Too much OSPF routing
james.king14
Beginner
Beginner
I have a scenario in which I am kind of stuck and wondering if anyone can give me the best advice on how to accomplish it.
Topology is as below:
WAN setup:
Router[R1] -> connected to Core Switch 1 [CSW1] via 1G Link
Core Switch 1[CSW1] -> Connected to ASA 1 [asa1] via 1G Link
Remote Router[R1-100] -> Connected to ASA 1 [ASA 1] via IPSEC VPN Link
Each router within the WAN has the same OSPF area 0 information.  With different links to each remote site.  Can we use route summarization to ensure connectivity but also stop making the routers use a lot of resources.
1 ACCEPTED SOLUTION
Mark Malone
Mentor
Mentor
Hi If each router is in Area 0 then no you cannot summarize as OSPF is a link state protocol and each router must contain the same LSDB
You can filter at the ABR or ABSR with OSPF using the area range or summary-address filters
The only other way is to prevent LSAs going to another router but this will cause routing issues in the same area
In what way is this causing an issue there may be another fix if you can provide further details ?
1 REPLY 1
Mark Malone
Mentor
Mentor
