Template for Zone based firewall
M Tech
Hello Expert,
I am looking for a template configuration for a zone based firewall to be applied on ISR 4300 series router. If there is anyone who could share a sample config file for ZBF, that would be very much appreciated. We just need a config that allows VPN connection from outside WAN port and  everything from inside to out. There are just two interfaces WAN and INSIDE.
Thank you so much in advance,
M02@rt37
Hello @M Tech
Do you see that little guide ?
https://community.cisco.com/t5/security-knowledge-base/zbfw-recommended-configuration-and-template/ta-p/3108955
Best regards
Blue_Bird
Hello  M Tech,
Please go through the link which will guide you to setup zone-based firewall (ZBF):
https://community.cisco.com/t5/security-knowledge-base/zone-based-firewall-implementation/ta-p/5071755
Best regards
******* If This Helps, Please Rate *******
