Dear Experts,
kindly update me with the cisco switch models which can give Throughput 200mpps (Million Packets Per Second) or kindly also suggest what are the models of switches which supports that much throughput after STACKING.
Or any Relevant information Kindly do share.
Waiting for the valued response.
Not enough info.
Do you need copper or SFP?
What is your budget?
What are you trying to do?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A 48 port 3750X, with dual 10g, is rated at 101.2 Mpps, so two of those stacked would meet your 200 Mpps requirement. The newer 48 port 3650 (also stackable) is rated at 104.16 Mpps with dual 10g and 130.95 Mpps with quad 10g. The newer 48 port 3850 (also stackable) is also rated at 130.95 Mpps for quad 10g. There's also other 3850 models (again also stackable) with 200 Mpps+ ratings (per one unit):
WS-C3850-24XU | 500 Mpps (80B packets) |
WS-C3850-12X48U | 460 Mpps (64B packets) |
WS-C3850-12XS | 227.28 Mpps |
WS-C3850-24XS | 454.55 Mpps |
There's often more involved in selecting a switch, for some purpose, than just it's PPS rating.
