12-17-2023 03:23 AM
https://community.cisco.com/t5/routing/tracking-in-a-route-map/td-p/3898975
Reference to the discussion in the above link (btw its a very old discussion, that's why I decided to create a new one with reference), can someone please help me the work around solution implemented by the OP ? I tried to understand and do it but in vain, can someone please share the expected configuration. Thanks a lot.
12-17-2023 03:29 AM - edited 12-17-2023 03:31 AM
https://packetlife.net/blog/2008/dec/12/ospf-conditional-default-route-injection/
https://lpmazariegos.com/2016/04/13/ospf-conditional-and-reliable-conditional-default-routing/
It called conditional inject route
Check link above
MHM
12-17-2023 03:34 AM
Every environment different, we understand you pointed to other forum thread ? are you having same issue ?
what is your device ? and IOS code running ?
how is your configuration Looks like ?
after adding configuration what challanges and issue you encountered ?
what is not working ? can you post some output and your troubleshooting's ?
12-18-2023 05:25 AM
Hello
So are you wanting to implement conditional default route advertisement using rip?
As in the OP - you can utilise ipsla tracking and append that track to a false static route
Then create a prefix-list to match on that false route and tie the whole thing together within a route-map which then you append in the rip process using the default-information route-map feature.
12-19-2023 09:42 AM
I see you still confused about this tasks
Can you confirm if you use ospf or rib?
MHM
12-19-2023 09:55 AM
The focus of the discussion in the provided link was trying to use a route map with match track to control advertisement of a RIP route. Route maps can be used for many different things and matches that are valid for one purpose may not be valid for some other purpose. I believe that in a route map to control route advertisement that match track is not valid.
I believe that the suggestion from Paul is a very good way to achieve what you want.
