Strange EIGRP problem
jorgecorrales1
Hi there.
I have three equipments in the same LAN. One 6500 switch, one 2800 router and one very old 1600 router. The thing is 2800 and 6500 can establish EIGRP neighborhood. Neither 6500 nor 2800 can establish EIGRP neighborhood with 1600 router. 6500 and 2800 added 1600 on their Neighbor tables, but 1600 didn't.
I run "debug eigrp packets hello". All of them send Hello messages, but for some reason 1600 does not see Hello packets from other equipments. 1600 is connected via serial interface with other router and they could establish neighborhood. I wonder if it is some issue with 1600 Ethernet interface.
Any ideas?
Thanks.
18 Replies 18
Do you know where I can get a newer version? You know a 1600 router is not a brand new hardware...
This 2800 configuration
version 12.3
service password-encryption
hostname ROT-CTL01-CAR
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5
no network-clock-participate aim 0
no network-clock-participate aim 1
no aaa new-model
ip subnet-zero
ip cef
ip domain name
ip name-server 10.129.20.21
no ftp-server write-enable
username monitor privilege 15 secret 5
interface FastEthernet0/0
description RED CTRL. CARTAGO
ip address 10.31.128.1 255.255.192.0 secondary
ip address 10.133.4.1 255.255.252.0
duplex full
speed 100
interface FastEthernet0/1
description CONEXION CON 6500-SAN PEDRO-PB
ip address 10.149.224.2 255.255.252.0
duplex full
speed 100
interface Serial0/0/0
description ROT-CTL01-CAR-SPE7500-SER000 (195-7430)
bandwidth 2048
ip address 10.129.164.2 255.255.252.0
interface Serial0/1/0
description ROT-CTL01-CAR-AGNCAR-SER010 (195-7533)
bandwidth 2048
ip address 10.133.164.1 255.255.252.0
interface Serial0/1/1
description ROT-CTL01-CAR-CTLEMP-SER001
bandwidth 2048
ip address 10.133.176.1 255.255.252.0
interface Serial0/2/0
description ROT-CTL01-CAR-CTLTUR-SER011 (195-5711)
ip address 10.133.168.1 255.255.252.0
interface Serial0/3/0
description ROT-CTL01-CAR-CTLPAR-SER030
bandwidth 128
ip address 10.133.180.1 255.255.252.0
encapsulation ppp
interface Serial0/3/1
no ip address
shutdown
clockrate 2000000
interface Group-Async24
physical-layer async
no ip address
router eigrp 2146
redistribute connected
redistribute static
network 10.0.0.0
no auto-summary
router rip
version 2
network 10.0.0.0
no ip classless
ip route 0.0.0.0 0.0.0.0 10.129.164.1
ip route 10.133.12.0 255.255.252.0 10.133.4.22
ip route 10.133.20.0 255.255.252.0 10.133.4.112
ip route 10.133.24.0 255.255.252.0 10.133.4.111
ip route 10.133.28.0 255.255.252.0 10.133.4.120
ip route 10.133.32.0 255.255.252.0 Serial0/1/1
ip route 10.133.36.0 255.255.252.0 Serial0/3/0
ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
snmp-server community
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server host 10.129.20.74 snmp
control-plane
banner motd ^Ctod
* C E N T R A L C A R T A G O *
* INFRAESTRUCTURA DE CONECTIVIDAD *
* D . A . T . I *
^C
line con 0
password 7
login local
line aux 0
line vty 0 4
privilege level 15
password 7
login local
transport input telnet
line vty 5 15
privilege level 15
password 7
login local
scheduler allocate 20000 1000
sntp server 10.149.164.2
end
Any reason why you have a secondary network on the 1600 router E0/0's interface ?
Can you remove it and see if EIGRP starts to work ?
Hi Jorge,
I think there is a configuration problem with 6500. Either there is a interface in passive mode or there is an access list blocking EIGRP hello packets.
It would be better if u could send config of 6500 and tell us on which ports r these 3 equipments connected to each other.
Deepinder Singh Babbar
I c that ur VLAN 1 is in passsive mode, remove it from passive mode. I hope all the neighbors will form adjacancy after that.
If this info was helpfull please rate that.
Thanks & Regards
