switch 2960
sajjad_m1987
hello Dears
can somebody help me
i tired searching for the differences between switch 2960G and 2960S..
thanks
Leo Laohoo
2960S = The "S" means STACK.
2960G = The "G" means GigabitEthernet ports (all of them) and CANNOT be stacked.
thanks Leo
only this different ?
thanks
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
That's the major difference, but there might be others.  You can compare their datasheets.  Other possible differences might be in 10g port support and/or PoE wattage, etc.  There might be some subtle internal differences too.  The 2960S series is a later variant.  The 2960G might also be end-of-life or end-of-sale too.
Exactly what are you trying to achieve?
Unless we know what is required, we can go on-and-on about the minor/major differences between 2960G vs 2960X.
Tell us what is required and maybe we'll go straight to the answer needed.
