tos / precedence value
rabeder
Level 5
Level 5
hi,
how to map tos-value to ip-prec value ??
dos it mean if i have a packet with a tos of 5 (00000101) ist this the ip-prec-value of 5 as well???
i mean the tos field is 8 bit long, the ip-prec value is a subset of the tos field - is this right - and it has 3 bit
(the 3 low order bit)
- right ????
mheusinger
Level 11
Level 11
the TOS byte contains the three IP precedence bits (7 6 5 - HIGH order bits). So IP precedence 5 is TOS=160 (10100000) or IP precedence 2 equals TOS 64.
You can check this also with an extended ping, which allows to set TOS bytes.
Hope this helps
Martin
