Sub Interfaces on E1
Kaushik Ray
Hello
I need to create two point to point links between two routers connected via E1.
They need to be in separate VRFs for my requirement.
Is there any way I can create that on an E1 interface? Please let me know.
Many Thanks in advance.
Kaushik.
2 Accepted Solutions
Giuseppe Larosa
Hello Kaushik,
I have used fractional E1 in the past for this kind of scenario.
you can use fractional E1 for this, under controller e1 you can define more then one channel-group, each of them with different timeslots associated. Two different serial interfaces are generated from this
controller e1 x/y
channel-group 1 timeslots 1-15
channel-group 2 timeslots 17-30
(check the syntax of the commands above it may be different)
this generates two serial interfaces
serx/y:1
serx/y:2
you can associated the first to VRF1 and the second to VRF2 do this on both routers and use appropriate addresses.
To be noted this provides a fixed division of resources ( 64 kbps timeslots) between the two derived serial interfaces.
Hope to help
Giuseppe
Hello Kaushik,
thanks for your kind rating.
yes in your case you can split the timeslots in an asymmetrical way to provide more bandwidth to user traffic.
Hope to help
Giuseppe
6 Replies 6
Giuseppe Larosa
Hello Kaushik,
controller e1 x/y
serx/y:1
serx/y:2
Hope to help
Giuseppe
HI Giuseppe
Thanks a lot for your reply.
One VRF is for management and the other for main traffic. So is it worthile to split timeslots as 1-28 and 29-30 to have the max bandwidth available for the traffic?
Hello Kaushik,
Hope to help
Giuseppe
Thanks a lot again!
hi Giuseppe
Dec  6 10:12:01.199 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to up
Dec  6 10:12:01.207 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to down
Dec  6 10:12:05.231 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to up
Dec  6 10:12:05.243 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to down
Dec  6 10:12:09.263 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to up
Dec  6 10:12:11.283 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to down
Dec  6 10:12:15.311 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to up
Dec  6 10:12:17.335 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to down
Dec  6 10:12:21.359 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to up
Dec  6 10:12:21.371 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:1, changed state to down
I created but one of the slots is fluctuating .. at the moment the connection is just back to back; i split the slot as 1-29 and 30-31; should i change the slots to 1-28, 29-31 for bandwidth; could it be a bandwidth issue?
Answered in new thread
in any case the bandwidth should not matter
Best Regards
Giuseppe
