Switch 3750
mdehsan230564
Dear Sir,
My pc are connected to a cisco 3750 switch. Switch is configured as vlan1 ip address as 10.42.4.1 255.255.255.0 primary.
And 10.42.8.1 as secondary.
PC default gateway = 10.42.4.1 and PC are getting application access through switch configure tunnel to a router.
Now the same switch 3750 i connected a another router to for internet.
since PC default gateway is to the internet router that is why i am not getting internet.
I configure my internet router LAN ip = 10.42.8.2.
What configuration in my Switch 3750 should i configure so that even PC default gateway is 10.42.4.1 not 10.42.8.1.
so that i should get internet as well as access my application.
Since my application only works if the default gateway is 10.42.4.1
Can I configure as :-
ip route 0.0.0.0 0.0.0.0 10.42.8.2 and it will solve my problem.
Thanks and best regards.
post the full running configurations (sh run) of both the router and the switch...
A diagram showing the topology would be helpful. I am not clear about
can you clarify about this?
Is ip routing enabled on this 3750? If so then please post the output of show ip route. Is vlan 1 the only vlan or are there other vlans?
Rick
Giuseppe Larosa
Hello @mdehsan230564 ,
I think you need to have ip routing enabled to perform inter VLAN routing even if in this case the routing is between primary and secondary address.
You need on C3750:
conf t
ip routing
Please note that the internet router may need the following:
on internet router :
a static route for subnet
ip route 10.42.4.0 255.255.255.0 10.42.8.1
and NAT configuration needs to be updated to include the 10.42.4.0/24 subnet
access-list 111 remark NAT
access-list 111 deny ip 10.42.4.0 0.0.0.255 10.42.8.0 0.0.0.255
access-lis 111 deny ip 10.42.8.0 0.0.0.255 10.42.4.0 0.0.0.255
access-list 111 permit ip 10.42.8.0 0.0.0.255 any
access-list 111 permit ip 10.42.4.0 0.0.0.255 any
ip nat source inside list 111 interface <WAN> overload
Hope to help
Giuseppe
