Switch 4948 reboot after applying route-map
mataalfredo
Hello all,
I'm trying to apply the following policy route in my switch 4948, but it suddenly crash. Is anything wrong in my commands? The switch is rebooting with an error:
System returned to ROM by abort at PC 0x0
My commands are:
access-lists 7 permit 10.140.22.0 0.0.0.255
access-list 177 permit ip 10.140.22.0 0.0.0.255 100.220.24.0 0.0.0.255
access-list 177 permit ip 10.140.22.0 0.0.0.255 100.216.36.0 0.0.0.255
access-list 177 permit ip 10.140.22.0 0.0.0.255 100.216.38.0 0.0.0.255
route-map client1 permit 5
match ip address 177
set ip next-hop 10.1.20.158
route-map client1 permit 10
match ip address 7
set ip default next-hop 10.1.20.158
interface GigabitEthernet1/36
ip policy route-map client1
Thanks for your help.
12 Replies 12
Reza Sharifi
Even if there was something wrong with your config, the switch should not reboot.  It might be a bug in the IOS that triggers the reboot when you apply the access list.  What version of IOS are you running?
Here is the info of IOS version.
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(46)SG, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 27-Jun-08 16:24 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11E3C0D8
ROM: 12.2(31r)SGA1
Dagobah Revision 226, Swamp Revision 5
Leo Laohoo
This information doesn't give much detail.
If the switch crashed and reboot, you should have a crashinfo file(s).  Post these.
Thank you, I will try to get the info from the crash file.
By the way is the route-map well configured?
The route-map has been applied, but is not working. I can see matches  in ACLs and also using route-map command but the router is ignoring the  route map.
Post the output from typing "show ip route 10.1.20.158, show ip route 10.140.22.0" and also "show run interface g1/36"
Thanks for your help. Here is the info:
LAN network is 10.140.22.0
MAN-01#sh ip route 10.140.22.0
Routing entry for 10.140.22.0/24
  Known via "static", distance 1, metric 0
  Redistributing via eigrp 69, eigrp 502, eigrp 128, ospf 1
  Advertised by eigrp 69 metric 1000000 1 255 1 1500
                eigrp 502 metric 1000000 1 255 1 1500
                ospf 1 subnets
  Routing Descriptor Blocks:
  * 10.1.10.186
      Route metric is 0, traffic share count is 1
MAN-01#sh ip route 10.1.20.158
Routing entry for 10.1.20.156/30
  Known via "connected", distance 0, metric 0 (connected, via interface)
  * directly connected, via Tunnel7
MAN-01#sh run int gi 1/36
Building configuration...
Current configuration : 313 bytes
no switchport
ip address 10.1.10.185 255.255.255.252
qos trust dscp
tx-queue 3
   bandwidth percent 33
   priority high
   shape percent 33
spanning-tree portfast
service-policy output VoIP-Qos-Policy
end
Interesting.. multiple routing instances...
                ospf 1 subnets
Your PBR config looks fine and I found some bugs affecting 12.2(46)SG which may be impacting you, here is one:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsr54959
Can you upgrade the code and try testing again?
I also wonder if the next-hop being a tunnel may be causing an issue here.
Thank you Edison, let me check.
The route map is not working with static IPs in the router.
Do you think is a bug or is a normal behavior?
You mean the source subnets are known via static? I don't think it makes a difference how the source is known but it needs to ingress the interface where the PBR is applied to.
46SG has several PBR related bugs thus I recommend upgrading to a safer code such as 12.2(53)SGx where x represents the train revision.
Hi Edison,
Just suffered from the same bug in a C4507 platform. Cisco says it was resolved in
12.2(50)SG but they are not recommending any certain release. Do you still recommend 12.2(53)SG instead?
Alex
