09-08-2012 10:04 PM - edited 03-04-2019 05:31 PM
Hi All,
Any one come across following error meassage. When i upgrade the IOS 122-33.SRE6 (SUP 720-3B), once the SUP card bootup this error meassage "%ICC-5-HUGE_BUFFER: Class [RPC ]" appear. i gone through the release note do not see any related error meassage. Any advise!
%ICC-5-HUGE_BUFFER: Class [RPC ] with Request id 0 requested a huge buffer of Size 65020
==== ICC HUGE Buffer Usage Stats and Traceback ====
Class Name Count Size TRACEBACK
2 RPC 2 65020 -Traceback= 42B042FC 42C8FCF4 422C6EC8 422BB638 422CAB20 422CC6E0 4075CF80 4075D310 4075D410 40BAD7D4 40BA82D0
Rgds,
09-10-2012 03:04 AM
Hello Attnnshtoon,
besides this error message, is the system able to boot up and to run the new IOS image ?
This might be a software bug as a traceback is produced. the system buffers are used to hold packets that are destinated to main cpu. Here there has been a request for a packet of size 65020 bytes too big to be allocated.
Does the message appear only once or multiple times? if multiple times with what frequency?
Again, if the system is up and running you may be fine for the moment if the error message is rare.
You may want to open a service request to Cisco TAC if error frequency is high.
Hope to help
Giuseppe
09-10-2012 05:50 AM
Ans: whenever reboot the SUP card rebooted, this message appears .After that i did not see agian.
Left it run this system overnight. Next morning when i was checked all services are what i expected.
Base on your experience , could you advise me how to conclude this matter?
Br
09-10-2012 08:24 AM
Hello Attnnshtoon,
if error message appears only once at reboot you should be able to deal with it. It should be a simple "don't care"
I would not for the moment do anything more, the system is up and running and you should be able to add it to production network
Hope to help
Giuseppe
09-11-2012 05:56 PM
Okay.. Just wanted to understand, Generally which is make it to Generate Traceback?
09-13-2012 02:31 AM
Hello Attnnshtoon,
a traceback is produced when a software error occurs. This is usually the symptom of a SW defect/bug
Hope to help
Giuseppe
09-13-2012 06:02 PM
Thanks for your info..
