Traffic Forwarding
kr_madan
Hi Experts,
I would like to forward the traffic between 3845 and 7206.
the problem is that 3845 and 7206 does not have fiber ports so i am using 4506 to connect them.
PPT attached for the reference
By default the 4506 will not forward the traffic to each other.
What are the configuration change i need to do on the 4506 ?
This is an a urgent requirement . any help appreciated.
Thanks in advance
Madan.
rll3
Do you have a trunk configured on each 4506 with the only allowable vlan as vlan 999?
trunking should be configured on both sides and allow vlan 999 to forward to/from your core router.
thanks,
k0rg
michaelchoo
Cat4506 connected to 3845 (the right one):
vlan 999
interface gi4/13
switchport access vlan 999
switchport mode access
interface gi2/6
switchport mode trunk
Cat4506 connected to 7206 (the left one):
vlan 999
interface Gi3/24
interface gi2/6
Those should do it. :-)
