TCL Script to reset interface
billobob123
Hi all
I've been searching for a way to have the router check the status of the dialed and if it's not responding and or down to have a TCL scrip reset the interface.
Is this possible?
6 Replies 6
andrew.prince
Level 10
Level 10
EEM would also serve the purpose.
I have a similuar  TCL  script but for PPPoE dialer and it just checks if the VI interface  in UP status and tries to reset the assotiated physical interface if it's in DOWN status.
Umm okay I would be interest in having a look
Marwan ALshawi
i recomnd you sereach the fourm in the network managment section and if you cant find it then put your post there
good luck
it's quite "rough" as it was "developed" for a test  purpose but went in production
You can assign it the even manger and serach in logging or, as we do it, just call it very 10 minutes from event manager.
#create flash file
after 30000
#::cisco::eem::event_register_syslog maxrun 60
#namespace import ::cisco::eem::*
#namespace import ::cisco::lib::*
#get all lines in PADISNT  status
set sh_pppoe_ses [ split [ exec "show pppoe session | i PADISNT" ] "\n" ]
foreach line $sh_pppoe_ses {
if { [ llength $line ] > 0 } {
#Find the according Vi interface and it Vlan interface
if { [ regexp {Vl[0-9]+} [ lindex $line 3 ] ] } {
set result [regexp {Vl([0-9]+)} [ lindex $line 3 ] match IF ]
#Find the all existing Vlan
set  sh_int_sta [ split [ exec "sh vlan-sw bri | e unsup"] "\n" ]
#Find the Phisycal  interface assotiated with a VLAN interface which assotiated with the Vi interface
foreach line_sta $sh_int_sta {
  if { [ llength $line_sta ] > 0 } {
   if { [ regexp "$IF" [ lindex $line_sta 0 ] ] && [ regexp "active" [ lindex $line_sta 2] ] } {
     set LENGTH [ expr  [ llength $line_sta ] - 1 ]
     set result [regexp {(Fa[0-9]+)} [ lindex $line_sta $LENGTH ] match FA ]
     set syslog [open "syslog:" w+]
     puts $syslog "%Reset-PPP-Int-TCL shutting down interface $FA"
     flush $syslog
     ios_config "interface $FA" "shutdown"
     after 10000
     puts $syslog "%Reset-PPP-Int-TCL starting interface $FA"
     ios_config "interface $FA" "no shutdown"
     close $syslog
#Find the according Vi interface and its Phisycal interface if PPPoE
#is directly configured on a phisycal interface
if { [ regexp {Fa[0-9]+} [ lindex $line 3 ] ] } {
set result [regexp {Fa([0-9]+)} [ lindex $line 3 ] match IF ]
set FA "Fa$IF"
flush $syslog
after 10000
close $syslog
set IF ""
set FA ""
Thanks I'll give it a shot and let you know how things go
