Static Route
% 192.168.3.0 overlaps with FastEthernet0/0Routing, Other Routers
https://www.solarwinds.com/free-tools/advanced-subnet-calculator#subnetcalculator . Does it work any lab?
I am so confused this lab. I do not know how to ping all router, and the end device
2 Accepted Solutions
Hello
Try the following:
R1
ip route 192.168.23.0 255.255.255.0 eth0/1 192.168.12.2
ip route 192.168.3.0 255.255.255.0 eth0/1 192.168.12.2
R2
ip route 192.168.1.0 255.255.255.0 eth0/0 192.168.12.1
ip route 192.168.3.0 255.255.255.0 eth0/1 192.168.23.3
R3
ip route 192.168.12.0 255.255.255.0 eth0/0 192.168.23.2
ip route 192.168.1.0 255.255.255.0 eth0/0 192.168.23.2
Kind Regards
Paul
there is no information whatsoever given regarding loopbacks, except for R2. So on R1 and R3, it can be anything. What lab is that, what instructions are you following ?
That said, you could further minimize the amount of static routes by using just default routes on R1 and R3:
R1
ip route 0.0.0.0 0.0.0.0 192.168.12.2
R2
interface Loopback0
ip address 192.168.2.2 255.255.255.0
ip route 192.168.1.0 255.255.255.0 192.168.12.1
ip route 192.168.3.0 255.255.255.0 192.168.23.3
R3
ip route 0.0.0.0 0.0.0.0 192.168.23.2
5 Replies 5
Hello
Try the following:
R1
R2
R3
Kind Regards
Paul
I wonder know the loopback for r1 r3
R1
R2
interface Loopback0
R3
this lab is from the instructor Duy Long. I am learning CCNA from the Vietnamese school. I sometimes confuse some lesson in the class. I ask it. This one will work in the real world
R1
R2
interface Loopback0
R3
Thank you so much. I appreciate all of your help. I learned so much from you.
