06-02-2007 06:26 AM - edited 03-03-2019 05:16 PM
I have 2 routers in my network.
172.16.0.0/12 - private intranet.
ple-rt#show ip route 172.28.23.1
Routing entry for 172.28.16.0/21
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
* 172.28.254.2
Route metric is 0, traffic share count is 1
ple-rt#traceroute 172.28.23.1
Tracing the route to 172.28.23.1
1 172.28.23.1 [AS 21017] 0 msec 0 msec 4 msec
ple-rt#traceroute 172.27.63.1
Tracing the route to 172.27.63.1
1 89.x.x.218 4 msec 0 msec 4 msec
2 172.27.63.1 [AS 21017] 0 msec 0 msec 4 msec
ple-rt#show run | b bgp
router bgp 15930
no synchronization
bgp log-neighbor-changes
network 89.18.128.0 mask 255.255.240.0
aggregate-address 89.18.128.0 255.255.240.0 summary-only
neighbor 80.82.34.77 remote-as 21017
neighbor 80.82.34.77 update-source GigabitEthernet0/1.904
neighbor 80.82.34.77 version 4
neighbor 80.82.34.77 send-community
neighbor 80.82.34.77 prefix-list peers-out out
neighbor 80.82.34.77 route-map setcommunity out
neighbor 80.82.63.250 remote-as 65530
neighbor 80.82.63.250 update-source GigabitEthernet0/1.202
neighbor 80.82.63.250 prefix-list wipline-net out
neighbor 172.16.0.1 remote-as 8981
neighbor 172.16.0.1 update-source GigabitEthernet0/1.15
neighbor 172.16.0.1 prefix-list wipline-net out
neighbor 213.129.97.165 remote-as 24923
neighbor 213.129.97.165 update-source GigabitEthernet0/1.900
neighbor 213.129.97.165 version 4
neighbor 213.129.97.165 prefix-list peers-out out
no auto-summary
ple-rt#show run | b router\ eigrp
router eigrp 100
network 89.x.x.216 0.0.0.3
no auto-summary
eigrp router-id 89.x.x.217
router eigrp 110
network 172.29.92.0 0.0.0.127
network 172.29.93.0 0.0.0.127
network 172.29.94.16 0.0.0.7
network 172.29.128.0 0.0.63.255
no auto-summary
eigrp router-id 172.29.94.18
question: Why does traceroute shows [AS 21017] for my private adresses?
06-02-2007 07:12 AM
Let me take a guess, are you using MPLS VPN, and the AS of your provider is "21017"?
BR,
Mohammed Mahmoud.
06-03-2007 09:37 PM
No, I'm not using MPLS VPN. 21017 is AS of my provider.
Probably, this is default route?
How can i fix it?
ple-rt#sh ip bgp 172.28.23.1
BGP routing table entry for 0.0.0.0/0, version 33343350
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Not advertised to any peer
21017
80.82.34.77 from 80.82.34.77 (80.82.57.79)
Origin IGP, localpref 100, valid, external, best
06-04-2007 03:32 AM
If not MPLS VPN then what kind of VPNs are you running here, a simple topology will help here.
Yes its a default route received from your provider thats why it is with his AS, this shouldn't be making any problems.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
06-04-2007 04:17 AM
There is no any VPN service. Just direct optic.
06-04-2007 04:42 AM
Do you mean that you have a direct link between your 2 routers ?
Can you please provide a simple topology diagram for all the connections that you have on both your routers.
BR,
Mohammed Mahmoud.
06-05-2007 05:58 AM
Hi!
ISP1(AS 21017) <-optic-> |Rtr A|<-optic->|Rtr B|
ISP2(AS 24923) <-optic->
This is primary link between my routers and my ISPs. Also I have reserve link via radio between my routers:
interface Tunnel0
description backup link on rtrA
ip address 172.29.94.38 255.255.255.252
ip mtu 1514
ip route-cache policy
ip route-cache flow
ip policy route-map comlink-gw
tunnel source 172.29.94.9
tunnel destination 172.29.94.1
!!!used for primary link
router eigrp 100
network 89.xx.xx.216 0.0.0.3
no auto-summary
eigrp router-id 89.xx.xx.217
!!!used for reserve
router eigrp 110
no auto-summary
