Static Routing - problem with ping
superfraktal
Good morning,
I'm new to networks and I've created this topology [attachment].
On R1 "ping 4.4.4.4" / "ping 4.4.4.4 source 1.1.1.1" doesn't work.
Any tip why? What am I missing?
R1
ip route 4.4.4.4 255.255.255.255 e0/0
ip route 4.4.4.4 255.255.255.255 s1/0
R2
ip route 1.1.1.1 255.255.255.255 e0/0
ip route 4.4.4.4 255.255.255.255 e0/1
R3
ip route 1.1.1.1 255.255.255.255 s1/0 13.13.13.1
ip route 4.4.4.4 255.255.255.255 e0/0 34.34.34.4
R4
ip route 1.1.1.1 255.255.255.255 e0/1
R1
e0/0 12.12.12.1 up/up
s1/0 13.13.13.1 up/up
loop1 1.1.1.1 up/up
R2
e0/0 12.12.12.2 up/up
e0/1 24.24.24.2 up/up
loop1 2.2.2.2 up/up
R3
e0/0 34.34.34.3 up/up
s1/0 13.13.13.3 up/up
loop1 3.3.3.3 up/up
R4
e0/0 34.34.34.4 up/up
e0/1 24.24.24.4 up/up
loop1 4.4.4.4 up/up
Julio E. Moisa
I think the other members have provided very good explanations and how to fix the problem, well I would like to provide my point of view:
In order to reach the IP 4.4.4.4 from R1 you have 2 path, through R2 or R3, static route is the most easy way for routing but it is complex to manage when you have a large network.
Now if you want to reach the R4's IP through R4, you should have the following configured:
R1
ip route 4.4.4.4 255.255.255.255 12.12.12.2
R2
ip route 1.1.1.1 255.255.255.255 12.12.12.1
ip route 4.4.4.4 255.255.255.255 24.24.24.4
R4
ip route 1.1.1.1 255.255.255.255 24.24.24.2
The ping is reciprocal in few words it requires communication in both ways so source and destination must know how to reach each other.
Now if you want to have redundancy you need to implement floating static routes.
R1
ip route 4.4.4.4 255.255.255.255 13.13.13.3
R2
R3
ip route 1.1.1.1 255.255.255.255 13.13.13.1
ip route 4.4.4.4 255.255.255.255 34.34.34.4
R4
ip route 1.1.1.1 255.255.255.255 34.34.34.3  2
By default the administrative distance for static routes is 1, if we talk about administrative distance, the lowest will always preferred, now if you want to have a back up path you can point to other next hop with higher administrative distance than 1, in my example I set up 2 for the path through R3, so if the link between R1 and R2 is down it will go through R3. Now for this scheme I recommend use a dynamic routing protocol like RIPv2, EIGRP, OSPF, etc.
Then sintaxis of a static route is:
ip route <network segment to be known> <subnet mask> <next hop router IP or the local interface> ; I always prefer use the next hop router IP 'the neighbor'
Hope it is useful.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
11 Replies 11
Dennis Mink
check your routes back , so on r4 do a sh ip route 1.1.1.1 and also on R3, check if all routers now all routes
Please rate if helpful
Please remember to rate useful posts, by clicking on the stars below.
Richard Burts
You have given us minimal information to work with. I do not see any obvious issues in the partial details provided so far that would cause this problem. Can you provide more complete router configs that might help us to identify the issue? It might also be helpful if you would post the output of show ip rout from each of the routers.
I will make one comment based on what is provided so far. The config on R3 is different from the other routers in that it specifies both the outbound interface and the next hop address while the other routers specify only the outbound interface. This can be problematic, especially when the outbound interface is Ethernet. Among other things this approach requires that proxy arp be enabled on the neighbor router. You might try configuring both the outbound interface and the next hop on the other 3 routers and see if the behavior changes.
Rick
Rick
thank you for such a fast responds
rburts  as I mentioned I'm a new one... I don't really know if there's a better option here than pasting all the configs in a separate files
minkdennis  I don't think it's about back routes, in simulation mode Packet Tracer shows problem with ICMP (ARP and CDP are fine)
R4#sh ip route 1.1.1.1
Routing entry for 1.1.1.1/32
  Known via "static", distance 1, metric 0 (connected)
  Routing Descriptor Blocks:
    directly connected, via Ethernet0/1
      Route metric is 0, traffic share count is 1
  * directly connected, via Ethernet0/0
R3#sh ip route 1.1.1.1
  * 13.13.13.1, via Serial1/0
Julio E. Moisa
R1
R2
R4
R1
R2
R3
R4
Hope it is useful.
thank you eduardomoi & thanks again to other guys
now it's working, will do step by step troubleshooting
will try with 1) next hop 2) exit-if 3) next hop & exit-if
I thought if I won't set AD (it's gonna be equal) then
ping will go through R2 or through R3 ("randomly")
You are welcome  :-)
Well if you have 2 or more static routes with the same destination and the same administrative distance but with different next hops, it will create load balance and it could create asymmetric traffic.
Router(config)#ip route 4.4.4.4 255.255.255.255 12.12.12.2 ?
<1-255> Distance metric for this route
"it will create load balance and it could create asymmetric traffic"
& in my example it won't allow ping between 1.1.1.1 and 4.4.4.4
Try using the next hop IP instead the interfaces only. Remember you also need to create an entry for the point to point networks, Example:
R1
ip route 24.24.24.0 255.255.255.0 12.12.12.2 name POINT-TO-POINT-R2-and-R4
R2
R4
ip route 12.12.12.0 255.255.255.0 24.24.24.2 name POINT-TO-POINT-R1-and-R2
Remember the routers know about the connected networks but not the networks of the other routers, so R1 should knows the network between R2 and R4 and R4 should knows about the network between R1 and R2. The same situation for the other path. The otherwise the packet will not able to go back or reach the destination.
Thank you for detailed and helpful comments! :)
I just wanted to give you some additional information: I was using eve 2.0.3-60 and Packet Tracer. In Packet Tracer it was all fine (I tried Simulation Mode after), but I had issues with eve (Emulated Virtual Environment). What I had to do was to set AD values for static routes, these values could be the same (!), I could even remove them after (set to default = 1 for statics). But if I didn't do it then ping from 1.1.1.1 to 4.4.4.4 didn't went through. My point is: keep in mind that software when you learn might be a bit bugged.
Once again thanks to all three guys :)
Thank you for providing the additional information, especially that this was done with emulation software. If done with actual hardware routers the administrative distance would not have been required. You make a very good point about being very careful about using software to emulate network devices. (+5 for you)
Rick
Rick
