Strange NAT problem
nemiath76
I am facing a strange issue with a clients cisco.
Although the DMZ server 192.168.1.102 is accesible at the beggining after a few hours it stops allowing the connection.
firewall logging does not show any dropped packets.
When i telnet at port 80 from outside i get a responce from the apache server but the browser failes to connect.
I think this is a NAT issue. The external ip address of the server is 94.70.142.127.
Can someone provide me some feedback? Is there something wrong with my NAT configuration?
Building configuration...
Current configuration : 10709 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname DocNetR1
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging message-counter syslog
logging buffered 4096 informational
enable secret 5 $1$1i/v$8tduHDZEMmcY6sRWsNHyK0
enable password 7 12292504011C5C162E7A
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-2567543707
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2567543707
revocation-check none
rsakeypair TP-self-signed-2567543707
crypto pki certificate chain TP-self-signed-2567543707
certificate self-signed 01
  3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32353637 35343337 3037301E 170D3133 30313137 31373436
  35325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35363735
  34333730 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100ABA4 B7FFF4F1 9FBE79D8 2CEBCA68 A14BE3AB DBF770C2 EB35A954 B271AE3E
  F8485837 F2E8566B 66E5EF6B BCFCDFA3 8F6F91F3 FD8E3015 879A67F5 85DD95F5
  C26875C0 2202CA6C CE95888F 545AB4F6 6F708A0E C65E78D1 60967480 5589F5EE
  80505E46 8767CE2C 37C994FE AB555AF0 BA4C4679 63FF7641 34FFF6EF 3EC38006
  46B90203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF 30110603
  551D1104 0A300882 06526F75 74657230 1F060355 1D230418 30168014 F0DE8531
  8FB370C3 6B4AFEB4 B0CA4460 25F0329C 301D0603 551D0E04 160414F0 DE85318F
  B370C36B 4AFEB4B0 CA446025 F0329C30 0D06092A 864886F7 0D010104 05000381
  810014AE D4A40F54 38472D5E 51FCE972 4955931B 73955A1D 0B8E9CB2 082566C7
  C42DEEE0 5A6D888A 2BF00C84 54E3BB2E 45A96188 D61658F7 9EC8E8DA 94BDE65B
  15F653DA 7B4C65C5 A4E80574 91F5CFDC 2088EFCE C68A16B5 F0D26B22 3ACB07C7
  EC29AE31 1935FE46 A986CAFA 25124A89 B0EE97C9 7FB9A5AD F4D6D06F E5FFDBD1 0D17
      quit
no ip source-route
ip cef
no ip bootp server
ip name-server 195.170.0.1
ip inspect log drop-pkt
no ipv6 cef
username admin privilege 15 view root secret 5 $1$Lny5$et1FhWOpIKOOYRUtN89H10
archive
log config
  hidekeys
ip tcp synwait-time 10
class-map type inspect match-any WebService
match protocol http
match protocol https
class-map type inspect match-all sdm-cls-sdm-pol-NATOutsideToInside-1-1
match class-map WebService
match access-group name WebServer
class-map type inspect match-all ccp-cls--1
match access-group name tr-out-self
class-map type inspect match-any CCP-Voice-permit
match protocol h323
match protocol skinny
match protocol sip
class-map type inspect match-all ccp-cls--2
match access-group name tr-out-in
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any http-https-DMZ
match protocol http
class-map type inspect match-all sdm-cls--2
match class-map http-https-DMZ
match access-group name web_server
class-map type inspect match-any MySQLService
match protocol mysql
class-map type inspect match-all sdm-cls--1
match class-map MySQLService
match access-group name DMZtoMySQL
class-map type inspect match-any sr-dmz-in-dns
match protocol dns
class-map type inspect match-any sr-out-in-https
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-cls-sdm-policy-sdm-cls--1-1
match class-map sr-dmz-in-dns
match access-group name tr-dmz-in-dns
class-map type inspect match-all ccp-cls-ccp-policy-ccp-cls--2-1
match class-map sr-out-in-https
match access-group name tr-out-in-80
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-cls-sdm-pol-NATOutsideToInside-1-1
  inspect
class class-default
  drop
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect CCP-Voice-permit
  inspect
class class-default
  drop
policy-map type inspect sdm-policy-sdm-cls--1
class type inspect ccp-cls-sdm-policy-sdm-cls--1-1
  inspect
class type inspect sdm-cls--1
  inspect
class class-default
  drop
policy-map type inspect ccp-policy-ccp-cls--1
class type inspect ccp-cls--1
  drop log
class class-default
  drop
policy-map type inspect sdm-policy-sdm-cls--2
class type inspect sdm-cls--2
  inspect
class class-default
  drop
policy-map type inspect ccp-policy-ccp-cls--2
class type inspect ccp-cls-ccp-policy-ccp-cls--2-1
  inspect
class type inspect ccp-cls--2
  drop log
class class-default
  drop
zone security out-zone
zone security in-zone
zone security dmz-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security zp-dmz-to-outside source dmz-zone destination out-zone
zone-pair security zp-outside-to-dmz source out-zone destination dmz-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
zone-pair security sdm-zp-dmz-zone-in-zone source dmz-zone destination in-zone
service-policy type inspect sdm-policy-sdm-cls--1
zone-pair security sdm-zp-in-zone-dmz-zone source in-zone destination dmz-zone
service-policy type inspect sdm-policy-sdm-cls--2
zone-pair security sdm-zp-out-zone-self source out-zone destination self
service-policy type inspect ccp-policy-ccp-cls--1
zone-pair security sdm-zp-out-zone-in-zone source out-zone destination in-zone
service-policy type inspect ccp-policy-ccp-cls--2
interface Null0
no ip unreachables
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 2
interface Vlan1
description $FW_INSIDE$
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
zone-member security in-zone
ip tcp adjust-mss 1412
interface Vlan2
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security dmz-zone
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname dikt15@otenet.gr
ppp chap password 7 124D094E0A5E4953
ppp pap sent-username dikt15@otenet.gr password 7 0918425001505245
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 2
ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static 192.168.0.101 94.70.142.113
ip nat inside source static 192.168.1.102 94.70.142.127
ip access-list extended DMZtoMySQL
remark CCP_ACL Category=128
permit ip host 192.168.1.102 host 192.168.0.101
ip access-list extended VTY_incoming
permit ip 192.168.0.0 0.0.0.255 any
ip access-list extended WebServer
permit ip any host 192.168.1.102
ip access-list extended tr-dmz-in-dns
permit ip host 192.168.1.102 host 192.168.0.100
ip access-list extended tr-out-in
permit ip any any
ip access-list extended tr-out-in-80
permit ip any host 192.168.0.101
ip access-list extended tr-out-self
permit ip any any
ip access-list extended web_server
permit ip 192.168.0.0 0.0.0.255 host 192.168.1.102
logging trap notifications
logging 192.168.0.2
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 2 deny   any
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CWARNING!!!This is a highly monitored private system. Access is prohibited!!^C
line con 0
login authentication local_authen
no modem enable
transport output telnet
line aux 0
line vty 0 4
access-class VTY_incoming in
password 7 08116C5D1A0E550516
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Abzal
Level 7
Level 7
Try to debug HTTP inspection
debug ip inspect http
I don't think that NAT could be a problem as you can succesfully telnet on 80 port.
Another option try change this
  drop log
  inspect
  inspect
  inspect
class class-default
  drop
to this
  drop log
  pass
  inspect
  inspect
class class-default
  drop
It will allow to pass return HTTP traffic from webserver.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
