Terminal Server or Console server
gautamzone
Hi friends,
I am looking for a 2800 router working as a Terminal server or console server.
I need console connections to 4 Cisco devices from the terminal server and the terminal server also needs to have the capability to dial in.
I am not clear about which wic/hwic would be suitable to meet this requirement? Will hwic-4a/s suffice?
Also, i read that the old routers used octal cable that had 8 RJ-45 plugs to connect to router consoles. I am not sure if i can use the same octal cable even in 2800 routers.
For dial-in, i believe that a modem connected to an AUX port should be good enough on the terminal server? Or is there any other better option?
Looking forward to your kind suggestions
Thanks a lot
Gautam
6 Replies 6
ankbhasi
Hi Gautam,
I believe this link should help you
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps6182/product_data_sheet0900aecd80274416.html
Ankur
*Pls rate all helpful post
vaisharm
Hi Gautam,
You can use HWIC-8A w/ CAB-HD8-ASYNC which has 8 RJ-45 connectors.
~Vaibhav
Thanks a lot for the info.
So it means, that i will use only one port on the hwic-8a. This one physical port on hwic-8a is good enough to provide connectivity to 8 devices. Right?
Also, what about the dial-in options? Can the same hwic be used? I believe that the same hwic can be used with the same cable but i may need an adapter viz. CAB-25AS-MMOD. Please let me know if that would be the right option? thanks a lot
Useful artical which may well help your cause and cheaper :)
http://www.petri.co.il/how-to-configure-cisco-router-as-terminal-server.htm
Thanks for this article. But i still wanted to confirm that will this cable CAB-HD8-ASYNC consume just one port from the 8 ports to manage 4 devices out of band.
Also, for the dial in option for this router, i wanted to know if we can use the AUX port on terminal server for connecting to external modem or can we use a port on the hwic-8a card itself and if yes, what will be the right cable / adapter for this purpose?
Thanks a lot
Gautam
Gautam,
That's correct. The 8-Port Asynchronous High-Speed WAN Interface Card use one (HWIC-8A) high-density 8-port connectors. The 8-port asynchronous cable provides the high-density connector on one end and eight RJ-45 plugs on the other. RJ-45- to DB-25 modular adapters are used to convert the RJ-45 to DB-25 DTE or DB-25 DCE connections.
For information on connecting an external modem and the exact cable/connector types needed, refer to the following documents:
Modem-Router Connection Guide
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a008009428b.shtml
Sync-Async Ports for Async Modem Dial-in On Cisco 1600, 1700, 2600, and 3600 Platforms
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a00801d2576.shtml
~Vaibhav
