Showing results forĀ
Search instead forĀ
Did you mean:Ā
system mtu routing not found cisco IE 3200
jesperb87
When i trying to use system mtu routing  on a Cisco IE 3200 I get a message that tells me routing is not found. Have cisco delete this? and should I only use system mtu and skip the routing?
DanielP211
You should be able to set system mtu on the IE3200. Try first enabling ip routing.
****Kindly rate all useful posts*****
