suggest model
ajayrajendra112
Kindly Suggest model for below mentioned product.
Technical Specification 24 Port Switches
Physical Interfaces
? 24 ports Fast Ethernet RJ45 Full Duplex with optional PoE support and optional K.21
Protection with Two SX GBIC Multi Mode Module fitted.
? 2 SFP Gigabit Ethernet Optical ports
? 2 ports 10/100/1000 Ethernet RJ45 Full Duplex
Power Supply
? Fixed PSU
? -48V DC / Universal AC Input (110-230V,
50-60Hz)
Dimensions
1U 19? Rack Mountable
VLANs
? IEEE802.1q, 4096 VLANs supported
? GARP, GVRP support
? IEEE802.1v Port/Protocol Based VLAN
support
Quality of Service
? QoS at VLAN level
? IEEE802.1p Class of Service
Power Over Ethernet (PoE) (Optional)
? -48V DC up to 15.6W on each port
? In DC Power Supply model only
Security
? Port Isolation (Protected Port Support)
? IEEE 802.1x Port based Authentication
? RADIUS Client Support
? DHCP Relay and DHCP Option 82
Management
? Telnet, SSHv2
? Industry Standard CLI (with multiple user access)
? Port mirroring for debugging & monitoring
2.
Technical specification Distribution Switches
􀂃 1 Rack unit with 12 SFP ports and throughput up to 1Gbps fitted with one LX/LH Transceiver Single Mode Module and six SX Transceiver Multi Mode Modules.
􀂃 QOS, IP Base Service Image IOS, Routing at access Layer.
􀂃 Adaptive Real-Time RF management.
􀂃 Layer 2 and layer 3 securities with multiple Extensible Authentication Protocol.
􀂃 VLan and Support up to configuration of 1005 VLans.
􀂃 Policy Control with Admission Control.
􀂃 Managed through Command Line Interface as well as Graphical User Interface.
􀂃 Spanning-Tree Configuration with Redundancy for Fault Backup.
􀂃 TACACS + and Radius Authentication.
􀂃 Port Security, Bandwidth Management, IGMP Filtering.
􀂃 802.1Q Tagging, VTP for Dynamic Trunk Configuration.
􀂃 Remote Switch Port Analyzer (RSPAN)
􀂃 Compatible with SNMS Software?s.
􀂃 Configurable up to 12,000 MAC addresses.
􀂃 Configurable up to 20,000 unicast routes.
􀂃 Power supply supports input voltages between 100 and 240VAC.
􀂃 Per-port status LEDs: link integrity, disabled, activity, speed, and full-duplex indications.
􀂃 System-status LEDs: system, RPS, and bandwidth-utilization indications.
􀂃 TFTPv2 for software updates
􀂃 SNMP v1/v2/v3
􀂃 Telnet, SSHv2
􀂃 Industry Standard CLI (with multiple user access)
􀂃 Port mirroring for debugging & monitoring
􀂃 Dual Application Image support
􀂃 Dual Configuration support
􀂃 Trusted Manager List
sandy3006
hi ajay can tell me is this any setup u going through
