T1 CSU testing question
dstjames123
I just purchased 2 cisco 1841 routers with csu cards in them to connect a remote office through a T1. I have them setup but I am by no means a cisco expert. I would like to test them here before I ship one of them to our remote office. When I connect the 2 routers with a straight through or crossover cable all I get is a yellow alarm light on the csu card. Is there any way to connect these so I can confirm everything is setup correctly before I ship the one?
adam.sellhorn
Level 4
Level 4
You will need to make a T1 crossover cable.
pins 1,2 to 4,5
http://www.ldfacts.com/faq_files/How-to-Make-a-T1-Crossover-cable.htm
Thank you very much. I will give it a try.
Rick Morris
Level 6
Level 6
As stated below the cross over cable will allow connection between the two routers. You can put on a basic config to run a live test. Something basic is all that is needed:
Router A
inter s0/0 (or whatever interface it is)
ip address 10.1.1.1 255.255.255.252
no shut
ip route 0.0.0.0 0.0.0.0 s0/0
Router B
inter s0/0
ip address 10.1.1.2 255.255.255.252
no shut
then try to ping across from router to router. But to keep it even more simple, if the line comes up then you are good, just do a no shut on the interfaces once the cable is plugged in and do a sh ip int brie to see if the interfaces are up or not.
