alert set to notify when the public IP goes "offline"
I have found the solution!  DO NOT USE IP NAT POOL!!!! (if you are using Static and Dynamic NAT Simultaneously)
"the same IP address cannot be used for the NAT static configuration or in the pool for NAT dynamic configuration."
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13778-9.html
If you are Configuring Static and Dynamic NAT Simultaneously, the setup should be like below
ip nat inside source list 1 interface g0/0 overload
ip nat inside source static tcp 10.10.10.1 25 172.16.130.2 25
*I changed my IP nat pool mynatpool 99.3.81.66 99.3.81.66, so the range would be only 1 publick IP, and my static NAT still stopped working for the FTP server...but after I removed
no ip nat pool mynatpool 99.3.81.66 99.3.81.66 prefix-length 24
no ip nat inside source list 1 pool mynatpool overload
and added
ip nat inside source list 1 interface G0/0 overload
I have had 3 days without any Static NAT issues! Now to go update every blog I found about "static NAT stopped working"......FYI and all of them were using the IP NAT POOL command.
Pro Inside global      Inside local       Outside local      Outside global
tcp 99.3.81.66:54743  10.3.81.2:54743    169.55.36.119:5938 169.55.36.119:5938
udp 99.3.81.66:59170  10.3.81.2:59170    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59182  10.3.81.2:59182    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59196  10.3.81.2:59196    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59295  10.3.81.2:59295    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60018  10.3.81.2:60018    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60356  10.3.81.2:60356    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60427  10.3.81.2:60427    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60515  10.3.81.2:60515    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60944  10.3.81.2:60944    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60988  10.3.81.2:60988    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61152  10.3.81.2:61152    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61338  10.3.81.2:61338    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61415  10.3.81.2:61415    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:49679  10.3.81.3:49679    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:49846  10.3.81.3:49846    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:50472  10.3.81.3:50472    208.67.222.222:53  208.67.222.222:53
tcp 99.3.81.66:50484  10.3.81.3:50484    173.192.194.85:5938 173.192.194.85:5938
tcp 99.3.81.66:57105  10.3.81.3:57105    128.121.22.176:443 128.121.22.176:443
tcp 99.3.81.66:57107  10.3.81.3:57107    128.121.22.176:443 128.121.22.176:443
udp 99.3.81.66:65236  10.3.81.3:65236    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59546  10.3.81.4:59546    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59674  10.3.81.4:59674    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60098  10.3.81.4:60098    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60260  10.3.81.4:60260    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60281  10.3.81.4:60281    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60293  10.3.81.4:60293    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60294  10.3.81.4:60294    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60664  10.3.81.4:60664    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60673  10.3.81.4:60673    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61058  10.3.81.4:61058    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61261  10.3.81.4:61261    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61294  10.3.81.4:61294    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61382  10.3.81.4:61382    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61723  10.3.81.4:61723    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61780  10.3.81.4:61780    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61848  10.3.81.4:61848    208.67.222.222:53  208.67.222.222:53
tcp 99.3.81.66:62007  10.3.81.4:62007    209.58.129.78:5938 209.58.129.78:5938
tcp 99.3.81.68:443    10.3.81.5:443      ---                ---
udp 99.3.81.68:500    10.3.81.5:500      ---                ---
tcp 99.3.81.68:992    10.3.81.5:992      ---                ---
tcp 99.3.81.68:1194   10.3.81.5:1194     ---                ---
udp 99.3.81.68:1701   10.3.81.5:1701     ---                ---
udp 99.3.81.68:4500   10.3.81.5:4500     45.37.92.167:4500  45.37.92.167:4500
udp 99.3.81.68:4500   10.3.81.5:4500     63.246.237.26:58894 63.246.237.26:58894
udp 99.3.81.68:4500   10.3.81.5:4500     71.195.146.181:4500 71.195.146.181:4500
udp 99.3.81.68:4500   10.3.81.5:4500     72.91.117.84:4500  72.91.117.84:4500
udp 99.3.81.68:4500   10.3.81.5:4500     73.43.213.215:4500 73.43.213.215:4500
udp 99.3.81.68:4500   10.3.81.5:4500     75.163.184.187:4500 75.163.184.187:4500
udp 99.3.81.68:4500   10.3.81.5:4500     96.249.144.24:4500 96.249.144.24:4500
udp 99.3.81.68:4500   10.3.81.5:4500     96.249.150.228:1025 96.249.150.228:1025
udp 99.3.81.68:4500   10.3.81.5:4500     96.249.150.228:4500 96.249.150.228:4500
udp 99.3.81.68:4500   10.3.81.5:4500     209.232.26.182:4500 209.232.26.182:4500
udp 99.3.81.68:4500   10.3.81.5:4500     ---                ---
tcp 99.3.81.68:5555   10.3.81.5:5555     ---                ---
tcp 99.3.81.66:53383  10.3.81.5:53383    130.158.6.125:443  130.158.6.125:443
tcp 99.3.81.66:54875  10.3.81.5:54875    38.127.167.48:443  38.127.167.48:443
tcp 99.3.81.66:54889  10.3.81.5:54889    38.127.167.48:443  38.127.167.48:443
udp 99.3.81.66:55869  10.3.81.5:55869    130.158.6.56:80    130.158.6.56:80
udp 99.3.81.66:59061  10.3.81.5:59061    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59335  10.3.81.5:59335    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59345  10.3.81.5:59345    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59484  10.3.81.5:59484    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59548  10.3.81.5:59548    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59600  10.3.81.5:59600    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:59878  10.3.81.5:59878    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60161  10.3.81.5:60161    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60315  10.3.81.5:60315    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60614  10.3.81.5:60614    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60648  10.3.81.5:60648    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60665  10.3.81.5:60665    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:60762  10.3.81.5:60762    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:6993  10.3.81.5:6993    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61340  10.3.81.5:61340    208.67.222.222:53  208.67.222.222:53
udp 99.3.81.66:61368  10.3.81.5:61368    208.67.222.222:53  208.67.222.222:53
tcp 99.3.81.66:63099  10.3.81.5:63099    50.22.136.98:5938  50.22.136.98:5938
udp 99.3.81.66:63745  10.3.81.5:63745    130.158.6.116:5004 130.158.6.116:5004
tcp 99.3.81.69:443    10.3.81.6:443      24.125.163.254:57401 24.125.163.254:57401
tcp 99.3.81.69:443    10.3.81.6:443      24.125.163.254:57402 24.125.163.254:57402
tcp 99.3.81.69:443    10.3.81.6:443      156.63.133.8:11937 156.63.133.8:11937
tcp 99.3.81.69:443    10.3.81.6:443      156.63.133.8:21601 156.63.133.8:21601
tcp 99.3.81.69:443    10.3.81.6:443      156.63.133.8:21693 156.63.133.8:21693
tcp 99.3.81.69:443    10.3.81.6:443      156.63.133.8:22472 156.63.133.8:22472
tcp 99.3.81.69:443    10.3.81.6:443      156.63.133.8:29096 156.63.133.8:29096
tcp 99.3.81.69:443    10.3.81.6:443      156.63.133.8:30705 156.63.133.8:30705
tcp 99.3.81.69:443    10.3.81.6:443      156.63.133.8:40145 156.63.133.8:40145
tcp 99.3.81.69:443    10.3.81.6:443      156.63.133.8:41293 156.63.133.8:41293
tcp 99.3.81.69:443    10.3.81.6:443      156.63.133.8:43672 156.63.133.8:43672
tcp 99.3.81.69:443    10.3.81.6:443      ---                ---
tcp 99.3.81.66:63567  10.3.81.6:63567    162.250.2.27:5938  162.250.2.27:5938
udp 99.3.81.72:137    10.3.81.7:137      99.3.80.4:1025    99.3.80.4:1025
tcp 99.3.81.72:3389   10.3.81.7:3389     64.250.195.75:22182 64.250.195.75:22182
tcp 99.3.81.72:3389   10.3.81.7:3389     64.250.195.75:57660 64.250.195.75:57660
icmp 99.3.81.72:8251  10.3.81.7:8251     99.3.80.4:8251    99.3.80.4:8251
tcp 99.3.81.66:57439  10.3.81.7:57439    209.58.129.77:5938 209.58.129.77:5938
--- 99.3.81.72        10.3.81.7          ---                ---
udp 99.3.81.66:51536  10.3.81.8:51536    208.67.222.222:53  208.67.222.222:53
tcp 99.3.81.66:61624  10.3.81.8:61624    162.250.6.2:5938   162.250.6.2:5938
tcp 99.3.81.66:64143  10.3.81.8:64143    128.121.22.176:443 128.121.22.176:443
tcp 99.3.81.66:63421  10.3.81.10:63421   173.192.194.69:5938 173.192.194.69:5938
tcp 99.3.81.66:25228  10.3.81.11:25228   162.250.6.4:5938   162.250.6.4:5938
tcp 99.3.81.66:38056  10.3.81.11:38056   192.168.1.147:135  192.168.1.147:135
udp 99.3.81.74:137    10.3.81.12:137     99.3.80.4:1025    99.3.80.4:1025
tcp 99.3.81.74:4721   10.3.81.12:4721    97.65.132.218:80   97.65.132.218:80
tcp 99.3.81.74:8080   10.3.81.12:8080    222.186.129.221:32733 222.186.129.221:32733
icmp 99.3.81.74:8251  10.3.81.12:8251    99.3.80.4:8251    99.3.80.4:8251
tcp 99.3.81.74:34070  10.3.81.12:34070   97.65.132.218:80   97.65.132.218:80
tcp 99.3.81.74:47161  10.3.81.12:47161   87.250.137.161:80  87.250.137.161:80
tcp 99.3.81.74:58653  10.3.81.12:58653   50.22.136.113:5938 50.22.136.113:5938
tcp 99.3.81.74:58884  10.3.81.12:58884   87.250.137.161:80  87.250.137.161:80
--- 99.3.81.74        10.3.81.12         ---                ---
tcp 99.3.81.76:3389   10.3.81.14:3389    ---                ---
tcp 99.3.81.76:80     10.3.81.15:80      ---                ---
tcp 99.3.81.76:6080   10.3.81.15:6080    ---                ---
icmp 99.3.81.66:1     10.3.81.16:1       65.196.188.24:1    65.196.188.24:1
icmp 99.3.81.66:1     10.3.81.16:1       184.168.47.225:1   184.168.47.225:1
tcp 99.3.81.73:80     10.3.81.16:80      ---                ---
tcp 99.3.81.66:32798  10.3.81.16:32798   162.220.222.5:5938 162.220.222.5:5938
tcp 99.3.81.66:1053   10.3.81.16:42026   184.168.47.225:80  184.168.47.225:80
tcp 99.3.81.66:42045  10.3.81.16:42045   207.200.29.90:443  207.200.29.90:443
tcp 99.3.81.66:57615  10.3.81.17:57615   173.192.194.75:5938 173.192.194.75:5938
tcp 99.3.81.66:63312  10.3.81.18:63312   173.192.194.85:5938 173.192.194.85:5938
tcp 99.3.81.66:58259  10.3.81.19:58259   173.192.194.69:5938 173.192.194.69:5938
tcp 99.3.81.66:49634  10.3.81.20:49634   169.55.36.118:5938 169.55.36.118:5938
tcp 99.3.81.66:35293  10.3.81.45:35293   52.8.141.115:443   52.8.141.115:443
tcp 99.3.81.66:42088  10.3.81.45:42088   54.183.159.187:443 54.183.159.187:443
tcp 99.3.81.71:80     10.3.81.49:80      ---                ---
tcp 99.3.81.71:443    10.3.81.49:443     ---                ---
tcp 99.3.81.75:8080   10.3.81.55:8080    ---                ---
tcp 99.3.81.66:39220  10.3.81.55:39220   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:39221  10.3.81.55:39221   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:39565  10.3.81.55:39565   104.192.143.1:443  104.192.143.1:443
tcp 99.3.81.66:41933  10.3.81.55:41933   104.192.143.2:443  104.192.143.2:443
tcp 99.3.81.66:41984  10.3.81.55:41984   104.192.143.1:443  104.192.143.1:443
tcp 99.3.81.66:42021  10.3.81.55:42021   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:42022  10.3.81.55:42022   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:42023  10.3.81.55:42023   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:42024  10.3.81.55:42024   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:42025  10.3.81.55:42025   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:42026  10.3.81.55:42026   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:42027  10.3.81.55:42027   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:42028  10.3.81.55:42028   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:42029  10.3.81.55:42029   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:42040  10.3.81.55:42040   104.192.143.3:443  104.192.143.3:443
tcp 99.3.81.66:43058  10.3.81.55:43058   104.192.143.2:443  104.192.143.2:443
tcp 99.3.81.66:51053  10.3.81.56:51053   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:51800  10.3.81.56:51800   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:51802  10.3.81.56:51802   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:51804  10.3.81.56:51804   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:51805  10.3.81.56:51805   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:51806  10.3.81.56:51806   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:51807  10.3.81.56:51807   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:51808  10.3.81.56:51808   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:51809  10.3.81.56:51809   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.66:51810  10.3.81.56:51810   131.103.28.7:443   131.103.28.7:443
tcp 99.3.81.67:80     10.3.81.57:80      ---                ---
tcp 99.3.81.66:58757  10.3.81.58:58757   169.254.169.254:80 169.254.169.254:80
tcp 99.3.81.66:58758  10.3.81.58:58758   169.254.169.254:80 169.254.169.254:80
tcp 99.3.81.66:58759  10.3.81.58:58759   169.254.169.254:80 169.254.169.254:80
tcp 99.3.81.66:58760  10.3.81.58:58760   169.254.169.254:80 169.254.169.254:80
tcp 99.3.81.66:59491  10.3.81.59:59491   23.14.84.162:80    23.14.84.162:80
tcp 99.3.81.78:80     10.3.81.60:80      ---                ---
tcp 99.3.81.70:80     10.3.81.61:80      ---                ---
tcp 99.3.81.66:60045  10.3.81.61:60045   173.192.194.75:5938 173.192.194.75:5938
tcp 99.3.81.66:49543  10.3.81.62:49543   50.22.136.98:5938  50.22.136.98:5938
tcp 99.3.81.66:59903  10.3.81.63:59903   209.58.129.81:5938 209.58.129.81:5938
tcp 99.3.81.66:64923  10.3.81.71:64923   15.201.142.250:5223 15.201.142.250:5223
tcp 99.3.81.66:44857  10.3.81.72:44857   15.201.140.250:5222 15.201.140.250:5222
tcp 99.3.81.66:63181  10.3.81.81:63181   184.172.60.198:5938 184.172.60.198:5938
tcp 99.3.81.66:50301  10.3.81.82:50301   198.252.206.25:443 198.252.206.25:443
tcp 99.3.81.66:58544  10.3.81.82:58544   65.196.188.25:443  65.196.188.25:443
tcp 99.3.81.66:58545  10.3.81.82:58545   216.58.219.142:443 216.58.219.142:443
udp 99.3.81.66:61593  10.3.81.82:61593   216.58.219.142:443 216.58.219.142:443
tcp 99.3.81.66:57393  10.3.81.85:57393   209.58.129.78:5938 209.58.129.78:5938
tcp 99.3.81.66:53017  10.3.81.87:53017   173.192.194.66:5938 173.192.194.66:5938
tcp 99.3.81.75:80     10.3.81.89:80      ---                ---
tcp 99.3.81.75:443    10.3.81.89:443     ---                ---
tcp 99.3.81.73:3389   10.3.81.90:3389    ---                ---
tcp 99.3.81.66:49172  10.3.81.90:49172   103.20.93.133:443  103.20.93.133:443
tcp 99.3.81.66:49202  10.3.81.90:49202   144.2.1.1:443      144.2.1.1:443
udp 99.3.81.66:51388  10.3.81.90:51388   216.58.219.134:443 216.58.219.134:443
tcp 99.3.81.66:52878  10.3.81.90:52878   50.22.136.98:5938  50.22.136.98:5938
tcp 99.3.81.66:57575  10.3.81.90:57575   17.167.137.19:443  17.167.137.19:443
tcp 99.3.81.66:57586  10.3.81.90:57586   17.172.238.213:443 17.172.238.213:443
tcp 99.3.81.66:57589  10.3.81.90:57589   17.167.139.8:443   17.167.139.8:443
tcp 99.3.81.66:57610  10.3.81.90:57610   17.172.238.213:443 17.172.238.213:443
tcp 99.3.81.66:57684  10.3.81.90:57684   65.196.188.58:443  65.196.188.58:443
tcp 99.3.81.66:57698  10.3.81.90:57698   65.196.188.23:443  65.196.188.23:443
tcp 99.3.81.66:57699  10.3.81.90:57699   216.58.219.134:443 216.58.219.134:443
tcp 99.3.81.66:1049   10.3.81.90:57703   65.196.188.25:443  65.196.188.25:443
tcp 99.3.81.66:57717  10.3.81.90:57717   17.167.139.8:443   17.167.139.8:443
tcp 99.3.81.66:57766  10.3.81.90:57766   107.21.213.241:80  107.21.213.241:80
tcp 99.3.81.66:57767  10.3.81.90:57767   107.21.213.241:80  107.21.213.241:80
tcp 99.3.81.66:57777  10.3.81.90:57777   156.63.241.167:80  156.63.241.167:80
tcp 99.3.81.66:57778  10.3.81.90:57778   156.63.241.200:80  156.63.241.200:80
tcp 99.3.81.66:1054   10.3.81.90:57779   23.0.90.177:80     23.0.90.177:80
tcp 99.3.81.66:57780  10.3.81.90:57780   23.0.90.177:80     23.0.90.177:80
tcp 99.3.81.66:57781  10.3.81.90:57781   23.0.90.177:80     23.0.90.177:80
tcp 99.3.81.77:80     10.3.81.92:80      ---                ---
tcp 99.3.81.66:53145  10.3.81.92:53145   184.172.60.194:5938 184.172.60.194:5938
tcp 99.3.81.75:3389   10.3.81.95:3389    222.186.21.92:4580 222.186.21.92:4580
tcp 99.3.81.75:3389   10.3.81.95:3389    ---                ---
tcp 99.3.81.66:61106  10.3.81.95:61106   169.55.36.105:5938 169.55.36.105:5938
tcp 99.3.81.66:55963  10.3.81.97:55963   162.250.2.6:5938   162.250.2.6:5938
tcp 99.3.81.66:56942  10.3.81.98:56942   50.22.136.99:5938  50.22.136.99:5938
udp 99.3.81.66:1174   10.3.81.106:5060   8.28.0.52:5199     8.28.0.52:5199
udp 99.3.81.66:1035   10.3.81.106:5060   8.28.0.168:5199    8.28.0.168:5199
udp 99.3.81.66:1195   10.3.81.106:5060   8.28.0.200:5199    8.28.0.200:5199
udp 99.3.81.66:1034   10.3.81.107:5060   8.28.0.52:5199     8.28.0.52:5199
udp 99.3.81.66:1196   10.3.81.107:5060   8.28.0.200:5199    8.28.0.200:5199
tcp 99.3.81.66:51952  10.3.81.114:51952  50.22.136.116:5938 50.22.136.116:5938
tcp 99.3.81.66:52778  10.3.81.114:52778  96.16.98.27:80     96.16.98.27:80
tcp 99.3.81.66:49710  10.3.81.115:49710  77.234.42.25:80    77.234.42.25:80
tcp 99.3.81.66:49907  10.3.81.115:49907  158.85.77.180:53   158.85.77.180:53
tcp 99.3.81.66:49912  10.3.81.115:49912  158.85.77.180:53   158.85.77.180:53
tcp 99.3.81.66:49934  10.3.81.115:49934  173.234.61.58:53   173.234.61.58:53
tcp 99.3.81.66:50050  10.3.81.115:50050  161.202.108.196:53 161.202.108.196:53
tcp 99.3.81.66:50647  10.3.81.115:50647  31.131.253.228:53  31.131.253.228:53
tcp 99.3.81.66:51097  10.3.81.115:51097  91.221.67.63:53    91.221.67.63:53
tcp 99.3.81.66:51177  10.3.81.115:51177  31.131.253.228:53  31.131.253.228:53
tcp 99.3.81.66:54217  10.3.81.115:54217  5.45.58.149:80     5.45.58.149:80
tcp 99.3.81.66:55565  10.3.81.115:55565  5.45.58.149:80     5.45.58.149:80
tcp 99.3.81.66:56529  10.3.81.115:56529  31.131.253.228:53  31.131.253.228:53
tcp 99.3.81.66:56943  10.3.81.115:56943  31.131.253.229:53  31.131.253.229:53
tcp 99.3.81.66:56947  10.3.81.115:56947  168.1.69.113:53    168.1.69.113:53
tcp 99.3.81.66:57387  10.3.81.115:57387  31.131.253.228:53  31.131.253.228:53
tcp 99.3.81.66:57418  10.3.81.115:57418  158.85.77.182:53   158.85.77.182:53
tcp 99.3.81.66:57435  10.3.81.115:57435  168.1.69.113:53    168.1.69.113:53
tcp 99.3.81.66:57865  10.3.81.115:57865  168.1.69.113:53    168.1.69.113:53
tcp 99.3.81.66:58257  10.3.81.115:58257  91.221.67.63:53    91.221.67.63:53
tcp 99.3.81.66:58750  10.3.81.115:58750  209.95.34.40:53    209.95.34.40:53
tcp 99.3.81.66:59040  10.3.81.115:59040  5.45.58.147:80     5.45.58.147:80
tcp 99.3.81.66:59407  10.3.81.115:59407  62.210.142.144:443 62.210.142.144:443
tcp 99.3.81.66:59430  10.3.81.115:59430  119.81.212.80:53   119.81.212.80:53
tcp 99.3.81.66:59806  10.3.81.115:59806  91.221.67.63:53    91.221.67.63:53
tcp 99.3.81.66:59845  10.3.81.115:59845  31.131.253.229:53  31.131.253.229:53
tcp 99.3.81.66:60247  10.3.81.115:60247  31.131.253.229:53  31.131.253.229:53
tcp 99.3.81.66:60810  10.3.81.115:60810  77.234.42.25:80    77.234.42.25:80
tcp 99.3.81.66:61424  10.3.81.115:61424  23.202.48.149:80   23.202.48.149:80
tcp 99.3.81.66:61430  10.3.81.115:61430  72.21.91.29:80     72.21.91.29:80
tcp 99.3.81.66:57217  10.3.81.116:57217  178.250.0.78:443   178.250.0.78:443
udp 99.3.81.66:1173   10.3.81.117:5060   8.28.0.52:5199     8.28.0.52:5199
udp 99.3.81.66:1029   10.3.81.117:5060   8.28.0.168:5199    8.28.0.168:5199
udp 99.3.81.66:1193   10.3.81.117:5060   8.28.0.200:5199    8.28.0.200:5199
tcp 99.3.81.66:56063  10.3.81.124:56063  77.234.42.26:80    77.234.42.26:80
tcp 99.3.81.66:60201  10.3.81.124:60201  77.234.42.34:80    77.234.42.34:80
tcp 99.3.81.66:62882  10.3.81.124:62882  23.202.3.103:80    23.202.3.103:80
tcp 99.3.81.66:64079  10.3.81.124:64079  77.234.42.26:80    77.234.42.26:80
tcp 99.3.81.66:64150  10.3.81.124:64150  5.45.58.147:80     5.45.58.147:80
tcp 99.3.81.66:1277   10.3.81.126:49408  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:1281   10.3.81.126:49409  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:1279   10.3.81.126:49410  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:1278   10.3.81.126:49411  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:49413  10.3.81.126:49413  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:1282   10.3.81.126:49414  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:1283   10.3.81.126:49415  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:1285   10.3.81.126:49416  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:1284   10.3.81.126:49417  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:49496  10.3.81.126:49496  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:49497  10.3.81.126:49497  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:49498  10.3.81.126:49498  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:49499  10.3.81.126:49499  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:49500  10.3.81.126:49500  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:49501  10.3.81.126:49501  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:50090  10.3.81.126:50090  77.234.42.25:80    77.234.42.25:80
tcp 99.3.81.66:57381  10.3.81.126:57381  91.221.67.63:53    91.221.67.63:53
tcp 99.3.81.66:57437  10.3.81.126:57437  31.131.253.229:53  31.131.253.229:53
tcp 99.3.81.66:1212   10.3.81.126:57439  177.47.27.156:53   177.47.27.156:53
tcp 99.3.81.66:57779  10.3.81.126:57779  169.57.1.214:443   169.57.1.214:443
tcp 99.3.81.66:57849  10.3.81.126:57849  177.47.27.156:53   177.47.27.156:53
tcp 99.3.81.66:32815  10.3.81.129:32815  216.58.219.110:443 216.58.219.110:443
tcp 99.3.81.66:33173  10.3.81.129:33173  31.13.73.1:443     31.13.73.1:443
tcp 99.3.81.66:33252  10.3.81.129:33252  65.196.188.52:80   65.196.188.52:80
tcp 99.3.81.66:33281  10.3.81.129:33281  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:33439  10.3.81.129:33439  96.16.98.27:80     96.16.98.27:80
tcp 99.3.81.66:33513  10.3.81.129:33513  216.58.219.104:443 216.58.219.104:443
tcp 99.3.81.66:33773  10.3.81.129:33773  216.58.219.142:80  216.58.219.142:80
tcp 99.3.81.66:33850  10.3.81.129:33850  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:33944  10.3.81.129:33944  216.58.219.138:443 216.58.219.138:443
tcp 99.3.81.66:34332  10.3.81.129:34332  65.196.188.23:80   65.196.188.23:80
tcp 99.3.81.66:34434  10.3.81.129:34434  54.235.170.63:443  54.235.170.63:443
tcp 99.3.81.66:34495  10.3.81.129:34495  216.58.219.136:443 216.58.219.136:443
tcp 99.3.81.66:34728  10.3.81.129:34728  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:34783  10.3.81.129:34783  74.125.21.95:443   74.125.21.95:443
tcp 99.3.81.66:34957  10.3.81.129:34957  65.196.188.52:80   65.196.188.52:80
tcp 99.3.81.66:34970  10.3.81.129:34970  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:34991  10.3.81.129:34991  23.210.96.211:443  23.210.96.211:443
tcp 99.3.81.66:35344  10.3.81.129:35344  54.241.32.1:443    54.241.32.1:443
tcp 99.3.81.66:35476  10.3.81.129:35476  23.210.96.211:443  23.210.96.211:443
tcp 99.3.81.66:35901  10.3.81.129:35901  65.196.188.52:80   65.196.188.52:80
tcp 99.3.81.66:35928  10.3.81.129:35928  23.202.19.88:443   23.202.19.88:443
tcp 99.3.81.66:35948  10.3.81.129:35948  65.196.188.52:80   65.196.188.52:80
tcp 99.3.81.66:35955  10.3.81.129:35955  54.192.83.244:443  54.192.83.244:443
tcp 99.3.81.66:36008  10.3.81.129:36008  23.0.94.216:443    23.0.94.216:443
tcp 99.3.81.66:36357  10.3.81.129:36357  52.68.186.250:5223 52.68.186.250:5223
tcp 99.3.81.66:36499  10.3.81.129:36499  54.209.172.186:443 54.209.172.186:443
tcp 99.3.81.66:36739  10.3.81.129:36739  216.58.219.138:443 216.58.219.138:443
tcp 99.3.81.66:36740  10.3.81.129:36740  216.58.219.138:443 216.58.219.138:443
tcp 99.3.81.66:36783  10.3.81.129:36783  54.243.93.187:443  54.243.93.187:443
tcp 99.3.81.66:37042  10.3.81.129:37042  31.13.73.1:443     31.13.73.1:443
tcp 99.3.81.66:37208  10.3.81.129:37208  23.21.47.31:443    23.21.47.31:443
tcp 99.3.81.66:37313  10.3.81.129:37313  107.20.243.255:443 107.20.243.255:443
tcp 99.3.81.66:37441  10.3.81.129:37441  216.58.219.136:443 216.58.219.136:443
tcp 99.3.81.66:37532  10.3.81.129:37532  54.239.27.61:443   54.239.27.61:443
tcp 99.3.81.66:37693  10.3.81.129:37693  174.129.0.44:443   174.129.0.44:443
tcp 99.3.81.66:37841  10.3.81.129:37841  65.196.188.55:80   65.196.188.55:80
tcp 99.3.81.66:37868  10.3.81.129:37868  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:37891  10.3.81.129:37891  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:38031  10.3.81.129:38031  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:38041  10.3.81.129:38041  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:38313  10.3.81.129:38313  31.13.73.1:443     31.13.73.1:443
tcp 99.3.81.66:38573  10.3.81.129:38573  74.125.21.188:5228 74.125.21.188:5228
tcp 99.3.81.66:38715  10.3.81.129:38715  65.196.188.59:80   65.196.188.59:80
tcp 99.3.81.66:38803  10.3.81.129:38803  54.239.27.61:443   54.239.27.61:443
tcp 99.3.81.66:38858  10.3.81.129:38858  216.58.219.104:443 216.58.219.104:443
tcp 99.3.81.66:38883  10.3.81.129:38883  52.26.205.202:443  52.26.205.202:443
tcp 99.3.81.66:39003  10.3.81.129:39003  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:39081  10.3.81.129:39081  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:39109  10.3.81.129:39109  107.178.254.148:443 107.178.254.148:443
tcp 99.3.81.66:39295  10.3.81.129:39295  74.125.196.188:5228 74.125.196.188:5228
tcp 99.3.81.66:39516  10.3.81.129:39516  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:39555  10.3.81.129:39555  31.13.66.3:443     31.13.66.3:443
tcp 99.3.81.66:39577  10.3.81.129:39577  216.58.219.138:443 216.58.219.138:443
tcp 99.3.81.66:39658  10.3.81.129:39658  216.58.219.136:443 216.58.219.136:443
tcp 99.3.81.66:39727  10.3.81.129:39727  216.58.219.104:443 216.58.219.104:443
tcp 99.3.81.66:39819  10.3.81.129:39819  31.13.65.7:443     31.13.65.7:443
tcp 99.3.81.66:39820  10.3.81.129:39820  31.13.65.7:443     31.13.65.7:443
tcp 99.3.81.66:40052  10.3.81.129:40052  23.23.184.36:443   23.23.184.36:443
tcp 99.3.81.66:40230  10.3.81.129:40230  52.26.205.202:443  52.26.205.202:443
tcp 99.3.81.66:40519  10.3.81.129:40519  107.178.254.148:443 107.178.254.148:443
tcp 99.3.81.66:41060  10.3.81.129:41060  74.125.196.239:443 74.125.196.239:443
tcp 99.3.81.66:41125  10.3.81.129:41125  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:41289  10.3.81.129:41289  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:41467  10.3.81.129:41467  23.23.158.148:443  23.23.158.148:443
tcp 99.3.81.66:41666  10.3.81.129:41666  74.125.196.188:5228 74.125.196.188:5228
tcp 99.3.81.66:42073  10.3.81.129:42073  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:42102  10.3.81.129:42102  216.58.219.138:443 216.58.219.138:443
tcp 99.3.81.66:42243  10.3.81.129:42243  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:42273  10.3.81.129:42273  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:42324  10.3.81.129:42324  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:42964  10.3.81.129:42964  31.13.73.1:443     31.13.73.1:443
tcp 99.3.81.66:43114  10.3.81.129:43114  23.21.230.199:443  23.21.230.199:443
tcp 99.3.81.66:43390  10.3.81.129:43390  65.196.188.59:80   65.196.188.59:80
tcp 99.3.81.66:43694  10.3.81.129:43694  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:43801  10.3.81.129:43801  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:4499  10.3.81.129:4499  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:44130  10.3.81.129:44130  31.13.73.1:443     31.13.73.1:443
tcp 99.3.81.66:44153  10.3.81.129:44153  23.210.121.59:443  23.210.121.59:443
tcp 99.3.81.66:44276  10.3.81.129:44276  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:44411  10.3.81.129:44411  54.235.104.161:443 54.235.104.161:443
tcp 99.3.81.66:44479  10.3.81.129:44479  107.23.227.176:443 107.23.227.176:443
tcp 99.3.81.66:44536  10.3.81.129:44536  216.58.219.104:443 216.58.219.104:443
tcp 99.3.81.66:44816  10.3.81.129:44816  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:44908  10.3.81.129:44908  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:45028  10.3.81.129:45028  107.178.254.148:443 107.178.254.148:443
tcp 99.3.81.66:45281  10.3.81.129:45281  65.196.188.21:80   65.196.188.21:80
tcp 99.3.81.66:45338  10.3.81.129:45338  23.210.121.59:443  23.210.121.59:443
tcp 99.3.81.66:45496  10.3.81.129:45496  173.194.219.95:443 173.194.219.95:443
tcp 99.3.81.66:45604  10.3.81.129:45604  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:45781  10.3.81.129:45781  216.58.219.165:443 216.58.219.165:443
tcp 99.3.81.66:45795  10.3.81.129:45795  54.164.122.218:443 54.164.122.218:443
tcp 99.3.81.66:46542  10.3.81.129:46542  23.21.109.20:443   23.21.109.20:443
tcp 99.3.81.66:46638  10.3.81.129:46638  216.58.219.142:80  216.58.219.142:80
tcp 99.3.81.66:46851  10.3.81.129:46851  31.13.73.1:443     31.13.73.1:443
tcp 99.3.81.66:47173  10.3.81.129:47173  174.129.38.36:443  174.129.38.36:443
tcp 99.3.81.66:47454  10.3.81.129:47454  52.68.186.250:5223 52.68.186.250:5223
tcp 99.3.81.66:47533  10.3.81.129:47533  31.13.65.3:443     31.13.65.3:443
tcp 99.3.81.66:47710  10.3.81.129:47710  216.58.192.65:80   216.58.192.65:80
tcp 99.3.81.66:47883  10.3.81.129:47883  216.58.219.138:443 216.58.219.138:443
tcp 99.3.81.66:48142  10.3.81.129:48142  54.243.92.40:443   54.243.92.40:443
tcp 99.3.81.66:48160  10.3.81.129:48160  23.202.94.216:443  23.202.94.216:443
tcp 99.3.81.66:48273  10.3.81.129:48273  54.221.205.146:443 54.221.205.146:443
tcp 99.3.81.66:48309  10.3.81.129:48309  23.0.94.216:443    23.0.94.216:443
tcp 99.3.81.66:48417  10.3.81.129:48417  52.5.75.111:443    52.5.75.111:443
tcp 99.3.81.66:48780  10.3.81.129:48780  216.58.192.72:443  216.58.192.72:443
tcp 99.3.81.66:49039  10.3.81.129:49039  173.194.219.95:443 173.194.219.95:443
tcp 99.3.81.66:49296  10.3.81.129:49296  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:49669  10.3.81.129:49669  23.210.121.59:443  23.210.121.59:443
tcp 99.3.81.66:49786  10.3.81.129:49786  65.196.188.20:80   65.196.188.20:80
tcp 99.3.81.66:49881  10.3.81.129:49881  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:50591  10.3.81.129:50591  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:50593  10.3.81.129:50593  107.23.111.105:443 107.23.111.105:443
tcp 99.3.81.66:50689  10.3.81.129:50689  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:50742  10.3.81.129:50742  23.210.121.59:443  23.210.121.59:443
tcp 99.3.81.66:50757  10.3.81.129:50757  65.196.188.23:80   65.196.188.23:80
tcp 99.3.81.66:51139  10.3.81.129:51139  107.21.251.167:443 107.21.251.167:443
tcp 99.3.81.66:51173  10.3.81.129:51173  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:51270  10.3.81.129:51270  23.202.19.88:443   23.202.19.88:443
tcp 99.3.81.66:51366  10.3.81.129:51366  216.58.192.72:443  216.58.192.72:443
tcp 99.3.81.66:51523  10.3.81.129:51523  107.178.254.148:443 107.178.254.148:443
tcp 99.3.81.66:51864  10.3.81.129:51864  65.196.188.26:80   65.196.188.26:80
tcp 99.3.81.66:51990  10.3.81.129:51990  23.202.19.88:443   23.202.19.88:443
tcp 99.3.81.66:52086  10.3.81.129:52086  173.194.219.95:443 173.194.219.95:443
tcp 99.3.81.66:1422   10.3.81.129:52205  74.125.21.95:443   74.125.21.95:443
tcp 99.3.81.66:52238  10.3.81.129:52238  31.13.73.3:443     31.13.73.3:443
tcp 99.3.81.66:52283  10.3.81.129:52283  31.13.73.1:443     31.13.73.1:443
tcp 99.3.81.66:52744  10.3.81.129:52744  216.58.219.104:443 216.58.219.104:443
tcp 99.3.81.66:52803  10.3.81.129:52803  52.5.58.109:443    52.5.58.109:443
tcp 99.3.81.66:52858  10.3.81.129:52858  96.16.98.27:80     96.16.98.27:80
tcp 99.3.81.66:53009  10.3.81.129:53009  216.58.219.130:443 216.58.219.130:443
tcp 99.3.81.66:53070  10.3.81.129:53070  23.210.96.211:443  23.210.96.211:443
tcp 99.3.81.66:53133  10.3.81.129:53133  174.129.0.44:443   174.129.0.44:443
tcp 99.3.81.66:53141  10.3.81.129:53141  31.13.73.1:443     31.13.73.1:443
tcp 99.3.81.66:53334  10.3.81.129:53334  65.196.188.52:80   65.196.188.52:80
tcp 99.3.81.66:53391  10.3.81.129:53391  173.194.219.95:443 173.194.219.95:443
tcp 99.3.81.66:53627  10.3.81.129:53627  216.58.219.104:443 216.58.219.104:443
tcp 99.3.81.66:53760  10.3.81.129:53760  216.58.219.129:443 216.58.219.129:443
tcp 99.3.81.66:54343  10.3.81.129:54343  216.58.219.129:443 216.58.219.129:443
tcp 99.3.81.66:54354  10.3.81.129:54354  216.58.192.110:443 216.58.192.110:443
tcp 99.3.81.66:54411  10.3.81.129:54411  23.21.230.199:443  23.21.230.199:443
tcp 99.3.81.66:54414  10.3.81.129:54414  216.58.219.110:443 216.58.219.110:443
tcp 99.3.81.66:54561  10.3.81.129:54561  96.16.98.27:80     96.16.98.27:80
tcp 99.3.81.66:54925  10.3.81.129:54925  74.125.21.141:443  74.125.21.141:443
tcp 99.3.81.66:55278  10.3.81.129:55278  173.194.219.95:443 173.194.219.95:443
tcp 99.3.81.66:55709  10.3.81.129:55709  23.0.94.216:443    23.0.94.216:443
tcp 99.3.81.66:55785  10.3.81.129:55785  23.210.96.211:443  23.210.96.211:443
tcp 99.3.81.66:56233  10.3.81.129:56233  31.13.65.52:80     31.13.65.52:80
tcp 99.3.81.66:56869  10.3.81.129:56869  54.239.23.120:443  54.239.23.120:443
tcp 99.3.81.66:56932  10.3.81.129:56932  74.125.196.239:443 74.125.196.239:443
tcp 99.3.81.66:57064  10.3.81.129:57064  96.16.98.27:80     96.16.98.27:80
tcp 99.3.81.66:57235  10.3.81.129:57235  31.13.73.1:443     31.13.73.1:443
tcp 99.3.81.66:57285  10.3.81.129:57285  65.196.188.52:80   65.196.188.52:80
tcp 99.3.81.66:57362  10.3.81.129:57362  52.22.91.5:443     52.22.91.5:443
tcp 99.3.81.66:57666  10.3.81.129:57666  54.192.83.102:443  54.192.83.102:443
tcp 99.3.81.66:58190  10.3.81.129:58190  74.125.21.95:443   74.125.21.95:443
tcp 99.3.81.66:58199  10.3.81.129:58199  31.13.65.3:443     31.13.65.3:443
tcp 99.3.81.66:58305  10.3.81.129:58305  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:58352  10.3.81.129:58352  107.178.254.148:443 107.178.254.148:443
tcp 99.3.81.66:58480  10.3.81.129:58480  54.243.190.199:443 54.243.190.199:443
tcp 99.3.81.66:58496  10.3.81.129:58496  65.196.188.52:80   65.196.188.52:80
tcp 99.3.81.66:58532  10.3.81.129:58532  107.23.45.105:443  107.23.45.105:443
tcp 99.3.81.66:58644  10.3.81.129:58644  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:58713  10.3.81.129:58713  31.13.65.3:443     31.13.65.3:443
tcp 99.3.81.66:58762  10.3.81.129:58762  23.0.94.216:443    23.0.94.216:443
tcp 99.3.81.66:59115  10.3.81.129:59115  216.58.192.78:443  216.58.192.78:443
tcp 99.3.81.66:59121  10.3.81.129:59121  23.210.121.59:443  23.210.121.59:443
tcp 99.3.81.66:59205  10.3.81.129:59205  23.235.46.143:443  23.235.46.143:443
tcp 99.3.81.66:59312  10.3.81.129:59312  74.125.138.188:5228 74.125.138.188:5228
tcp 99.3.81.66:59339  10.3.81.129:59339  23.210.96.211:443  23.210.96.211:443
tcp 99.3.81.66:60261  10.3.81.129:60261  23.210.121.59:443  23.210.121.59:443
tcp 99.3.81.66:60392  10.3.81.129:60392  54.239.20.197:443  54.239.20.197:443
tcp 99.3.81.66:60465  10.3.81.129:60465  54.174.26.102:443  54.174.26.102:443
tcp 99.3.81.66:60480  10.3.81.129:60480  23.202.26.179:443  23.202.26.179:443
tcp 99.3.81.66:49408  10.3.81.133:49408  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:49409  10.3.81.133:49409  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:49412  10.3.81.133:49412  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:1445   10.3.81.133:49413  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:49414  10.3.81.133:49414  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:49415  10.3.81.133:49415  23.210.103.156:443 23.210.103.156:443
tcp 99.3.81.66:49416  10.3.81.133:49416  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:49417  10.3.81.133:49417  23.210.103.156:443 23.210.103.156:443
tcp 99.3.81.66:49418  10.3.81.133:49418  23.210.103.156:443 23.210.103.156:443
tcp 99.3.81.66:49419  10.3.81.133:49419  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:49423  10.3.81.133:49423  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:64043  10.3.81.133:64043  72.21.81.200:80    72.21.81.200:80
tcp 99.3.81.66:54605  10.3.81.134:54605  23.74.2.66:80      23.74.2.66:80
tcp 99.3.81.66:54610  10.3.81.134:54610  72.21.81.200:443   72.21.81.200:443
tcp 99.3.81.66:54645  10.3.81.134:54645  65.196.188.59:443  65.196.188.59:443
tcp 99.3.81.66:54702  10.3.81.134:54702  184.73.152.154:80  184.73.152.154:80
tcp 99.3.81.66:54703  10.3.81.134:54703  192.173.28.130:80  192.173.28.130:80
tcp 99.3.81.66:57524  10.3.81.134:57524  65.196.188.55:443  65.196.188.55:443
tcp 99.3.81.66:60155  10.3.81.134:60155  52.3.246.198:443   52.3.246.198:443
tcp 99.3.81.66:60157  10.3.81.134:60157  52.3.246.198:443   52.3.246.198:443
tcp 99.3.81.66:60159  10.3.81.134:60159  52.3.246.198:443   52.3.246.198:443
tcp 99.3.81.66:60193  10.3.81.134:60193  65.196.188.26:443  65.196.188.26:443
tcp 99.3.81.66:60354  10.3.81.134:60354  65.196.188.24:443  65.196.188.24:443
tcp 99.3.81.66:60384  10.3.81.134:60384  54.225.146.155:80  54.225.146.155:80
tcp 99.3.81.66:60391  10.3.81.134:60391  38.127.167.50:443  38.127.167.50:443
tcp 99.3.81.66:61383  10.3.81.134:61383  52.91.95.187:443   52.91.95.187:443
tcp 99.3.81.66:61387  10.3.81.134:61387  52.91.95.187:443   52.91.95.187:443
tcp 99.3.81.66:51166  10.3.81.135:51166  17.172.238.31:5223 17.172.238.31:5223
tcp 99.3.81.66:51372  10.3.81.135:51372  17.167.142.39:443  17.167.142.39:443
tcp 99.3.81.66:51444  10.3.81.135:51444  74.125.21.108:993  74.125.21.108:993
tcp 99.3.81.66:51445  10.3.81.135:51445  98.138.13.27:993   98.138.13.27:993
tcp 99.3.81.66:51446  10.3.81.135:51446  98.138.13.27:993   98.138.13.27:993
tcp 99.3.81.66:51447  10.3.81.135:51447  98.138.74.46:993   98.138.74.46:993
tcp 99.3.81.66:51449  10.3.81.135:51449  98.138.74.43:993   98.138.74.43:993
tcp 99.3.81.66:51450  10.3.81.135:51450  98.138.74.43:993   98.138.74.43:993
tcp 99.3.81.66:51451  10.3.81.135:51451  17.172.99.58:443  17.172.99.58:443
tcp 99.3.81.66:52174  10.3.81.135:52174  17.249.153.246:443 17.249.153.246:443
tcp 99.3.81.66:52176  10.3.81.135:52176  17.249.153.246:443 17.249.153.246:443
tcp 99.3.81.66:52177  10.3.81.135:52177  17.249.153.246:443 17.249.153.246:443
tcp 99.3.81.66:52178  10.3.81.135:52178  17.249.153.246:443 17.249.153.246:443
tcp 99.3.81.66:52180  10.3.81.135:52180  216.58.192.110:443 216.58.192.110:443
tcp 99.3.81.66:52184  10.3.81.135:52184  17.172.238.12:5223 17.172.238.12:5223
tcp 99.3.81.66:52186  10.3.81.135:52186  65.196.188.52:443  65.196.188.52:443
tcp 99.3.81.66:52188  10.3.81.135:52188  216.58.192.99:443  216.58.192.99:443
tcp 99.3.81.66:52189  10.3.81.135:52189  216.58.219.98:443  216.58.219.98:443
tcp 99.3.81.66:52521  10.3.81.135:52521  17.143.164.158:443 17.143.164.158:443
udp 99.3.81.66:49155  10.3.81.137:49155  10.1.10.253:161    10.1.10.253:161
tcp 99.3.81.66:61894  10.3.81.140:61894  162.220.222.142:5938 162.220.222.142:5938
tcp 99.3.81.66:3745   10.3.81.142:3745   144.2.1.1:443      144.2.1.1:443
tcp 99.3.81.66:3803   10.3.81.142:3803   144.2.0.1:443      144.2.0.1:443
tcp 99.3.81.66:16000  10.3.81.142:16000  108.174.10.10:443  108.174.10.10:443
tcp 99.3.81.66:16313  10.3.81.142:16313  103.20.93.133:443  103.20.93.133:443
tcp 99.3.81.66:16356  10.3.81.142:16356  144.2.1.1:443      144.2.1.1:443
tcp 99.3.81.66:16357  10.3.81.142:16357  144.2.0.1:443      144.2.0.1:443
tcp 99.3.81.66:16358  10.3.81.142:16358  103.20.93.133:443  103.20.93.133:443
tcp 99.3.81.66:16359  10.3.81.142:16359  103.20.94.1:443    103.20.94.1:443
tcp 99.3.81.66:16516  10.3.81.142:16516  144.2.1.1:443      144.2.1.1:443
tcp 99.3.81.66:16572  10.3.81.142:16572  144.2.1.1:443      144.2.1.1:443
tcp 99.3.81.66:16573  10.3.81.142:16573  144.2.0.1:443      144.2.0.1:443
tcp 99.3.81.66:16574  10.3.81.142:16574  108.174.11.1:443   108.174.11.1:443
tcp 99.3.81.66:16575  10.3.81.142:16575  185.63.144.1:443   185.63.144.1:443
tcp 99.3.81.66:16576  10.3.81.142:16576  108.174.12.129:443 108.174.12.129:443
tcp 99.3.81.66:16577  10.3.81.142:16577  103.20.93.133:443  103.20.93.133:443
tcp 99.3.81.66:16578  10.3.81.142:16578  91.225.248.133:443 91.225.248.133:443
tcp 99.3.81.66:16579  10.3.81.142:16579  103.20.94.1:443    103.20.94.1:443
tcp 99.3.81.66:16580  10.3.81.142:16580  108.174.5.133:443  108.174.5.133:443
tcp 99.3.81.66:16581  10.3.81.142:16581  108.174.2.133:443  108.174.2.133:443
tcp 99.3.81.66:16582  10.3.81.142:16582  199.101.163.133:443 199.101.163.133:443
tcp 99.3.81.66:16583  10.3.81.142:16583  108.174.10.10:443  108.174.10.10:443
tcp 99.3.81.66:17474  10.3.81.142:17474  103.20.94.1:443    103.20.94.1:443
tcp 99.3.81.66:50455  10.3.81.145:50455  209.58.129.81:5938 209.58.129.81:5938
tcp 99.3.81.66:54473  10.3.81.150:54473  173.194.219.188:5228 173.194.219.188:5228
tcp 99.3.81.66:57609  10.3.81.150:57609  38.127.167.48:443  38.127.167.48:443
tcp 99.3.81.66:57703  10.3.81.150:57703  132.245.68.210:443 132.245.68.210:443
udp 99.3.81.66:59621  10.3.81.150:59621  99.3.80.4:58995   99.3.80.4:58995
tcp 99.3.81.66:61666  10.3.81.150:61666  132.245.16.242:443 132.245.16.242:443
tcp 99.3.81.66:61687  10.3.81.150:61687  132.245.81.162:443 132.245.81.162:443
tcp 99.3.81.66:61705  10.3.81.150:61705  132.245.38.194:443 132.245.38.194:443
tcp 99.3.81.66:61875  10.3.81.150:61875  132.245.44.226:443 132.245.44.226:443
tcp 99.3.81.66:61887  10.3.81.150:61887  132.245.48.50:443  132.245.48.50:443
tcp 99.3.81.66:61891  10.3.81.150:61891  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:61892  10.3.81.150:61892  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:61893  10.3.81.150:61893  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:1055   10.3.81.150:61894  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:61895  10.3.81.150:61895  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:61896  10.3.81.150:61896  132.245.3.210:443  132.245.3.210:443
tcp 99.3.81.66:61900  10.3.81.150:61900  132.245.71.18:443  132.245.71.18:443
tcp 99.3.81.66:61901  10.3.81.150:61901  40.96.8.2:443      40.96.8.2:443
tcp 99.3.81.66:61902  10.3.81.150:61902  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:61903  10.3.81.150:61903  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:61904  10.3.81.150:61904  132.245.113.33:443 132.245.113.33:443
tcp 99.3.81.66:61905  10.3.81.150:61905  38.127.167.48:443  38.127.167.48:443
tcp 99.3.81.66:61906  10.3.81.150:61906  65.55.44.109:443   65.55.44.109:443
tcp 99.3.81.66:61907  10.3.81.150:61907  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:61908  10.3.81.150:61908  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:61909  10.3.81.150:61909  38.127.167.50:443  38.127.167.50:443
tcp 99.3.81.66:61914  10.3.81.150:61914  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:61915  10.3.81.150:61915  50.22.136.104:80   50.22.136.104:80
tcp 99.3.81.66:64961  10.3.81.150:64961  192.241.163.235:443 192.241.163.235:443
tcp 99.3.81.66:51980  10.3.81.151:51980  23.56.231.61:443   23.56.231.61:443
tcp 99.3.81.66:51981  10.3.81.151:51981  23.56.231.61:443   23.56.231.61:443
tcp 99.3.81.66:52000  10.3.81.151:52000  23.56.231.61:443   23.56.231.61:443
tcp 99.3.81.66:52001  10.3.81.151:52001  23.56.231.61:443   23.56.231.61:443
udp 99.3.81.66:1172   10.3.81.152:5060   8.28.0.52:5199     8.28.0.52:5199
udp 99.3.81.66:1030   10.3.81.152:5060   8.28.0.168:5199    8.28.0.168:5199
udp 99.3.81.66:1194   10.3.81.152:5060   8.28.0.200:5199    8.28.0.200:5199
tcp 99.3.81.66:49761  10.3.81.153:49761  94.46.159.11:443   94.46.159.11:443
tcp 99.3.81.66:49944  10.3.81.153:49944  206.190.152.176:443 206.190.152.176:443
tcp 99.3.81.66:49945  10.3.81.153:49945  65.196.188.55:443  65.196.188.55:443
tcp 99.3.81.66:49968  10.3.81.153:49968  65.196.188.23:443  65.196.188.23:443
tcp 99.3.81.66:49970  10.3.81.153:49970  174.129.252.106:80 174.129.252.106:80
tcp 99.3.81.66:49974  10.3.81.153:49974  192.229.163.187:443 192.229.163.187:443
tcp 99.3.81.66:50030  10.3.81.153:50030  216.58.192.66:443  216.58.192.66:443
tcp 99.3.81.66:50040  10.3.81.153:50040  65.196.188.52:443  65.196.188.52:443
tcp 99.3.81.66:50061  10.3.81.153:50061  23.4.43.27:80      23.4.43.27:80
tcp 99.3.81.66:50070  10.3.81.153:50070  184.50.232.73:80   184.50.232.73:80
tcp 99.3.81.66:50085  10.3.81.153:50085  23.4.43.27:80      23.4.43.27:80
tcp 99.3.81.66:50107  10.3.81.153:50107  206.190.152.176:443 206.190.152.176:443
tcp 99.3.81.66:50133  10.3.81.153:50133  206.190.152.176:443 206.190.152.176:443
tcp 99.3.81.66:50134  10.3.81.153:50134  206.190.152.176:443 206.190.152.176:443
tcp 99.3.81.66:50135  10.3.81.153:50135  206.190.152.176:443 206.190.152.176:443
tcp 99.3.81.66:50136  10.3.81.153:50136  206.190.152.176:443 206.190.152.176:443
tcp 99.3.81.66:54408  10.3.81.153:54408  65.196.188.52:443  65.196.188.52:443
tcp 99.3.81.66:54909  10.3.81.153:54909  128.121.22.145:443 128.121.22.145:443
tcp 99.3.81.66:55742  10.3.81.153:55742  52.3.246.198:443   52.3.246.198:443
tcp 99.3.81.66:55779  10.3.81.153:55779  52.91.117.111:443  52.91.117.111:443
tcp 99.3.81.66:55800  10.3.81.153:55800  52.3.246.198:443   52.3.246.198:443
tcp 99.3.81.66:57257  10.3.81.153:57257  65.196.188.52:443  65.196.188.52:443
tcp 99.3.81.66:57876  10.3.81.153:57876  128.121.22.145:443 128.121.22.145:443
tcp 99.3.81.66:60909  10.3.81.153:60909  192.173.28.130:80  192.173.28.130:80
tcp 99.3.81.66:61113  10.3.81.153:61113  216.58.192.98:443  216.58.192.98:443
tcp 99.3.81.66:61114  10.3.81.153:61114  69.172.216.55:443  69.172.216.55:443
tcp 99.3.81.66:61117  10.3.81.153:61117  23.210.122.141:443 23.210.122.141:443
tcp 99.3.81.66:61118  10.3.81.153:61118  23.210.122.141:443 23.210.122.141:443
tcp 99.3.81.66:61123  10.3.81.153:61123  199.166.0.200:443  199.166.0.200:443
tcp 99.3.81.66:61124  10.3.81.153:61124  69.172.216.111:443 69.172.216.111:443
tcp 99.3.81.66:61130  10.3.81.153:61130  216.58.192.98:80   216.58.192.98:80
tcp 99.3.81.66:61139  10.3.81.153:61139  52.5.151.22:80     52.5.151.22:80
tcp 99.3.81.66:61148  10.3.81.153:61148  69.172.216.58:443  69.172.216.58:443
tcp 99.3.81.66:61152  10.3.81.153:61152  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:61153  10.3.81.153:61153  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:61154  10.3.81.153:61154  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:61155  10.3.81.153:61155  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:61972  10.3.81.153:61972  65.196.188.27:443  65.196.188.27:443
tcp 99.3.81.66:62047  10.3.81.153:62047  128.121.22.145:443 128.121.22.145:443
tcp 99.3.81.66:62121  10.3.81.153:62121  23.210.103.156:80  23.210.103.156:80
tcp 99.3.81.66:62122  10.3.81.153:62122  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:62123  10.3.81.153:62123  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:62124  10.3.81.153:62124  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:62125  10.3.81.153:62125  23.14.84.64:80     23.14.84.64:80
tcp 99.3.81.66:62126  10.3.81.153:62126  23.14.84.49:80     23.14.84.49:80
tcp 99.3.81.66:62128  10.3.81.153:62128  192.229.163.187:443 192.229.163.187:443
tcp 99.3.81.66:62144  10.3.81.153:62144  52.91.49.168:443   52.91.49.168:443
tcp 99.3.81.66:199   10.3.81.154:50593  17.172.232.176:5223 17.172.232.176:5223
tcp 99.3.81.66:51137  10.3.81.156:51137  52.72.25.190:443   52.72.25.190:443
tcp 99.3.81.66:51138  10.3.81.156:51138  107.20.189.185:443 107.20.189.185:443
tcp 99.3.81.66:51363  10.3.81.156:51363  54.235.163.171:443 54.235.163.171:443
tcp 99.3.81.66:51391  10.3.81.156:51391  23.23.161.99:443  23.23.161.99:443
tcp 99.3.81.66:51409  10.3.81.156:51409  52.72.25.190:443   52.72.25.190:443
tcp 99.3.81.66:51504  10.3.81.156:51504  52.72.25.190:443   52.72.25.190:443
tcp 99.3.81.66:60468  10.3.81.156:60468  54.235.163.171:443 54.235.163.171:443
tssrouter#
