Static NAT
Ethan55
Hi all guys,
I have a simple static NAT config.
Topo
Client (f0/1) ----192.168.0.0/24----(f0/1)R1(f0/0)----200.0.0.0/24----(f0/0)R2
IP addresses
IP Client:
f0/1: 192.168.0.10/24
IP R1:
f0/1: 192.168.0.1/24
f0/0: 200.0.0.1/24
IP R2:
f0/0: 200.0.0.10/24
Config
Client:
ip route 0.0.0.0 0.0.0.0 192.168.0.1
R1:
interface FastEthernet0/1
ip nat inside
interface FastEthernet0/0
ip nat outside
Question
If I config static NAT on R1 like below:
ip nat inside source static 192.168.0.10 200.0.0.1
or
ip nat inside source static 192.168.0.10 interface f0/0
I can ping from client to 200.0.0.10 successfully.
But if I config static NAT on R1 like below:
ip nat inside source static 192.168.0.10 200.0.0.2
I can't ping from client to 200.0.0.10 successfully. R1 doesn't forward ICMP reply from R2 to Client.
Please give me some suggestions.
Thank you.
tituscs
This should work normally ,
Do you see NAT translations on R1 ?
Do you see ARP for 200.0.0.2 on R2 ?
6 Replies 6
tituscs
Hi Tituscs,
I delete all config and re-config again and it works normally.
R1#show ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 200.0.0.2:3 192.168.0.10:3 200.0.0.10:3 200.0.0.10:3
icmp 200.0.0.2:4 192.168.0.10:4 200.0.0.10:4 200.0.0.10:4
--- 200.0.0.2 192.168.0.10 --- ---
R2#show ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 200.0.0.1 4 c207.2bf8.0000 ARPA FastEthernet0/0
Internet 200.0.0.2 2 c207.2bf8.0000 ARPA FastEthernet0/0
Internet 200.0.0.10 - c208.2ab4.0000 ARPA FastEthernet0/0
You are doing a static NAT to interface f0/0 of R1. I don't think you could make that work unless you were doing an overload, and then that would only allow outbound. Assuming nothing else is occupying 200.0.0.2, trying using that as the outside address for the static.
Hi Elliot,
I don't know why but I deleted all config and re-config again and it works normally.
Hello
Do the rtr's have any static routing, as from youve decribed they dont require any and it should work.
Please post the following of the rtrs
sh run
sh ip aliases
sh arp
Kind Regards
Paul
Hi Paul,
This is all config.
Client#show running-config
hostname Client
ip address 192.168.0.10 255.255.255.0
duplex auto
speed auto
R1#show running-config
hostname R1
ip address 200.0.0.1 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
R2#show running-config
hostname R2
ip address 200.0.0.10 255.255.255.0
duplex auto
speed auto
