Static nat
ziziahmed9
Hy everyone
Please I have problem with cisco router
I configured static nat on router , when I run show ip nat transactions,  the internal and external addresses that I configure appear but when capture packets outside the source ip doesn't translated ?
Thank
21 Replies 21
Ok thank you very much.  I will check
Unfortunately , the problem persists when I capture icmp packet in interface that I ping , I find that address hasn't been translated
ziziahmed9
Is there other suggestion to resolve this problem?
there are many types of NAT and these type can work simultaneous AND some not work
NAT 1:1 using One IP outside interface can not work with dynamic NAT using same interface <<- this I think your case
PAT 1:1 using port NATing to one IP outside interface can work with dynamic NAT using same interface
solution I think
ip nat inside source static icmp <ip><ip>
ip nat inside source list 1 interface <x> overload
Should I remove dynamic NAT configs?
Hello
If your static nat is not working, did you ammed the NAT ACL ( as I suggested) to deny that host from being dynamically translated?
Kind Regards
Paul
Me when I use static NAT I remove all configurations that are related with dynamic NAT.
