T1 Usage
aukes
I have a Cisco 2811 and we are trying to solve a bandwidth usage problem. Is there a way to determine what host IP is using all the bandwidth on the Serial port?
Richard Burts
Allen
Probably the easiest way to determine that is to configure NetFlow on the router. NetFlow will generate statistics that will identify addresses, protocols, and amount of traffic. It would be especially interesting to configure the option in NetFlow to identify the Top Talkers. This link has information about this:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00805e11ab.html
It seems that it would be just what you need.
Rick
Rick
Richard Burts
Allen
Rick
Rick
Allen
I am glad that my suggestion was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read about a question and can know that they will read a response that resolved the question.
I encourage you to continue your participation in the forum.
Rick
Rick
