SUP 2T and WISM or WISM2
techdata
SUP 2T Compatible with WISM ?
On the Data Sheet the Sup 2T claims to support with the WISM  tried to configure in Dynamic Configuration Tool came back as incompatible with  each other  on a 6513-e chassis.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps11878/data_sheet_c78-648214.html
Does anyone know if this is or not compatible. Originally preferred the WISM2 but will settle for the WISM
Leo Laohoo
Yes.
WiSM-2 is CHEAPER then WiSM-1.  WiSM-2 is faster.
Gentlemen,
I have the same issue.....
Is the SUP 2T compatible with WISM-2 ?
The Q&A for the Sup-2T mentioned it is compatible, while on the dynamic configurator, it isn't !
Can anybody help?
It is compatible.
