Static Routing options
                   What advantage the below mentioned command offers over the normal static routing command pointing to next hop ip address.
ip route <Destination address> <netmask> exit_interface <nexthop address>
blau grana
Level 11
Level 11
Did you read this article?
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800ef7b2.shtml
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 11
Level 11
Best Regards
in addition to the Cisco document provided by blau grana, here's a similar discussion:
https://supportforums.cisco.com/message/3990076
Hope that helps
Rolf
ip route exit_interface
any destination that doesn't exist in your network and its availabe on ip that is next hope is pingable
mean in your netwrok u have to reach 192.168.100.x network which is not availabe locally but availabe on next hope so u can add route for it
ip route 192.168.100.0 255.255.255.0 (next hope which has this network is) 192.168.5.1
Jawad
Jawad
Hi Blau,
the link which you provided was very usefull...... I got to know the reason.
thanks.
