取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
Static routing with OSPF
punasup
I have this network. The routers are c7200:
As you can see, I configured the 4 routers with OSPF. Everything works fine. Now I want to configure my router 1 only with static routing and the goal is to ping the router 6. Can you confirm that I should add all the networks (192.168.2-3-4-5-6-7.0) in my route (GW is router 2 of course)?
Thanks.
1 个已接受解答
已接受的解答
Giuseppe Larosa
Hello @punasup ,
as already noted by @marioiram   you don't need static routes that describe all the subnets in your OSPF domain.
as suggested you can use  a static default route pointing to RE2's IP address in subnet 192.168.1.0.
on RE1:
ip route 0.0.0.0 0.0.0.0 192.168.1.2
On RE2 in order to make possible return packets from RE6 to RE1 you need to advertise the subnet between RE1, RE2  you can  for example assuming RE1 is not configured for OSPF
router ospf 10
network 192.168.1.0 0.0.0.255 area 0
passive-interface <interface-name-to-RE1>
To be noted OSPF is not very good in handling external routes ( we have limited control over their scope not granular )
So in real networks instead of using redistributed connected the combo
network     ...               area .....
passive-interface
is to be preferred as it creates an internal route instead of an external one.
Hope to help
Giuseppe
在原帖中查看解决方案
3 条回复3
marioiram
Try a default route on RE1 to send all traffic to RE2, something like "0.0.0.0 0.0.0.0 192.168.1.x" (insert RE2 IP address instead of 192.168.1.x) and under the OSPF config redistribute the connected routes.
Giuseppe Larosa
Hello @punasup ,
on RE1:
router ospf 10
passive-interface
Hope to help
Giuseppe
punasup
Thank you very much to both of you!
