trace route
mahinccnp
there is ospf running in my network and when I check routing in distribution switch I can see multiple paths, but when I trace route from l2 access switch I cant see mutiple path , but when I try trace route from l3 distribution switch I can see multiple path ..why ?
Sandeep Choudhary
Here is the guideline for layer 2 traceroute:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/l2trace.html
ospf dont work on layer 2 , it works on layer 3 or 4.
So layer 2 switch will not show the all path.
Hope it helps.
REgards
Please rate if it helps.
