05-28-2014 07:12 AM - edited 03-04-2019 11:03 PM
Hi all
hitting the issue that the device reloads after issueing "sh policy-map type inspect zone-pair"
Patrick
For image:
Cisco IOS Software, ISR4400 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(2)S, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 26-Mar-14 21:38 by mcpre
Uptime = 00:09:36
Happens in isr4400-universalk9.03.12.00.S.154-2.S-std.SPA.bin and isr4400-universalk9.03.11.01.S.154-1.S1-std.SPA.bin.
CMD: 'h policy-map type inspect zone-pair'' 15:25:08 CET Fri May 23 2014
Exception to IOS Thread:
Frame pointer 0x7FE738ADCE70, PC = 0x2824D9F
UNIX-EXT-SIGNAL: Segmentation fault(11), Process = SSH Process
-Traceback= 1#0f900c654b45d2459c0c267ce51d6164 :400000+2424D9F :400000+974FE12 :400000+974FAB8 :400000+974F5E2 :400000+27A9BB0 :400000+28297C6 :400000+281182C :400000+2810189 :400000+975962A :400000+9759522 :400000+98645DA :400000+975991D :400000+AC061C :400000+ABF735 :400000+ABDAAD :400000+3FCC510
Fastpath Thread backtrace:
-Traceback= 1#0f900c654b45d2459c0c267ce51d6164 c:7FE7877A2000+BE012
Auxiliary Thread backtrace:
-Traceback= 1#0f900c654b45d2459c0c267ce51d6164 pthread:7FE782EFD000+A7C9
RAX = 00007FE738ADCEC4 RBX = 00007FE735F40608
RCX = 0000000000000001 RDX = 000000000000001F
RSP = 00007FE738ADCE70 RBP = 00007FE738ADCE70
RSI = 0000000000000000 RDI = 00007FE738ADCEC4
R8 = 0000000000000001 R9 = 0000000000000000
R10 = 0000000000000002 R11 = 0000000000000002
R12 = 000000000000001D R13 = C88E990B00000000
R14 = C4CEAD38E77F0000 R15 = A0ED3436E77F0001
RFL = 0000000000010202 RIP = 0000000002824D9F
CS = 0033 FS = 0000 GS = 0000
ST0 = 0000 0000000000000000 ST1 = 0000 0000000000000000
ST2 = 0000 0000000000000000 ST3 = 0000 0000000000000000
ST4 = 0000 0000000000000000 ST5 = 0000 0000000000000000
ST6 = 0000 0000000000000000 ST7 = 0000 0000000000000000
X87CW = 037F X87SW = 0000 X87TG = 0000 X87OP = 0000
X87IP = 0000000000000000 X87DP = 0000000000000000
XMM0 = 00000000000000000000000000000000
XMM1 = 00000000000000000000000000000000
XMM2 = 00000000000000000000000000000000
XMM3 = 00000000000000000000000000000000
XMM4 = 00000000000000000000000000000000
XMM5 = 00000000000000000000000000000000
XMM6 = 00000000000000000000000000000000
XMM7 = 5C5C5C5C5C5C5C5C5C5C5C5C5C5C5C5C
XMM8 = 36363636363636363636363636363636
XMM9 = 36363636363636363636363636363636
XMM10 = 5C5C5C5C5C5C5C5C5C5C5C5C5C5C5C5C
XMM11 = 5C5C5C5C5C5C5C5C5C5C5C5C5C5C5C5C
XMM12 = 00000000000000000000000000000000
XMM13 = 00000000000000000000000000000000
XMM14 = 00000000000000006F6F6B6B67676767
XMM15 = 00000000000000000000000020202020
MXCSR = 00001F80
05-28-2014 07:36 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe tracebacks are normally indicative of a bug. This might be something more suitable to raise with TAC.
06-25-2014 06:48 AM
Yes correct have to raise a tac case-
