11-23-2022 01:33 AM
Hi all!
What are the differences between these two commands? Are these two the same or not?
Thanks!
Best regards
Solved! Go to Solution.
11-23-2022 01:38 AM
11-23-2022 01:38 AM
11-25-2022
03:31 AM
- last edited on
11-27-2022
11:07 PM
by
Translator
Hi Rookie R ,
- The major difference between the
Reachability and state ( Default Option )
command is that of the OverThreshold .
- You can track two aspects of IP SLAs operation: state and reachability. For state, if the return code is OK, the track state is up; if the return code is not OK, the track state is down. For reachability, if the return code is OK or OverThreshold, reachability is up; if not OK, reachability is down.
- While using the Reachability option we can specify a range of threshold and this range will be taken into consideration , in deciding if the reachability is up or down
