el 06-27-2019 12:33 PM
Configure and install a summary route on R01 to allow PC1 to reach all networks on R02, R03, & R04
¡Resuelto! Ir a solución.
el 06-27-2019 01:52 PM
R01
interface Serial0/0/0
ip address 1.55.1.1 255.255.255.252
interface GigabitEthernet0/1
ip address 10.10.55.1 255.255.255.240
R02
ip address 1.55.1.2 255.255.255.252
interface GigabitEthernet0/0
ip address 10.55.20.1 255.255.255.0
ip address 10.55.22.1 255.255.255.0
R03
ip address 10.55.22.2 255.255.255.0
interface Loopback1
ip address 10.55.23.1 255.255.255.0
R04
ip address 10.55.20.2 255.255.255.0
interface Loopback1
ip address 10.55.21.1 255.255.255.0
el 06-27-2019 12:43 PM
what is your question ? The summary route is in your screen capture. If you need a static route:
R01#conf t
R01(config)#ip route 10.55.20.0 0.0.3.255 10.55.1.2 <-- this needs to be the IP address of interface Serial0/0/0 on R02
Or are you supposed to use a routing (which) protocol ?
el 06-27-2019 01:35 PM
am trying to figure what will be the ip for each routers from R1 TO R4
R01
R02
R03
interface Loopback1
R04
interface Loopback1
el 06-27-2019 03:15 PM
el 06-27-2019 03:18 PM
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
