TFTPnld command
Rupesh Kashyap
I have 6509 Switch having 48 ethernet ports. The IOS is crashed.
Can you tell me how can I transfer the IOS from tftp to rommon mode of switch.
Mark Yeates
Level 7
Level 7
Rupesh,
I don't believe the TFTPdnld is supported in the 6500 in rommon. You should be able to use xmodem. Here are instructions on how to do that.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml#recprocedure
HTH,
Mark
