04-10-2008 07:44 AM - edited 03-03-2019 09:30 PM
I have a VPn on my Cisco ASA firewall. I used the VPN wizard to create it, but it didn't work until I added a static route to the ASA.
Remote network is 172.16.1.0/24
I added:
route outside 172.19.15.0 255.255.255.0 Internet_Router 1
Which worked, but I also removed this and added:
route outside 172.19.15.0 255.255.255.0 1.2.3.4 1
Now 1.2.3.4 is the peer address of the remote router, which one is best to use? point to our internet router to find the remote network or point that traffic straight to the remote router for the VPN?
04-10-2008 09:02 AM
is the preferred one. As it is direct next hop to ASA.
hth
thank you
MS
04-10-2008 12:30 PM
In static routing you point your traffic to the next hop IP, or on the router it can be the outbound interface.
