Static Network Route
DoubleTapNY
I need your help,
I am setting up a basic static route between two routers.  The pc's cannot ping each other.
  • PC1 can ping Router 1 and Router 2
  • PC2 can ping Router 2 and Router 1
WireShark on PC 1 sees the ping requests from PC 2, but PC1 does not reply.
WireShark on PC 2 sees the ping requests from PC 1, but PC2 does not reply.
PC1 10.10.10.1/24  gateway 10.10.10.2
PC2 10.10.20.1/24  gateway 10.10.20.2
Router 1 static route 10.10.20.0 255.255.255.0 10.10.200.2
Router 2 static route 10.10.10.0 255.255.255.0 10.10.200.1
Same situation even if I set Router 1's gateway of last resort to 0.0.0.0 0.0.0.0 10.10.200.2
Same situation even if I set Router 2's gateway of last resort to 0.0.0.0 0.0.0.0 10.10.200.1
9 Replies 9
luis_cordova
Hi @DoubleTapNY ,
Check that the PC's firewalls are down, since this will block the external network's ping.
balaji.bandi
If the sw 10.10.10.2  can ping 10.10.20.2 vice versa, as suggested new windows 7X  onwards have build in FW, disable that FW and try again and advise.
BB
Using Ubuntu 18.04
Ubuntu 18.04 has the firewall on by default. Thank you so much for your suggestion and link.
Hi @DoubleTapNY ,
I'm glad you could have solved your problem.
I congratulate you for your desire to learn.
If you have another question, just post it in the community.
If you using Linux :
Please post ifconfig output
try below command
#iptables -F
ping and advise
BB
Jaderson Pessoa
@DoubleTapNY  hello,
I suggest test from each router if they can ping on gateways
step 1: from r1: ping 10.10.20.2    (if ok, go step 2)
step 2: from pc 1 ping own gateway and do the same for pc 2
PC1: ping 10.10.10.2
PC2: ping 10.10.20.2
If all results ok, check firewall on PC's
Obs: Certified that there arent any acl on switch blocking traffic either.
Thanks in advance
Jaderson Pessoa
*** Rate All Helpful Responses ***
DoubleTapNY
Thank you all for your help!  It was the firewall.  I didn't realize Ubuntu 18.04 had the firewall on by default.  Turned it off and everything pings like it should.
DoubleTapNY
