Traffic flow
Ibrahim Jamil
Level 6
Level 6
Hello Guys
pls find attachment
when the L2 Link Between  3750-X-1 and ASA-1 failed  , after that  traffic from/to hosts sits in ESXi will be blackholed as ASA-1 still Active node while ASA-2 in standby ( cant forward the traffic up and down , until the active one fail)
Adding 2 link from DMZ switches to each ASAs as a cross link seems properer design
pls Advise on the most proper design
Thanks all
10 Replies 10
nazimkha
Level 4
Level 4
Many possible design options :
1. From switch perspective, if you are using HSRP on 3750 switches you can change the HSRP state when the link is down using object tracking.
2.You can configure object-tracking/ IP SLA on the ASA to failover
3. You can add cross links but since the 3750 are not VSS or vPC capable you will not be able to port-channel them and use the aggregate bandwidth
For option 1 . the 3750 are just L2 switch , the GW for DMZ hosts is the ASA
For Option 2 , this is the DMZ interface down to L2 Switches
THANKS
In that case option 2 may be more suitable and you can monitor the interfaces. I am not an expert in ASA and cannot suggest the exact configuration. Probably moving this thread to the Security section will get better responses
balaji.bandi
Why not consider ASA as cluster design.
https://www.cisco.com/c/en/us/td/docs/security/asa/asa90/configuration/guide/asa_90_cli_config/ha_cluster.html
3750X is located in different location ? or same location, if same location why not stack them.
BB
yep
3750-X are  DMZ Switches , where the the DMZ Servers are connected
Is there any reason you are not considering Stacking them ?
BB
Does these 2 3750-X acts as 1 unit if i stack them , i mean do they becomes like similar to VSS
yes, they become 1 switch.
BB
Do you mean , 2 X Control plane and 2 x Data Plane
Switches in Stack, you will have 1 control plane.
suggest to understand Stacking concept, below information help you:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html
BB
