Time Based Access List
umeshgurav
Dear All
I have a lease line as primary and Vsat as backup link to a remote branch,with the lan ip range 130.12.1.101. We have internet access to the remote user via proxy .I want to restrict a block of host to access the internet at particular time .These host shud be able to access internet everyday between 8.00 am to 10.00 am in morning and 18.00 to 20.00 hrs in teh evening .
Kindly help me to configure this.
Umesh
Goutam Sanyal
Level 4
Level 4
Hi Umesh,
Please do the following:-
login to router-> conf t->
#time-range [name_locally]
#periodic daily [start_time] to [end_time]
Access-list configuration
#ip access-list extended [name_of _access-list]
#permit tcp [your_required_network] [netmusk] [proxy_ip_address] time-range [name_locally]
Apply it to the required interface.
For PIX, do the following:
#time-range entry: [name_time_range] (active)
periodic daily 10:30 to 11:00
periodic daily 13:00 to 14:00
periodic daily 17:00 to 18:00
#access-list acl_in line 77 extended permit ip host [proxy_ip_address] any time-range
#access-list acl_in line 77 extended permit ip host [proxy_ip_address] any time-range [name_time_range]
Goutam [pls rate if it works]
umeshgurav
time-range internet
periodic weekdays 9:00 to 18:00
ip access-list extended strict
deny tcp any host 172.16.0.1 time-range internet
interface FastEthernet0/0
ip access-group strict in
Above is the router configurations but the access list says inactive.
Please help
Dear Umesh,
Please inform that whether are you using any NTP clock source? If yes, then pls confirm that your router is properly connected with NTP server / source. Else it will not work properly.
If the router is using local time then it will active as per the mentioned time, otherwise it will show inactive.
Also please try the following:
1.deny tcp any host 172.16.0.1 [port_number_for_your_proxy] time-range internet
2.int serial [interface number]
3.ip access-group strict out
[Your mail has been replied with the same]
Goutam
