11-02-2022 04:38 AM
Trying to help a customer I found an strange issue, if below configuration is present, all works fine:
Router#show platform
Chassis type: ASR1009-X
Slot Type State Insert time (ago)
1 ASR1000-MIP100 ok 00:15:02
2 ASR1000-MIP100 ok 00:26:33
R0 ASR1000-RP3 ok, active 00:39:11
R1 ASR1000-RP3 ok, standby 00:18:21
F0 ASR1000-ESP100 ok, active 00:39:11
P0 ASR1000X-AC-1100W ok 00:38:03
P1 ASR1000X-AC-1100W ok 00:38:00
P2 ASR1000X-AC-1100W ok 00:37:56
P3 ASR1000X-AC-1100W ok 00:37:51
P4 ASR1000X-AC-1100W ok 00:37:49
P5 ASR1000X-AC-1100W ok 00:37:46
P6 ASR1000X-FAN ok 00:37:32
P7 ASR1000X-FAN ok 00:37:31
P8 ASR1000X-FAN ok 00:37:33
Slot CPLD Version Firmware Version
1 15072100 16.3(2r)
2 15072100 16.3(2r)
R0 17042115 17.3(1r)
R1 17042115 17.3(1r)
F0 12071700 17.3(1r)
Router#
But in the moment I insert the other ASR1000-ESP100 I start to get the below messages:
*Nov 2 12:35:08.062: %CMRP-6-FP_HA_STATUS: R0/0: cmand: F0 redundancy state is Active with ready Standby
*Nov 2 12:35:19.153: %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT: F1/0: cman_fp: Block qesi-chico_set1-CC2/11 of serial bridge 0 had I/O event 0xf800
*Nov 2 12:35:22.556: %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT: C2/0: cmcc: Block qesi-chico_set1-FP1/15 of serial bridge 0 had I/O event 0xd800
*Nov 2 12:35:34.155: %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT: F1/0: cman_fp: Block qesi-chico_set1-CC2/11 of serial bridge 0 had I/O event 0xd800
*Nov 2 12:35:37.689: %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT: C2/0: cmcc: Block qesi-chico_set1-FP1/15 of serial bridge 0 had I/O event 0x9800
*Nov 2 12:35:49.156: %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT: F1/0: cman_fp: Block qesi-chico_set1-CC2/11 of serial bridge 0 had I/O event 0xd000
*Nov 2 12:35:52.826: %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT: C2/0: cmcc: Block qesi-chico_set1-FP1/15 of serial bridge 0 had I/O event 0xd800
*Nov 2 12:36:04.157: %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT: F1/0: cman_fp: Block qesi-chico_set1-CC2/11 of serial bridge 0 had I/O event 0xd800
Router#
If only one ESP is present, doesn't matter the slot its plugged in, the message will not show.
Router#show ver
Cisco IOS XE Software, Version 17.06.04
Cisco IOS Software [Bengaluru], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.6.4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Sun 14-Aug-22 08:52 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2022 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 17.3(1r)
Router uptime is 46 minutes
Uptime for this control processor is 49 minutes
System returned to ROM by Reload Command at 11:38:17 UTC Wed Nov 2 2022
System image file is "bootflash:asr1000rpx86-universalk9.17.06.04.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: Smart License is permanent
License Level: adventerprise
Next reload license Level: adventerprise
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco ASR1009-X (RP3) processor (revision RP3) with 15006187K/24590K bytes of memory.
Processor board ID FXS2204Q3Z0
Router operating mode: Autonomous
32768K bytes of non-volatile configuration memory.
33554432K bytes of physical memory.
7116799K bytes of eUSB flash at bootflash:.
97620247K bytes of SATA hard disk at harddisk:.
Router#
Could someone shred some light on this issue?
Thanks!
11-02-2022 06:06 AM
this document is for IOS-XE version 16, but states the log is cosmetic
System Error Messages Guide For Access and Edge Routers, Cisco IOS XE Gibraltar 16.10.1 - SBC_MPS through TMQ [Cisco IOS XE 16] - Cisco
| %SCOOBY-5-SERIAL_BRIDGE_BLOCK_EVENT : Block [chars]/[dec] of serial bridge [dec] had I/O event [hex] | |
| Explanation | A serial bridge I/O event has occurred. This event is not serious but is logged for diagnostic purposes. |
| Recommended Action | No user action is required. |
11-02-2022 07:21 AM
Hi pieterh,
The strange thing is that they have another chassis with exactly the same config and they don't get any message so far.
Best regards,
11-07-2022 01:13 AM
See attached a bit more info, take into account that these two chassis/card combination are exactly the same (and running the same IOS-XR) so, if was cosmetic, I would expect to have the same errors in both chassis:
RP/0/RSP1/CPU0:W4A#show controller np ports all location 0/0/CPU0
Fri Nov 4 16:24:44.096 CET
Node: 0/0/CPU0:
CPX NP Bridge Fia Ports
0 0 0 0 HundredGigE0/0/0/1
0 1 0 1 HundredGigE0/0/0/1
1 2 1 2 HundredGigE0/0/0/0
1 3 1 3 HundredGigE0/0/0/0
Then with the command below I identified that in bridge 1 (the one that controls the offending port) there are various errors:
RP/0/RSP1/CPU0:W4A#show controllers fabric fia bridge stats location 0/0/CPU0
Fri Nov 4 16:46:50.210 CET
********** FIA-0 **********
Category: bridge_in-0
To FIA0 L-0 1975908298
To FIA0 L-1 22657962790
To FIA1 L-0 25593342316
To FIA1 L-1 2394174402
Frm NPU ilk 52621387810
Frm NPU Pkt 52621387812
MC Ch0 Pkt drp 0
MC Ch1 Pkt drp 0
MC Ch2 Pkt drp 0
MC Ch3 Pkt drp 0
FIA00 Tx Err 0
FIA01 Tx Err 0
FIA10 Tx Err 0
FIA11 Tx Err 0
NP Err1 Cnt 0
NP Err2 Cnt 0
NP Err3 Cnt 0
NP Err4 Cnt 0
NP WrdSync1 0
NP WrdSync2 0
NP WrdSync3 0
NP WrdSync4 0
NP WrdSync5 0
NP WrdSync6 0
NP MFrm Err1 0
NP MFrm Err2 0
NP MFrm Err3 0
NP MFrm Err4 0
NP MFrm Err5 0
NP MFrm Err6 0
NP BType Err1 0
NP BType Err2 0
NP BType Err3 0
NP BType Err4 0
NP BType Err5 0
NP BType Err6 0
NP MFrmSync1 0
NP MFrmSync2 0
NP MFrmSync3 0
NP MFrmSync4 0
NP MFrmSync5 0
NP MFrmSync6 0
NP MFrmLn Err1 0
NP MFrmLn Err2 0
NP MFrmLn Err3 0
NP MFrmLn Err4 0
NP MFrmLn Err5 0
NP MFrmLn Err6 0
Category: bridge_eg-0
FIA0 L-0 ilk 18551480573
FIA0 L-1 ilk 18151690715
FIA1 L-0 ilk 704245493002
FIA1 L-1 ilk 18668799906
FIA0 L-0 Pkt 18551480576
FIA0 L-1 Pkt 18151690718
FIA1 L-0 Pkt 704245493007
FIA1 L-1 Pkt 18668799908
To NPU 759617464248
UC LO Pkt ctr 758964674469
UC HI Pkt ctr 16613759
MC LO Pkt ctr 1003120
MC HI Pkt ctr 635172902
UC LO Pkt drp 0
UC HI Pkt drp 0
MC LO Pkt drp 0
MC HI Pkt drp 0
FIA00 Pkt drp 0
FIA01 Pkt drp 0
FIA10 Pkt drp 0
FIA11 Pkt drp 0
NPU Err Cnt 0
FIA00 Rx Err 0
FIA00 ilk Err 0
FIA00 crc Err 0
FIA00 seq Err 0
FIA01 Rx Err 0
FIA01 ilk Err 0
FIA01 crc Err 0
FIA01 seq Err 0
FIA10 Rx Err 0
FIA10 ilk Err 0
FIA10 crc Err 0
FIA10 seq Err 0
FIA11 Rx Err 0
FIA11 ilk Err 0
FIA11 crc Err 0
FIA11 seq Err 0
FIA00 crc1 Err 0
FIA00 crc2 Err 0
FIA01 crc1 Err 0
FIA01 crc2 Err 0
FIA10 crc1 Err 0
FIA10 crc2 Err 0
FIA11 crc1 Err 0
FIA11 crc2 Err 0
********** FIA-1 **********
Category: bridge_in-1
To FIA0 L-0 1897378903970
To FIA0 L-1 716307026477
To FIA1 L-0 14725384592
To FIA1 L-1 796301087214
Frm NPU ilk 3424712402254
Frm NPU Pkt 3424712402257
MC Ch0 Pkt drp 0
MC Ch1 Pkt drp 0
MC Ch2 Pkt drp 0
MC Ch3 Pkt drp 0
FIA00 Tx Err 0
FIA01 Tx Err 0
FIA10 Tx Err 0
FIA11 Tx Err 0
NP Err1 Cnt 0
NP Err2 Cnt 0
NP Err3 Cnt 0
NP Err4 Cnt 0
NP WrdSync1 0
NP WrdSync2 0
NP WrdSync3 0
NP WrdSync4 0
NP WrdSync5 0
NP WrdSync6 0
NP MFrm Err1 0
NP MFrm Err2 0
NP MFrm Err3 0
NP MFrm Err4 0
NP MFrm Err5 0
NP MFrm Err6 0
NP BType Err1 0
NP BType Err2 0
NP BType Err3 0
NP BType Err4 0
NP BType Err5 0
NP BType Err6 0
NP MFrmSync1 0
NP MFrmSync2 0
NP MFrmSync3 0
NP MFrmSync4 0
NP MFrmSync5 0
NP MFrmSync6 0
NP MFrmLn Err1 0
NP MFrmLn Err2 0
NP MFrmLn Err3 0
NP MFrmLn Err4 0
NP MFrmLn Err5 0
NP MFrmLn Err6 0
Category: bridge_eg-1
FIA0 L-0 ilk 1745875069
FIA0 L-1 ilk 1430103512
FIA1 L-0 ilk 38157078790
FIA1 L-1 ilk 1424658053
FIA0 L-0 Pkt 1745875070
FIA0 L-1 Pkt 1430103513
FIA1 L-0 Pkt 38157078795
FIA1 L-1 Pkt 1424615986
To NPU 42757673372
UC LO Pkt ctr 42375120096
UC HI Pkt ctr 982848
MC LO Pkt ctr 91752
MC HI Pkt ctr 381478679
UC LO Pkt drp 0
UC HI Pkt drp 0
MC LO Pkt drp 0
MC HI Pkt drp 0
FIA00 Pkt drp 0
FIA01 Pkt drp 0
FIA10 Pkt drp 0
FIA11 Pkt drp 0
NPU Err Cnt 0
FIA00 Rx Err 0
FIA00 ilk Err 0
FIA00 crc Err 0
FIA00 seq Err 0
FIA01 Rx Err 0
FIA01 ilk Err 0
FIA01 crc Err 0
FIA01 seq Err 0
FIA10 Rx Err 0
FIA10 ilk Err 0
FIA10 crc Err 0
FIA10 seq Err 0
FIA11 Rx Err 52212
FIA11 ilk Err 365441
FIA11 crc Err 3786383512
FIA11 seq Err 1
FIA00 crc1 Err 0
FIA00 crc2 Err 0
FIA01 crc1 Err 0
FIA01 crc2 Err 0
FIA10 crc1 Err 0
FIA10 crc2 Err 0
FIA11 crc1 Err 3783754038
FIA11 crc2 Err 0
RP/0/RSP1/CPU0:W4A#show controller fabric fia drop in location 0/0/CPU0
Fri Nov 4 17:00:32.660 CET
Category: in_drop-0
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
Header parsing drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 16
sp1 bad align 0
sp1 bad code 16
sp1 align fail 3
sp1 prot err 3
Category: in_drop-1
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 1
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 0
sp1 bad align 0
sp1 bad code 0
sp1 align fail 3
sp1 prot err 0
********** FIA-2 **********
Category: in_drop-2
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 103685
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 0
sp1 bad align 0
sp1 bad code 0
sp1 align fail 3
sp1 prot err 0
********** FIA-3 **********
Category: in_drop-3
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 7
sp1 bad align 0
sp1 bad code 4
sp1 align fail 3
sp1 prot err 0
RP/0/RSP1/CPU0:W4A#show controller fabric fia q-depth location 0/0/CPU0
Fri Nov 4 17:01:19.200 CET
Category: q_stats_a-0
Voq ddr pri pktcnt Slot_FIA_NP
Category: q_stats_b-0
Category: q_stats_a-1
Category: q_stats_b-1
Category: q_stats_a-2
Category: q_stats_b-2
Category: q_stats_a-3
312 0 2 1450 LC2_0_0
Category: q_stats_b-3
Finally I paste the output of the same 4 commands from the machine that has no problems:
RP/0/RSP0/CPU0:NS3#show controller np ports all location 0/0/CPU0
Fri Nov 4 17:37:30.510 CET
Node: 0/0/CPU0:
RP/0/RSP0/CPU0:NS3#show controllers fabric fia bridge stats location 0/0/CPU0
Fri Nov 4 17:37:59.049 CET
To FIA0 L-0 27477332927
To FIA0 L-1 27847393105
To FIA1 L-0 27774090133
To FIA1 L-1 28387156842
Frm NPU ilk 111485973012
Frm NPU Pkt 111485973014
MC Ch0 Pkt drp 0
MC Ch1 Pkt drp 0
MC Ch2 Pkt drp 0
MC Ch3 Pkt drp 0
FIA00 Tx Err 0
FIA01 Tx Err 0
FIA10 Tx Err 0
FIA11 Tx Err 0
NP Err1 Cnt 0
NP Err2 Cnt 0
NP Err3 Cnt 0
NP Err4 Cnt 0
NP WrdSync1 0
NP WrdSync2 0
NP WrdSync3 0
NP WrdSync4 0
NP WrdSync5 0
NP WrdSync6 0
NP MFrm Err1 0
NP MFrm Err2 0
NP MFrm Err3 0
NP MFrm Err4 0
NP MFrm Err5 0
NP MFrm Err6 0
NP BType Err1 0
NP BType Err2 0
NP BType Err3 0
NP BType Err4 0
NP BType Err5 0
NP BType Err6 0
NP MFrmSync1 0
NP MFrmSync2 0
NP MFrmSync3 0
NP MFrmSync4 0
NP MFrmSync5 0
NP MFrmSync6 0
NP MFrmLn Err1 0
NP MFrmLn Err2 0
NP MFrmLn Err3 0
NP MFrmLn Err4 0
NP MFrmLn Err5 0
NP MFrmLn Err6 0
FIA0 L-0 ilk 57343383331
FIA0 L-1 ilk 56875518953
FIA1 L-0 ilk 57318428927
FIA1 L-1 ilk 57342623474
FIA0 L-0 Pkt 57343383334
FIA0 L-1 Pkt 56875518958
FIA1 L-0 Pkt 57318428932
FIA1 L-1 Pkt 57342623478
To NPU 228879954725
UC LO Pkt ctr 228152056244
UC HI Pkt ctr 79434304
MC LO Pkt ctr 240256
MC HI Pkt ctr 648223921
UC LO Pkt drp 0
UC HI Pkt drp 0
MC LO Pkt drp 0
MC HI Pkt drp 0
FIA00 Pkt drp 0
FIA01 Pkt drp 0
FIA10 Pkt drp 0
FIA11 Pkt drp 0
NPU Err Cnt 0
FIA00 Rx Err 0
FIA00 ilk Err 0
FIA00 crc Err 0
FIA00 seq Err 0
FIA01 Rx Err 0
FIA01 ilk Err 0
FIA01 crc Err 0
FIA01 seq Err 0
FIA10 Rx Err 0
FIA10 ilk Err 0
FIA10 crc Err 0
FIA10 seq Err 0
FIA11 Rx Err 0
FIA11 ilk Err 0
FIA11 crc Err 0
FIA11 seq Err 0
FIA00 crc1 Err 0
FIA00 crc2 Err 0
FIA01 crc1 Err 0
FIA01 crc2 Err 0
FIA10 crc1 Err 0
FIA10 crc2 Err 0
FIA11 crc1 Err 0
FIA11 crc2 Err 0
To FIA0 L-0 413523092710
To FIA0 L-1 408254651520
To FIA1 L-0 407426294052
To FIA1 L-1 1607159674927
Frm NPU ilk 2836363713215
Frm NPU Pkt 2836363713219
MC Ch0 Pkt drp 0
MC Ch1 Pkt drp 0
MC Ch2 Pkt drp 0
MC Ch3 Pkt drp 0
FIA00 Tx Err 0
FIA01 Tx Err 0
FIA10 Tx Err 0
FIA11 Tx Err 0
NP Err1 Cnt 0
NP Err2 Cnt 0
NP Err3 Cnt 0
NP Err4 Cnt 0
NP WrdSync1 0
NP WrdSync2 0
NP WrdSync3 0
NP WrdSync4 0
NP WrdSync5 0
NP WrdSync6 0
NP MFrm Err1 0
NP MFrm Err2 0
NP MFrm Err3 0
NP MFrm Err4 0
NP MFrm Err5 0
NP MFrm Err6 0
NP BType Err1 0
NP BType Err2 0
NP BType Err3 0
NP BType Err4 0
NP BType Err5 0
NP BType Err6 0
NP MFrmSync1 0
NP MFrmSync2 0
NP MFrmSync3 0
NP MFrmSync4 0
NP MFrmSync5 0
NP MFrmSync6 0
NP MFrmLn Err1 0
NP MFrmLn Err2 0
NP MFrmLn Err3 0
NP MFrmLn Err4 0
NP MFrmLn Err5 0
NP MFrmLn Err6 0
FIA0 L-0 ilk 3400484549787
FIA0 L-1 ilk 105233491135
FIA1 L-0 ilk 102479840910
FIA1 L-1 ilk 101977545140
FIA0 L-0 Pkt 3400484549787
FIA0 L-1 Pkt 105233491136
FIA1 L-0 Pkt 102479840917
FIA1 L-1 Pkt 101977545143
To NPU 3710175426990
UC LO Pkt ctr 3709853180349
UC HI Pkt ctr 918672
MC LO Pkt ctr 95888
MC HI Pkt ctr 321232082
UC LO Pkt drp 0
UC HI Pkt drp 0
MC LO Pkt drp 0
MC HI Pkt drp 0
FIA00 Pkt drp 0
FIA01 Pkt drp 0
FIA10 Pkt drp 0
FIA11 Pkt drp 0
NPU Err Cnt 0
FIA00 Rx Err 0
FIA00 ilk Err 0
FIA00 crc Err 0
FIA00 seq Err 0
FIA01 Rx Err 0
FIA01 ilk Err 0
FIA01 crc Err 0
FIA01 seq Err 0
FIA10 Rx Err 0
FIA10 ilk Err 0
FIA10 crc Err 0
FIA10 seq Err 0
FIA11 Rx Err 0
FIA11 ilk Err 0
FIA11 crc Err 0
FIA11 seq Err 0
FIA00 crc1 Err 0
FIA00 crc2 Err 0
FIA01 crc1 Err 0
FIA01 crc2 Err 0
FIA10 crc1 Err 0
FIA10 crc2 Err 0
FIA11 crc1 Err 0
FIA11 crc2 Err 0
RP/0/RSP0/CPU0:NS3#show controller fabric fia drop in location 0/0/CPU0
Fri Nov 4 17:38:33.515 CET
Category: in_drop-0
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 2
sp1 bad align 0
sp1 bad code 1
sp1 align fail 3
sp1 prot err 0
Category: in_drop-1
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 12
sp1 bad align 0
sp1 bad code 7
sp1 align fail 3
sp1 prot err 3
Category: in_drop-2
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 0
sp1 bad align 0
sp1 bad code 0
sp1 align fail 3
sp1 prot err 0
Category: in_drop-3
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 25
sp0 bad align 0
sp0 bad code 14
sp0 align fail 3
sp0 prot err 8
sp1 crc err 0
sp1 bad align 0
sp1 bad code 1
sp1 align fail 3
sp1 prot err 0
RP/0/RSP0/CPU0:NS3#show controller fabric fia q-depth location 0/0/CPU0
Fri Nov 4 17:39:14.798 CET
323 0 2 92 LC2_1_3
Node: 0/0/CPU0:
MC Ch0 Pkt drp 0
MC Ch1 Pkt drp 0
MC Ch2 Pkt drp 0
MC Ch3 Pkt drp 0
FIA00 Tx Err 0
FIA01 Tx Err 0
FIA10 Tx Err 0
FIA11 Tx Err 0
NP Err1 Cnt 0
NP Err2 Cnt 0
NP Err3 Cnt 0
NP Err4 Cnt 0
NP WrdSync1 0
NP WrdSync2 0
NP WrdSync3 0
NP WrdSync4 0
NP WrdSync5 0
NP WrdSync6 0
NP MFrm Err1 0
NP MFrm Err2 0
NP MFrm Err3 0
NP MFrm Err4 0
NP MFrm Err5 0
NP MFrm Err6 0
NP BType Err1 0
NP BType Err2 0
NP BType Err3 0
NP BType Err4 0
NP BType Err5 0
NP BType Err6 0
NP MFrmSync1 0
NP MFrmSync2 0
NP MFrmSync3 0
NP MFrmSync4 0
NP MFrmSync5 0
NP MFrmSync6 0
NP MFrmLn Err1 0
NP MFrmLn Err2 0
NP MFrmLn Err3 0
NP MFrmLn Err4 0
NP MFrmLn Err5 0
NP MFrmLn Err6 0
To NPU 759617464248
UC LO Pkt drp 0
UC HI Pkt drp 0
MC LO Pkt drp 0
MC HI Pkt drp 0
FIA00 Pkt drp 0
FIA01 Pkt drp 0
FIA10 Pkt drp 0
FIA11 Pkt drp 0
NPU Err Cnt 0
FIA00 Rx Err 0
FIA00 ilk Err 0
FIA00 crc Err 0
FIA00 seq Err 0
FIA01 Rx Err 0
FIA01 ilk Err 0
FIA01 crc Err 0
FIA01 seq Err 0
FIA10 Rx Err 0
FIA10 ilk Err 0
FIA10 crc Err 0
FIA10 seq Err 0
FIA11 Rx Err 0
FIA11 ilk Err 0
FIA11 crc Err 0
FIA11 seq Err 0
FIA00 crc1 Err 0
FIA00 crc2 Err 0
FIA01 crc1 Err 0
FIA01 crc2 Err 0
FIA10 crc1 Err 0
FIA10 crc2 Err 0
FIA11 crc1 Err 0
FIA11 crc2 Err 0
MC Ch0 Pkt drp 0
MC Ch1 Pkt drp 0
MC Ch2 Pkt drp 0
MC Ch3 Pkt drp 0
FIA00 Tx Err 0
FIA01 Tx Err 0
FIA10 Tx Err 0
FIA11 Tx Err 0
NP Err1 Cnt 0
NP Err2 Cnt 0
NP Err3 Cnt 0
NP Err4 Cnt 0
NP WrdSync1 0
NP WrdSync2 0
NP WrdSync3 0
NP WrdSync4 0
NP WrdSync5 0
NP WrdSync6 0
NP MFrm Err1 0
NP MFrm Err2 0
NP MFrm Err3 0
NP MFrm Err4 0
NP MFrm Err5 0
NP MFrm Err6 0
NP BType Err1 0
NP BType Err2 0
NP BType Err3 0
NP BType Err4 0
NP BType Err5 0
NP BType Err6 0
NP MFrmSync1 0
NP MFrmSync2 0
NP MFrmSync3 0
NP MFrmSync4 0
NP MFrmSync5 0
NP MFrmSync6 0
NP MFrmLn Err1 0
NP MFrmLn Err2 0
NP MFrmLn Err3 0
NP MFrmLn Err4 0
NP MFrmLn Err5 0
NP MFrmLn Err6 0
To NPU 42757673372
MC LO Pkt ctr 91752
UC LO Pkt drp 0
UC HI Pkt drp 0
MC LO Pkt drp 0
MC HI Pkt drp 0
FIA00 Pkt drp 0
FIA01 Pkt drp 0
FIA10 Pkt drp 0
FIA11 Pkt drp 0
NPU Err Cnt 0
FIA00 Rx Err 0
FIA00 ilk Err 0
FIA00 crc Err 0
FIA00 seq Err 0
FIA01 Rx Err 0
FIA01 ilk Err 0
FIA01 crc Err 0
FIA01 seq Err 0
FIA10 Rx Err 0
FIA10 ilk Err 0
FIA10 crc Err 0
FIA10 seq Err 0
FIA11 Rx Err 52212
FIA11 seq Err 1
FIA00 crc1 Err 0
FIA00 crc2 Err 0
FIA01 crc1 Err 0
FIA01 crc2 Err 0
FIA10 crc1 Err 0
FIA10 crc2 Err 0
FIA11 crc2 Err 0
Category: in_drop-0
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 16
sp1 bad align 0
sp1 bad code 16
sp1 align fail 3
sp1 prot err 3
Category: in_drop-1
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 1
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 0
sp1 bad align 0
sp1 bad code 0
sp1 align fail 3
sp1 prot err 0
Category: in_drop-2
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 103685
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 0
sp1 bad align 0
sp1 bad code 0
sp1 align fail 3
sp1 prot err 0
Category: in_drop-3
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 7
sp1 bad align 0
sp1 bad code 4
sp1 align fail 3
sp1 prot err 0
Node: 0/0/CPU0:
MC Ch0 Pkt drp 0
MC Ch1 Pkt drp 0
MC Ch2 Pkt drp 0
MC Ch3 Pkt drp 0
FIA00 Tx Err 0
FIA01 Tx Err 0
FIA10 Tx Err 0
FIA11 Tx Err 0
NP Err1 Cnt 0
NP Err2 Cnt 0
NP Err3 Cnt 0
NP Err4 Cnt 0
NP WrdSync1 0
NP WrdSync2 0
NP WrdSync3 0
NP WrdSync4 0
NP WrdSync5 0
NP WrdSync6 0
NP MFrm Err1 0
NP MFrm Err2 0
NP MFrm Err3 0
NP MFrm Err4 0
NP MFrm Err5 0
NP MFrm Err6 0
NP BType Err1 0
NP BType Err2 0
NP BType Err3 0
NP BType Err4 0
NP BType Err5 0
NP BType Err6 0
NP MFrmSync1 0
NP MFrmSync2 0
NP MFrmSync3 0
NP MFrmSync4 0
NP MFrmSync5 0
NP MFrmSync6 0
NP MFrmLn Err1 0
NP MFrmLn Err2 0
NP MFrmLn Err3 0
NP MFrmLn Err4 0
NP MFrmLn Err5 0
NP MFrmLn Err6 0
To NPU 228879954725
UC LO Pkt drp 0
UC HI Pkt drp 0
MC LO Pkt drp 0
MC HI Pkt drp 0
FIA00 Pkt drp 0
FIA01 Pkt drp 0
FIA10 Pkt drp 0
FIA11 Pkt drp 0
NPU Err Cnt 0
FIA00 Rx Err 0
FIA00 ilk Err 0
FIA00 crc Err 0
FIA00 seq Err 0
FIA01 Rx Err 0
FIA01 ilk Err 0
FIA01 crc Err 0
FIA01 seq Err 0
FIA10 Rx Err 0
FIA10 ilk Err 0
FIA10 crc Err 0
FIA10 seq Err 0
FIA11 Rx Err 0
FIA11 ilk Err 0
FIA11 crc Err 0
FIA11 seq Err 0
FIA00 crc1 Err 0
FIA00 crc2 Err 0
FIA01 crc1 Err 0
FIA01 crc2 Err 0
FIA10 crc1 Err 0
FIA10 crc2 Err 0
FIA11 crc1 Err 0
FIA11 crc2 Err 0
MC Ch0 Pkt drp 0
MC Ch1 Pkt drp 0
MC Ch2 Pkt drp 0
MC Ch3 Pkt drp 0
FIA00 Tx Err 0
FIA01 Tx Err 0
FIA10 Tx Err 0
FIA11 Tx Err 0
NP Err1 Cnt 0
NP Err2 Cnt 0
NP Err3 Cnt 0
NP Err4 Cnt 0
NP WrdSync1 0
NP WrdSync2 0
NP WrdSync3 0
NP WrdSync4 0
NP WrdSync5 0
NP WrdSync6 0
NP MFrm Err1 0
NP MFrm Err2 0
NP MFrm Err3 0
NP MFrm Err4 0
NP MFrm Err5 0
NP MFrm Err6 0
NP BType Err1 0
NP BType Err2 0
NP BType Err3 0
NP BType Err4 0
NP BType Err5 0
NP BType Err6 0
NP MFrmSync1 0
NP MFrmSync2 0
NP MFrmSync3 0
NP MFrmSync4 0
NP MFrmSync5 0
NP MFrmSync6 0
NP MFrmLn Err1 0
NP MFrmLn Err2 0
NP MFrmLn Err3 0
NP MFrmLn Err4 0
NP MFrmLn Err5 0
NP MFrmLn Err6 0
MC LO Pkt ctr 95888
UC LO Pkt drp 0
UC HI Pkt drp 0
MC LO Pkt drp 0
MC HI Pkt drp 0
FIA00 Pkt drp 0
FIA01 Pkt drp 0
FIA10 Pkt drp 0
FIA11 Pkt drp 0
NPU Err Cnt 0
FIA00 Rx Err 0
FIA00 ilk Err 0
FIA00 crc Err 0
FIA00 seq Err 0
FIA01 Rx Err 0
FIA01 ilk Err 0
FIA01 crc Err 0
FIA01 seq Err 0
FIA10 Rx Err 0
FIA10 ilk Err 0
FIA10 crc Err 0
FIA10 seq Err 0
FIA11 Rx Err 0
FIA11 ilk Err 0
FIA11 crc Err 0
FIA11 seq Err 0
FIA00 crc1 Err 0
FIA00 crc2 Err 0
FIA01 crc1 Err 0
FIA01 crc2 Err 0
FIA10 crc1 Err 0
FIA10 crc2 Err 0
FIA11 crc1 Err 0
FIA11 crc2 Err 0
Category: in_drop-0
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 2
sp1 bad align 0
sp1 bad code 1
sp1 align fail 3
sp1 prot err 0
Category: in_drop-1
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 12
sp1 bad align 0
sp1 bad code 7
sp1 align fail 3
sp1 prot err 3
Category: in_drop-2
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 0
sp0 bad align 0
sp0 bad code 0
sp0 align fail 3
sp0 prot err 0
sp1 crc err 0
sp1 bad align 0
sp1 bad code 0
sp1 align fail 3
sp1 prot err 0
Category: in_drop-3
From Spaui Drop-0 0
accpt tbl-0 0
ctl len-0 0
short pkt-0 0
max pkt len-0 0
min pkt len-0 0
From Spaui Drop-1 0
accpt tbl-1 0
ctl len-1 0
short pkt-1 0
max pkt len-1 0
min pkt len-1 0
Tail drp 0
Vqi drp 0
pw to ni drp 0
ni from pw drp 0
sp0 crc err 25
sp0 bad align 0
sp0 bad code 14
sp0 align fail 3
sp0 prot err 8
sp1 crc err 0
sp1 bad align 0
sp1 bad code 1
sp1 align fail 3
sp1 prot err 0
323 0 2 92 LC2_1_3
Best regards,
