I have 2 Catalyst 6509 Switches that Im trying to bring up and MPLS VPN connection between. The loopbacks can ping each other, as well as the directly connected interfaces (the interfaces travel through 2 switches, but no routing etc in between). An OSPF neighbor relationship DOES come up, and the routing tables appear normal. However, the MPLS VPN does NOT come up.
After further review, I found that the routing tables are correct on either side for the loopbacks (public addresses X’d out on first 3 octets):
SWITCH A:
Bryan-26th-CAT-2#sh ip route 10.255.2.2
Routing entry for 10.255.2.2/32
Known via "ospf 23532", distance 110, metric 2, type intra area
Last update from X.X.X.70 on Vlan65, 00:10:25 ago
Routing Descriptor Blocks:
* X.X.X.70, from 10.255.2.2, 00:10:25 ago, via Vlan65
Route metric is 2, traffic share count is 1
SWITCH B:
DAL-COLO-6509-1#sh ip route 10.255.2.3
Routing entry for 10.255.2.3/32
Last update from X.X.X.69 on Vlan65, 02:26:50 ago
* X.X.X.69, from 10.255.2.3, 02:26:50 ago, via Vlan65
This is exactly the same for the directly connected interfaces on VLAN65. (X.X.X.69 and X.X.X.70). The ARP cache also shows to be correct:
SWITCH A:
Bryan-26th-CAT-2#sh arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet X.X.X.70 147 0009.b6a4.b800 ARPA Vlan65
Internet X.X.X.69 - 001c.b144.5800 ARPA Vlan65
SWITCH B:
DAL-COLO-6509-1#sh arp
Internet X.X.X.70 - 0009.b6a4.b800 ARPA Vlan65
Internet X.X.X.69 141 001c.b144.5800 ARPA Vlan65
And once again, the OSPF Neighbor relationship does come up:
SWITCH A:
Bryan-26th-CAT-2# sh ip ospf neigh
Neighbor ID Pri State Dead Time Address Interface
10.255.2.2 1 FULL/BDR 00:00:30 X.X.X.70 Vlan65
SWITCH B:
DAL-COLO-6509-1#sh ip ospf neig
10.255.2.3 1 FULL/DR 00:00:33 X.X.X.69 Vlan65
In the Troubleshooting MPLS VPN manuals- it shows to test trace routes. All of our other connections like this the trace routes work fine. In this case though, I cannot trace route not only between the loopback interfaces, but between the DIRECTLY CONNECTED interfaces. I don’t know what this is. It should simply be a one hop trace route. I believe this is what is keeping the MPLS VPN from coming up. Any ideas? Here are the relevant OSPF configs and interface configs as well:
SWITCH A:
interface Vlan65
description Connection to DAL-COLO-6509-2
mtu 1580
ip address X.X.X.69 255.255.255.252
no ip redirects
no ip unreachables
ip pim sparse-dense-mode
ip ospf mtu-ignore
mpls label protocol ldp
mpls ip
router ospf 23532
log-adjacency-changes
redistribute connected subnets
redistribute static subnets
passive-interface default
no passive-interface Vlan65
network 10.255.2.3 0.0.0.0 area 0
network X.X.X.69 0.0.0.0 area 0
SWITCH B:
interface Vlan65
description Connection to Bryan-26th-CAT-2
mtu 1580
ip address X.X.X.70 255.255.255.252
no ip redirects
no ip unreachables
ip ospf mtu-ignore
mpls ip
router ospf 23532
network 10.255.2.2 0.0.0.0 area 0
network X.X.X.70 0.0.0.0 area 0
Any ideas would be appreciated.
Greg
Solved! Go to Solution.
Hello Greg,
in order to be able to traceroute you need to enable the sending of ICMP unreachables back to the traceroute sender.
use
int vlan 65
ip unreachables
Hope to help
Giuseppe
Greg,
Can you explain more about your issue?. When you say MPLS VPN is not coming up, do you mean the ping (or traffic) from CE connected to one 6509 is not traversing the MPLS cloud to otehr CE connected to remote 6509?.
Do you have VRF enabled with respective RT import/export?. Do you have MP-BGP with VPNv4 AF enabled?.
To confirm if basic MPLS is working fine, Can you check if you have LDP neighborship up and running?. Use "show mpls ldp neighbor" to see the session.
Also do a "ping mpls ipv4 <remote-loopback> <mask>" and see if it works?.
-Nagendra
I have removed all BGP from the 6509 at this point until this issue is fixed. There is an OSPF neighbor relationship between the 2- we aren't talking about VRF's etc. This is simply now a directly connected interface over a vlan that cannot trace route to the other side. It can ping. The only devices with this VLAN are the 2 6509s. I can ping from one to the other. It's just not letting me trace route.
Hello Greg,
use
int vlan 65
ip unreachables
Hope to help
Giuseppe
