strange problem
volkan.gunaydin
Think about this:
2 router on the same subnet. One Windows XP client. The default gateway of the client is Router 1. The Router 1's Default Gateway is Router 2. When I ping from Windows XP to Router 1, it pings 1 times to Router 1 and the other pings go to Router 2.
Windows Client adds a route to its routing table! What is the case, please give me a technical explanation and how to resolve this issue (this is a model actually, I will resolve a big problem if I realize whats going on in this scenario). thanks.
7 Replies 7
Danilo Dy
Can you post the following;
1. Windows Client
route print output
ipconfig all output
2. Routers
router1 and router2 ip address and subnet that is in the same vlan with your Windows Client
Etkin Yollar:
Ağ Hedefi Ağ Maskesi Ağ Ge?idi Arabirim ?l??t
0.0.0.0 0.0.0.0 192.168.2.220 192.168.2.230 20
69.147.114.210 255.255.255.255 192.168.2.253 192.168.2.230 1
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.0.1 255.255.255.255 192.168.2.253 192.168.2.230 1
192.168.0.241 255.255.255.255 192.168.2.253 192.168.2.230 1
192.168.2.0 255.255.255.0 192.168.2.230 192.168.2.230 20
192.168.2.230 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.2.255 255.255.255.255 192.168.2.230 192.168.2.230 20
193.254.252.30 255.255.255.255 192.168.2.253 192.168.2.230 1
207.46.111.27 255.255.255.255 192.168.2.253 192.168.2.230 1
207.68.178.61 255.255.255.255 192.168.2.253 192.168.2.230 1
224.0.0.0 240.0.0.0 192.168.2.230 192.168.2.230 20
255.255.255.255 255.255.255.255 192.168.2.230 192.168.2.230 1
255.255.255.255 255.255.255.255 192.168.2.230 10004 1
Varsayılan
Ağ Ge?idi: 192.168.2.220
S?rekli Yollar:
Yok
IP1: 192.168.2.253
IP2:192.168.2.220
Thanks.
jitesh1982
Hello Volkan,
Could you please post configuration of both router and ip of your XP client.
Rgds,
Jitesh
Isn't that because of ICMP Redirect or Proxy ARP? Check the subnet masks of the workstation and router.
Humm... That's strange. =)
-John
ncglass
Is router 1 sending an ICMP redirect to the host? The situation is appropriate for that to happen. Not sure if creating a static route is how Windows handles a redirect (rather than changing the default gateway)
What you are seeing is the normal behavior. IP redirects are enabled by default on Cisco routers.
If you are trying to get to a destination that router1 has to go through router2 then it would send ICMP redirect to the host to forward packet to that destination directly to router2, which is on the same segment.
There may be situations why this behavior may be undesirable. In that case, you can turn off this default behavior on router1 as noted below.
int --> this s/b your LAN interface
no ip redirect
Sundar
Thank you all of you and especially Sundar.
I will do this and let you know tomorrow, Sundar.
Volkan
